Author Topic: Upgrade KDE 4 installation to Plasma 5  (Read 68568 times)
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • GPU Card: Intel HD4000 + Nvidia 620M / Geforxe GTX 970
  • GPU driver: nonfree
  • Kernel: Latest
  • Skill: Intermediate
« on: 26. November 2014, 18:48:00 »
To install Plasma 5 in a net installation, you would start in step 3.
1. Update your system
Code: [Select]
sudo pacman -Syu
2. Remove everything that depends on kdebase-workspace
Code: [Select]
sudo pacman -R $(LANG=C pacman -Qi kdebase-workspace | grep "Req" | sed -e  's/Required By\s*:\s*//g')
And remove kdebase-workspace too
Code: [Select]
sudo pacman -R kdebase-workspace
3. Install the Plasma 5 desktop
Basic stuff:
Code: [Select]
sudo pacman -S bluedevil breeze drkonqi kde-gtk-config kdeplasma-addons kgamma5 khelpcenter kinfocenter kio-extras kmenuedit kscreen ksshaskpass ksysguard kwallet-pam kwayland-integration kwin kwrited milou oxygen oxygen-cursors plasma-desktop plasma-nm plasma-pa plasma-workspace plasma-workspace-wallpapers powerdevil systemsettings user-manager
Display manager (sddm):
Code: [Select]
sudo pacman -S sddm sddm-kcm
KDE4/QT4 Theming:
Code: [Select]
sudo pacman -S breeze-kde4 oxygen-kde4
GTK Themes:
gtk-theme-maia
breeze-gtk
gnome-themes-standard for Adwaita theme (oficial gtk3 theme)
Print, service manager:
Code: [Select]
sudo pacman -S print-manager systemd-kcm
Better systray/notification support:
Code: [Select]
sudo pacman -S sni-qt libappindicator-gtk2 libappindicator-gtk3 libappindicator-sharpAlso for 64 bits:
Code: [Select]
sudo pacman -S lib32-sni-qt
Say YES (y) for all conflicts
4. Enable the display manager (sddm)
Code: [Select]
sudo systemctl enable sddm -f
If for some reason that command fails, try this
Code: [Select]
sudo rm /etc/systemd/system/display-manager.service
Now you can reboot (type "reboot" in the console, it doesn't work using the launcher)
5. Post installation
-Configure sddm
If you installed sddm-kcm, go to System Settings -> Startup and Shutdown -> Login Screen (SDDM) and select the theme you want (Breeze is recommended)
If not you go to a terminal
Code: [Select]
su
(type your root password)
sddm --example-config > /etc/sddm.conf
nano /etc/sddm.conf
And change this lines:
Code: [Select]
[Theme]
# Current theme name
Current=breeze
# Cursor theme
CursorTheme=breeze_cursors
- Install Maia Plasma Theme
Code: [Select]
sudo pacman -S plasma5-themes-maia sddm-maia-theme
Go to System Settings -> Workspace Theme -> Look and Feel -> select Maia and apply
It also includes a theme for sddm go to System Settings -> Startup and Shutdown -> Login Screen (SDDM) and select Maia.
And that's all, if you have any problem just ask :)
« Last Edit: 03. April 2016, 18:42:08 by Kirek »
Offline AJ1000
  • Sr. Mitglied
  • Branch: stable
  • Desktop: LXQT
  • GPU Card: NVidia
  • GPU driver: Free
  • Skill: Novice
Re: Upgrade KDE 4 installation to Plasma 5
« Reply #1 on: 26. November 2014, 19:37:23 »
Great work. Thanks.
Offline AJ1000
  • Sr. Mitglied
  • Branch: stable
  • Desktop: LXQT
  • GPU Card: NVidia
  • GPU driver: Free
  • Skill: Novice
« Reply #2 on: 29. November 2014, 12:56:24 »
I got it working. I had to do a lot more it get it to be similar to the v9.0 iso version, but it all works now.
Thanks very much Kirek, very much appreciated.
Offline ewolnux
  • Held Mitglied
  • Branch: Stable
  • Desktop: KDE (the best)
  • GPU driver: Free
  • Kernel: 4.1.x
« Reply #3 on: 29. November 2014, 13:04:24 »
Hi
How sddm display (maui) in the user icon.
