Author Topic: sudo pacman-mirrors -g gives Error! after Manjaro Update 2014-12-25 (stable)  (Read 1395 times)
Offline bayone
  • Neuling
  • Branch: stable
  • Desktop: Mate
  • GPU Card: nVidia Quadro
  • GPU driver: non-free
  • Kernel: linux40-x64
  • Skill: Intermediate
Hi,
I get Error! on
Code: [Select]
sudo pacman-mirrors -g for all mirrors after the subject update.
Code: [Select]
:: Querying servers, this may take some time...
Japan
-> Error!http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
-> Error!http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
:: Generated and saved '/etc/pacman.d/mirrorlist' mirrorlist.
Before this update it used to work fine.
The same behavior persisted after the latest update (Manjaro Update 2015-01-04 (stable)).
Reinstalling pacman-mirrors does not help, neither do the methods described in https://forum.manjaro.org/index.php?topic=12138.0
I am behind a proxy server, so this might related to the problem.
My current solution is to use 'OnlyCountry=Japan' in pacman-mirrors.conf as described in https://wiki.manjaro.org/index.php?title=Create_your_own_Custom_Mirrorlist.
Although it does not change the 'Error!' behavior, it gives me the servers I want to use after an update.
Any ideas?
