Author Topic: Budgie -rience  (Read 2607 times)
Offline rydhwan
  • Sr. Mitglied
  • slowly
  • Branch: unstable
  • Desktop: Plasma 5, Gnome, Cinnamon, Deepin, Unity,
  • GPU Card: Intel
  • GPU driver: free driver
  • Kernel: linux 4.1
  • Skill: Novice
Budgie -rience
« on: 04. January 2015, 19:20:18 »
after net-install
I added the following applications :
gdm gnome-themes-standard gnome-session gnome-shell-extensions dkms net-tools xdg-user-dirs sudo bash-completion wget grub os-prober baobab evince file-roller firefox gedit gnome-backgrounds gnome-calculator gnome-control-center gnome-screenshot gnome-system-monitor gnome-terminal gnome-tweak-tool gstreamer0.10-plugins mutter nautilus noise vala viewnior vlc;
Install Budgie
Now logout and you can change to Budgie-Desktop as your session!
but in the end nothing happens
I have  "not found budgie-desktop"
any idea ? 8)
American dream. welcome to Guantánamo civil-isation
we are all different ... this is our common
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
  • Skill: Intermediate
Re: Budgie -rience
« Reply #1 on: 04. January 2015, 19:59:41 »
after net-install
Why not a simply yaourt -S budgie-desktop-git ?
Was a while back but that worked for me.
Offline rydhwan
  • Sr. Mitglied
  • slowly
  • Branch: unstable
  • GPU Card: Intel
  • Kernel: linux 4.1
  • Skill: Novice
Re: Budgie -rience
« Reply #2 on: 04. January 2015, 20:56:13 »
pacman -Ss budgie
community/budgie-desktop 8-1
    Simple GTK3 desktop experience
following applications is needed i think?
Offline simgin
  • Held Mitglied
  • Branch: All.
  • Desktop: XFCE+Alpine Linux, Mate+Fedora, Ubuntu Server + Mate and NoX+LinuxBBQ
  • GPU Card: GeForce 8600M & GT 555M 2GB
Re: Budgie -rience
« Reply #3 on: 05. January 2015, 00:39:51 »
Hmmm, damn , hope Mandog see's this, because he bas done this many times. Budgie rules, but I use EvolveOS in VM, so I do not have this issue atm, sorry.  But as Mips says, go for the git version.
Cheers
simon
Offline rydhwan
  • Sr. Mitglied
  • slowly
  • Branch: unstable
  • GPU Card: Intel
  • Kernel: linux 4.1
  • Skill: Novice
Re: Budgie -rience
« Reply #4 on: 05. January 2015, 07:00:37 »
thanks
after fresh netinstall i add yaourt -S budgie-desktop-git
but have this errors :
'not find fekeroot binary required for build as non root user' and
'not find the strip binary required for object file stripping'
what's wrong ?
« Last Edit: 05. January 2015, 10:49:03 by rydhwan »
Offline whoknows
  • Vollwertiges Mitglied
  • Branch: Unstable
  • Desktop: KDE
  • GPU Card: Intel
  • GPU driver: Free
  • Kernel: Linux318-64
  • Skill: Novice
Re: Budgie -rience
« Reply #5 on: 05. January 2015, 12:24:25 »
Seems like you need the base-developer group of packages
Code: [Select]
sudo pacman -S base-devel
Offline rydhwan
  • Sr. Mitglied
  • slowly
  • Branch: unstable
  • GPU Card: Intel
  • Kernel: linux 4.1
  • Skill: Novice
Re: Budgie -rience
« Reply #6 on: 05. January 2015, 16:47:33 »
thanks
what exec in ~/.xinitrc : budgie-desktop not work
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
Re: Budgie -rience
« Reply #7 on: 05. January 2015, 16:50:10 »
thanks
Is this a question?
J.
Hitten by the door in the back when I left Manjaro.
Offline rydhwan
  • Sr. Mitglied
  • slowly
  • Branch: unstable
  • GPU Card: Intel
  • Kernel: linux 4.1
  • Skill: Novice
Re: Budgie -rience
« Reply #8 on: 05. January 2015, 16:54:57 »
yes
Offline NickStone
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: Radeon HD 3000
  • GPU driver: free
  • Kernel: Linux 3.18.32-1 x86_64
  • Skill: Novice
Re: Budgie -rience
« Reply #9 on: 05. January 2015, 18:18:18 »
Did you install the git edition from AUR or the official edition from Community database?
I installed Budgie this morning from repository(community) and it worked (kind of), removed it again as not fully working on my machine.
Full time GNU/Linux user since 2003, prior to that was duel booting Windows (98) and GNU/Linux (Mandrake).
Offline rydhwan
  • Sr. Mitglied
  • slowly
  • Branch: unstable
  • GPU Card: Intel
  • Kernel: linux 4.1
  • Skill: Novice
Re: Budgie -rience
« Reply #10 on: 05. January 2015, 18:30:54 »
budgie-desktop-git  wont work  :-[
Offline whoknows
  • Branch: Unstable
  • Desktop: KDE
  • GPU Card: Intel
  • GPU driver: Free
  • Skill: Novice
Re: Budgie -rience
« Reply #11 on: 05. January 2015, 20:18:19 »
I installed budgie-desktop-git on top of a minimal xfce install and it worked fine, so not sure what is missing from your install.
Offline flippy
  • AKA "day|flip" manjaro irc
  • Branch: Testing
  • Desktop: xmonad & bspwm
  • GPU Card: nVidia GeForce GTX 550 Ti
  • GPU driver: Nvida
  • Kernel: Got 64?
Re: Budgie -rience
« Reply #12 on: 05. January 2015, 20:48:01 »
If I were to figuer out how to start session on desktop I never used. pacman -Ql could help with this.
pacman -Ql budgie-desktop-git   look under /usr/bin/
Normally it exec desktopname or exec desktopname-session
Offline Zileene
  • Held Mitglied
  • Branch: Stable
  • Desktop: awesomeWM,Gnome
  • GPU Card: various
  • GPU driver: the one that works
  • Kernel: 4.1
Re: Budgie -rience
« Reply #13 on: 05. January 2015, 22:31:44 »
The EvolveOS forums and the readme.md on GitHub mention 'budgie-session'.
You could try that. ;)
Have Fun! ^-^
Z.
While I may not always have the correct solution, my input could lead you in the right direction...
If you don't know what a command does, then type 'man <command>' or '<command> --help' to find out.
Offline thundersqueak
  • Held Mitglied
  • everyone dies
  • Branch: all of em
  • Desktop: gnome
  • GPU Card: nvidia 9300
  • GPU driver: non-free
  • Kernel: most,if not all
  • Skill: Novice
Re: Budgie -rience
« Reply #14 on: 05. January 2015, 22:35:57 »
i would do net install then install gnome and gnome-extra groups then add budgie-desktop from repo,this is what i did works great.
"Why is it that every grubby little government i pass has the impertinence to assume that i can spare the time and energy necessary for their destruction?"
