Author Topic: Dropbox and Megasync integration with Thunar  (Read 2763 times)
Offline Zeffanyx
  • Neuling
  • GPU Card: Intel HD 3000
  • Skill: Intermediate
« on: 13. January 2015, 12:40:14 »
Hi guys,
Please share some knowledge about right-click menus for Dropbox and Megasync in Thunar. Specifically, I need to generate public links via context menu, just like in Nautilus or Nemo. Does that feature work with XFCE's Thunar?
Offline Ivanwah
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU Card: AMD Radeon HD 6670
  • GPU driver: Free (radeon)
  • Kernel: 4.2
Re: Dropbox and Megasync integration with Thunar
« Reply #1 on: 13. January 2015, 13:21:29 »
I know there is a package in AUR called thunar-dropbox which adds dropbox related items to context menus in thunar, maybe you could try that.
Offline Zeffanyx
  • Neuling
« Reply #2 on: 13. January 2015, 13:29:21 »
I've tried that, but only offers "Move to Dropbox" menu.
Offline Ivanwah
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: Cinnamon
  • Kernel: 4.2
« Reply #3 on: 13. January 2015, 14:37:50 »
Oh, it's been a while since I used dropbox, I don't remember what was available in that package. Well, I can't help you further, hope someone else will be able to.
Offline Mozon
  • Support Team
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: HD 4600
  • GPU driver: free
  • Kernel: 4.6
  • Skill: Advanced
« Reply #4 on: 13. January 2015, 14:45:22 »
@Zeffanyx
If you visit another Folder as Dropbox the right-klick-menue offers only "move to Dropbox"
If you are in the Dropbox folder you get more options like Share link, earlier Version, see on dropbox.com (not correktly the same  but I used in another language).
The menu changed a little  again if you are in the Dropbox/private folder.
Made quik a short Movie for better underständing
http://youtu.be/ALG5kd79X8w
« Last Edit: 13. January 2015, 15:13:03 by Mozon »
Offline notuxius
  • Neuling
  • Branch: unstable
  • Desktop: LXDE, KDE, XFCE
  • GPU Card: ATI 4200
  • GPU driver: free
  • Kernel: latest x64
« Reply #5 on: 22. December 2016, 21:12:47 »
And what about Megasync?
Offline cipricus
  • Jr. Mitglied
  • Desktop: Fluxbox
  • Kernel: linux38-x64
  • Skill: Novice
« Reply #6 on: 29. September 2017, 01:34:20 »
There is a simple workaround that I find preferable to a separate program; like always with Thunar, custom actions is the way to go.
But instead of uploading the files or folders to "/MEGAsync Uploads", they will simply be copied in the Mega folder on the computer and from there uploaded by the megasync client.
So: add a custom action in Thunar with the line:
cp -r %F "/path/to/your/Mega/folder"
and check all boxes for Appearance conditions.