My sddm.conf:
Code: [Select]
[Autologin]
Relogin=false
Session=
User=
[General]
HaltCommand=/usr/bin/systemctl poweroff
Numlock=on
RebootCommand=/usr/bin/systemctl reboot
[Theme]
Current=maui
CursorTheme=KDE_Classic
FacesDir=/usr/share/sddm/faces
ThemeDir=/usr/share/sddm/themes
[Users]
DefaultPath=/bin:/usr/bin:/usr/local/bin
HideShells=
HideUsers=
MaximumUid=65000
MinimumUid=1000
RememberLastSession=true
RememberLastUser=true
[XDisplay]
DisplayCommand=/usr/share/sddm/scripts/Xsetup
MinimumVT=7
ServerPath=/usr/bin/X
SessionCommand=/usr/share/sddm/scripts/Xsession
SessionDir=/usr/share/xsessions
XauthPath=/usr/bin/xauth
Administrator MANJARO FRANCE
Rejoignez la communauté francophone sur manjaro.fr.
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
« Reply #4 on: 29. November 2014, 13:16:26 »
You'll need to copy your .face icon to /usr/share/sddm/faces and rename it to {user}.face.icon yourself.
« Last Edit: 29. November 2014, 13:31:14 by AJSlye »
Offline ewolnux
  • Held Mitglied
  • Branch: Stable
  • GPU driver: Free
  • Kernel: 4.1.x
« Reply #5 on: 29. November 2014, 13:38:05 »
Thank's.
Where to find a doc to set sddm ?
Offline conky57
  • Held Mitglied
  • Branch: testing
  • Desktop: KDE Plasma 5.8.4 (16.10 Fringilla) w/OpenRC
  • GPU Card: M92 Ati Mobility Radeon HD 4500 Series
  • GPU driver: free
  • Kernel: 3.18.32-1-MANJARO - x86_64
  • Skill: Novice
« Reply #6 on: 29. November 2014, 13:57:50 »
Be kind to everyone, because everyone is fighting some sort of battle.
LinuxCounter registered user  #278931
Offline ewolnux
  • Held Mitglied
  • Branch: Stable
  • GPU driver: Free
  • Kernel: 4.1.x
« Reply #7 on: 29. November 2014, 14:01:49 »
This should be what you need: https://wiki.manjaro.org/index.php?title=Install_Display_Managers#SDDM
Best regards.
Thank you, but only for installation; I'm looking for documentation for setup.
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • Kernel: Latest
« Reply #8 on: 29. November 2014, 14:08:47 »
Thank's.
man sddm.conf
Offline conky57
  • Held Mitglied
  • Branch: testing
  • GPU driver: free
  • Skill: Novice
« Reply #9 on: 29. November 2014, 14:10:49 »
Oh, ok. Here maybe too: https://wiki.archlinux.org/index.php/SDDM
Best regards.
Offline ewolnux
  • Held Mitglied
  • Branch: Stable
  • GPU driver: Free
  • Kernel: 4.1.x
« Reply #10 on: 29. November 2014, 14:14:39 »
@Kirek & conky57 : thank you.
I never think of this man.
What is unfortunate is that it is in English (I'm French).
It's better than nothing and it should be fine.
Offline rydhwan
  • Sr. Mitglied
  • slowly
  • Branch: unstable
  • Desktop: Plasma 5, Gnome, Cinnamon, Deepin, Unity,
  • GPU Card: Intel
  • GPU driver: free driver
  • Kernel: linux 4.1
  • Skill: Novice
« Reply #11 on: 30. November 2014, 20:36:55 »
fantastic all ok merci
exept no window decoration
any idea ?
American dream. welcome to Guantánamo civil-isation
we are all different ... this is our common
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • Kernel: Latest
« Reply #12 on: 30. November 2014, 20:41:50 »
Selecting another window decorations doesn't work?
Code: [Select]
kcmshell5 kwindecoration
Offline rydhwan
  • Sr. Mitglied
  • slowly
  • Branch: unstable
  • GPU Card: Intel
  • Kernel: linux 4.1
  • Skill: Novice
« Reply #13 on: 30. November 2014, 21:12:12 »
Icon theme "oxygen" not found.
Trying to open ksycoca from "/home/rydma/.cache/ksycoca5"
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • Kernel: Latest
« Reply #14 on: 30. November 2014, 21:15:02 »
Install the oxygen package
Code: [Select]
sudo pacman -S oxygen
I guess I have to add it to the minimal plasma 5 installation.
