Author Topic: ManjaroPek OpenRC 0.8.11 released!  (Read 6572 times)
Offline mxx
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Openbox/i3wm
  • Kernel: linux4
  • Skill: Intermediate
Re: ManjaroPek OpenRC 0.8.11 released!
« Reply #15 on: 16. December 2014, 20:42:08 »
I am testing this. The first update after install does not work before these instructions are followed https://forum.manjaro.org/index.php?topic=18504.msg170671#msg170671
Offline mxx
  • Sr. Mitglied
  • Branch: stable
  • Kernel: linux4
« Reply #16 on: 16. December 2014, 22:53:02 »
Gufw is in the menus but not installed. After gksudo the menu item did nothing. To get ufw working, easiest is to do
Code: [Select]
sudo pacman -S ufw-openrc
Offline mxx
  • Sr. Mitglied
  • Branch: stable
  • Kernel: linux4
« Reply #17 on: 16. December 2014, 23:02:18 »
REDME contains mistaken instructions. There's no .config/pekwm directory. There's .pekwm
Offline Holmes
  • Mirror Support Team
  • Brazilian and Hispanic Support Team
    • Manjaro Brasil
  • Branch: Stable
  • Desktop: Manjaro XFCE
  • GPU Card: Mobile Intel (R) 945
  • GPU driver: Non-free
  • Kernel: kernellinux
  • Skill: Novice
« Reply #18 on: 16. December 2014, 23:37:20 »
thank @mxx by the observations. the readme was wrong, the correct is: ~/.pekwm. to run the Gufw is necessary to run the firewall script, in: menu>system>script support>firewall. see the contents of the script:
Code: [Select]
#!/bin/bash
# Simple bash script to install the necessary software packages to
# enable firewal. Ufw service is then enabled and
# started.
# Written by Carl Duff (Adapted ManjaroPek Team)
# Information about this script for the user
echo "${title}Install and Enable Full Firewall${nrml}
This will install all the necessary software to enable firewall.
Press ${grnb}<enter>${nrml} to proceed. You may still cancel the process when prompted."
read
pacman -S gufw ufw ufw-openrc && rc-update add ufw default && sudo ufw enable
read -p $'\n'"Process Complete. Press ${grnb}<enter>${nrml} to continue"$'\n'
exit 0
vlw fwi, Holmes :)
==> Manjaro Brasil I Manjaro Hispano
==> IRC Manjaro Brasil: #manjaro-br I IRC Manjaro Hispano: #manjaro-es
Offline mxx
  • Sr. Mitglied
  • Branch: stable
  • Kernel: linux4
« Reply #19 on: 17. December 2014, 02:03:03 »
Are your grub settings somewhere else than /etc/default/grub ? I want to make the grub not to show up and to make it countdown just one second to make it faster.
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #20 on: 17. December 2014, 02:46:35 »
hello @mxx, the link http://bit.ly/1weWcw7 are the settings grub. any problem to access the link communicates.
OBS.: all ManjaroPek OpenRC settings are here http://bit.ly/1weZ64a.
vlw fwi, Holmes :)
« Last Edit: 17. December 2014, 03:05:42 by Holmes »
Offline mt12345
  • Jr. Mitglied
  • Branch: stable
  • Desktop: i3
  • GPU Card: Intel
  • Kernel: 4.4.21-1 x64
« Reply #21 on: 17. December 2014, 03:31:33 »
/boot/grub/grub.cfg
Offline mxx
  • Sr. Mitglied
  • Branch: stable
  • Kernel: linux4
« Reply #22 on: 17. December 2014, 07:26:01 »
Thanks mt12345. That file tells me that my grub timeout is changed to what I want, but the boot behaviour still doesn't reflect that unfortunately.
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
« Reply #23 on: 17. December 2014, 07:55:23 »
Did you sudo update-grub after editing the config file?
Offline mxx
  • Sr. Mitglied
  • Branch: stable
  • Kernel: linux4
« Reply #24 on: 17. December 2014, 08:18:08 »
Of course. Done it about twenty times now and rebooted each time too.
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #25 on: 17. December 2014, 11:05:08 »
hi @mxx, then, gave sure the changes did you do?
vlw fwi, Holmes :)
Offline mxx
  • Sr. Mitglied
  • Branch: stable
  • Kernel: linux4
« Reply #26 on: 17. December 2014, 11:23:14 »
update-grub works nicely.. the only weird thing it says is
Code: [Select]
  /run/lvm/lvmetad.socket: connect failed: No such file or directory
  WARNING: Failed to connect to lvmetad. Falling back to internal scanning.
But since I don't have an lvm install, I thought it's okay... Otherwise it says Found Found Found as usual.
Offline mt12345
  • Jr. Mitglied
  • Branch: stable
  • Desktop: i3
  • GPU Card: Intel
« Reply #27 on: 17. December 2014, 12:19:50 »
you can quickly change timeout by editing /boot/grub/grub.conf (no update-grub, just reboot!)
but if you update/install kernel and you do update-grub, new file is created overwriting  your changes, reading the value from defaults - so it's better to edit  /etc/defaults/grub (and update-grub)
Offline mxx
  • Sr. Mitglied
  • Branch: stable
  • Kernel: linux4
« Reply #28 on: 18. December 2014, 20:51:19 »
Is there a tutorial how to switch from Network Manager to WICD?
Network Manager has completely stopped working for me. In this release, I cannot connect to wifi properly, while I can to ethernet and usb modem, on another machine it's the other way round.
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
  • Desktop: Xfce, Openbox
  • GPU Card: Intel HD 4000
  • Kernel: Linux 4.4 x86_64
« Reply #29 on: 18. December 2014, 21:30:53 »
You could try the following:
Code: [Select]
pkill nm-applet
sudo rc-service networkmanager stop
sudo rc-update del networkmanager
sudo pacman -S wicd-openrc wicd-gtk
sudo rc-update add wicd
sudo rc-service wicd start
wicd-gtk --tray &
To remove networkmanager-openrc, you could remove all that depended on it (like networkmanager-dispatcher-ntpd), and then do
Code: [Select]
sudo pacman -S libnm-glibyou can remove libnm-glib afterwards.
« Last Edit: 18. December 2014, 21:38:12 by aaditya »
