Author Topic: Issue with resizing & moving some app windows.  (Read 5761 times)
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
  • Skill: Intermediate
« on: 17. December 2014, 16:32:05 »
Chromium, WPS Office, Teamviewer & Steam will not allow me to resize windows by dragging the borders or move the window by dragging the title bar. The minimize & maximise buttons do however work. Really weird as other apps work fine.
Any ideas?
« Last Edit: 17. December 2014, 18:54:17 by mips »
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • Kernel: 3.16
Re: Issue with resizing & moving some app windows.
« Reply #1 on: 18. December 2014, 17:00:02 »
Anybody?
Offline Holmes
  • Mirror Support Team
  • Brazilian and Hispanic Support Team
    • Manjaro Brasil
  • Branch: Stable
  • Desktop: Manjaro XFCE
  • GPU Card: Mobile Intel (R) 945
  • GPU driver: Non-free
  • Kernel: kernellinux
  • Skill: Novice
« Reply #2 on: 19. December 2014, 21:00:17 »
Any ideas?
hi @mips, not know why this occurs. i will give a studied it.
vlw fwi, Holmes :)
==> Manjaro Brasil I Manjaro Hispano
==> IRC Manjaro Brasil: #manjaro-br I IRC Manjaro Hispano: #manjaro-es
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • Kernel: 3.16
« Reply #3 on: 02. January 2015, 13:37:18 »
I did a fresh install of 0.8.11 a few minutes ago, updated, installed chromium and I still have the same issue.
Offline Zileene
  • Held Mitglied
  • Branch: Stable
  • Desktop: awesomeWM,Gnome
  • GPU Card: various
  • GPU driver: the one that works
  • Kernel: 4.1
« Reply #4 on: 02. January 2015, 17:52:59 »
I haven't tried PEK properly, but is there/can you set a move/resize keyboard+mouse combo, like there is in AwesomeWM?
(Mod4+leftMouse=move, Mod4+rightMouse=resize)
That could at least serve as a workaround.
Have Fun! ^-^
Z.
While I may not always have the correct solution, my input could lead you in the right direction...
If you don't know what a command does, then type 'man <command>' or '<command> --help' to find out.
Offline mxx
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Openbox/i3wm
  • Kernel: linux4
« Reply #5 on: 02. January 2015, 18:44:05 »
Are those windows meant to be resizable? For example Parcellite preferences window is annoyingly implemented as non-resizable.
Offline immerblind
  • Jr. Mitglied
  • Branch: Archlinux
  • Desktop: Gnome 3.16
  • GPU Card: Intel 3rd Gen Core processor Graphics Controller
  • GPU driver: video-intel
  • Kernel: x86_64 Linux 3.19
  • Skill: Novice
« Reply #6 on: 02. January 2015, 19:34:49 »
just wanne tell you, you are not alone with that problem.
it affects not all windows, i noticed this problem with chromium (switched to opera for now, works fine)
did you tried different themes?
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • Kernel: 3.16
« Reply #7 on: 02. January 2015, 22:21:04 »
Have Fun! ^-^
Z.
You can resize via the mouse bindings but the grab handles do nothing.
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • Kernel: 3.16
« Reply #8 on: 02. January 2015, 22:21:42 »
Yes.
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • Kernel: 3.16
« Reply #9 on: 02. January 2015, 22:24:45 »
I have googled and not yet found a solution. this is pekwm related as it does not happen in other wm/dm environments.
It's not theme related either.
If I cant solve this I will have to revert to openbox which I'm not keen on.
« Last Edit: 02. January 2015, 22:28:30 by mips »
Offline tropper
  • Vollwertiges Mitglied
  • Sorry my bad english
    • Manjaro Geek
  • Branch: testing
  • Desktop: ManjaroPek
  • GPU Card: SIS
  • GPU driver: SIS
  • Kernel: 3.18
  • Skill: Advanced
« Reply #10 on: 04. January 2015, 09:02:23 »
Hello people, I can not understand the problem, someone could make a short video to demonstrate. So it is possible I could help.
 ;D ;D ;D ;D ;D ;D
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • Kernel: 3.16
« Reply #11 on: 04. January 2015, 09:56:18 »
What's a good/simple screen recorder app to use?
Offline Zileene
  • Held Mitglied
  • Branch: Stable
  • GPU Card: various
  • Kernel: 4.1
« Reply #12 on: 05. January 2015, 22:17:37 »
simplescreenrecorder
I use it all the time.
You can find it in the repos.
Have Fun! ;D
Z.
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #13 on: 10. January 2015, 10:51:34 »
hello @mips, researched about your problem and i confess that i do not know how to solve. i sent an email to the developers for help. we await the return. sorry for not knowing solve the problem.
Quote
hi pekdon and shared, i'm Holmes the maintainer of ManjaroPek (Manjaro Linux with Pekwm). mips, user the ManjaroPek, this one with a problem and i wonder if you guys could help me. the problem is:
- title: Issue with resizing & moving some app windows
- content: Chromium, WPS Office, Teamviewer & Steam will not allow me to resize windows by dragging the borders or move the window by dragging the title bar. The minimize & maximise buttons do however work. Really weird as other apps work fine.Any ideas?
i studied the case, but do not know how to solve this and would like to know if you have solution to the problem report for mips.
the link below contains all discussion about the topic:
https://forum.manjaro.org/index.php?topic=18856.msg172154#msg172154
thank you and sorry for the my bad English.
vlw fwi, Holmes
vlw fwi, Holmes :)
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #14 on: 14. January 2015, 14:31:15 »
hello @mips, Claes Nästén response:
Quote
Hi,
I've tried Chromium Version 39.0.2171.95 on my FreeBSD computer together
with pekwm version from GIT and it works without any issues, both with
and without "Use system title bar and borders" checked.
Any modifications done to ~/.pekwm/mouse or ~/.pekwm/autoproperties?
Tried using the GIT version?
vlw fwi, Holmes :)
