Author Topic: GIMP segmentation fault  (Read 2136 times)
Offline bra10n
  • Jr. Mitglied
« on: 02. February 2013, 00:11:33 »
Gimp seg faults as an ordinary user but starts with root privileges.
I have unstable repos enabled here with a fully updated system.
Please ask for any specific information as required.
cheers
Aspire 5750 i5 2.3Ghz, HD 3000, 12GB DDR3
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
Re: GIMP segmentation fault
« Reply #1 on: 02. February 2013, 12:21:43 »
No issues here. Start it form a terminal and post the error messages.
Offline bra10n
  • Jr. Mitglied
« Reply #2 on: 02. February 2013, 23:40:32 »
Code: [Select]
[bra10n@manjaro ~]$ gimp
Segmentation fault (core dumped)
I've switched from unstable to the testing repo's with the same result.
Uninstalled, re installed. No difference here.
UPDATE: I found that GIMP works with a newly created user. How to fix this?
« Last Edit: 02. February 2013, 23:59:04 by bra10n »
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #3 on: 03. February 2013, 00:04:06 »
strange here also no issues ??
Dutch go the dutch site :)
Offline bra10n
  • Jr. Mitglied
[Solved] Re: GIMP segmentation fault
« Reply #4 on: 03. February 2013, 02:02:16 »
Solved.
Due to a missing .gimp-2.8 folder from ~/  ::)
No idea how this happened but I copied one across from a guest account, fiddled with permissions and now all is well.
Thanks for the responses.
