Author Topic: Evince cannot scroll with mouse  (Read 2054 times)
Offline oli
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: Openbox, Pekwm
  • GPU Card: Intel core processor integrated graphics controller
  • GPU driver: Free
  • Kernel: 3.18 or 3.16
  • Skill: Novice
« on: 25. November 2014, 09:00:18 »
Hi All,
I posted this in the applications sub forum a week or so ago, but didn't get any reply so I thought I'd ask again in here. My problem is that I cannot scroll with the mouse wheel in evince. I think the problem is related to Pekwm since I didn't have any problem in my openbox set up. Mouse wheel scrolling is working fine in all other programs. Does anyone have any ideas?
Cheers! ;)
Didn't we already pass that same stack of rocks twice?
Offline babouk
  • Neuling
  • Branch: stable
  • Desktop: Pekwm and i3 with xfce
  • Skill: Novice
Re: Evince cannot scroll with mouse
« Reply #1 on: 25. November 2014, 14:23:35 »
I can not test it at the moment, but
in the pekwm config files there is a mouse file:
$HOME/.pekwm/mouse
Thr Pekwm-Projekt page also offers dokumentation about the mouse file:
https://www.pekwm.org/files/pekwm/doc/0.1.17/html/config/keys_mouse.html
Hope that helps  ;)
babouk
Offline oli
  • Branch: stable
  • GPU driver: Free
  • Skill: Novice
« Reply #2 on: 26. November 2014, 09:27:05 »
Thanks for the suggestion, but I looked in that file and in the documentation and as far as I can tell there are no application specific settings contained within it. The settings there configure things like using scroll wheel to switch desktops, which works perfectly. It is only with evince that it's not working so its quite strange...
Offline tropper
  • Sorry my bad english
    • Manjaro Geek
  • Branch: testing
  • Desktop: ManjaroPek
  • GPU Card: SIS
  • GPU driver: SIS
  • Kernel: 3.18
  • Skill: Advanced
« Reply #3 on: 26. November 2014, 15:44:33 »
Hello Oli, gtk3 does not work very well with Pekwm, the suggestion that I take is the removal of Evince and use another application. I suggest xournal the official repository.
In AUR there are good applications running.
evince-gtk2
masterpdfeditor - (owner code)
flpsed
Offline oli
  • Branch: stable
  • GPU driver: Free
  • Skill: Novice
« Reply #4 on: 27. November 2014, 12:49:10 »
Okay, so I will look for another pdf viewer, I checked aur with yaourt -Ss evince and saw that there are quite a few variants of evince, but none of them seem to be well maintained, evince2, evince2-lite and evince-gtk all failed to build and I see others having similar problems... I tried flsped/xournal too, but while it seems like a good option for making annotations it doesn't offer so much in terms of usability while reading (at least not as good as evince). Last time I tried Okular I didn't like it at all, it is quite a beast from what I remember. Basically I want something with equivalent functionality as evince, since when the scroll wheel is working, evince is perfect.
Offline Holmes
  • Mirror Support Team
  • Brazilian and Hispanic Support Team
    • Manjaro Brasil
  • Branch: Stable
  • Desktop: Manjaro XFCE
  • GPU Card: Mobile Intel (R) 945
  • GPU driver: Non-free
  • Kernel: kernellinux
  • Skill: Novice
« Reply #5 on: 28. November 2014, 03:10:55 »
tests the raktpdf...
vlw fwi, Holmes :)
==> Manjaro Brasil I Manjaro Hispano
==> IRC Manjaro Brasil: #manjaro-br I IRC Manjaro Hispano: #manjaro-es
Offline oli
  • Branch: stable
  • GPU driver: Free
  • Skill: Novice
« Reply #6 on: 28. November 2014, 22:07:56 »
I tested raktpdf, it seems good, but its a bit simple for me, it is lacking a fit to page width, doesn't seem to display an index and no continuous mode. I spend quite a bit of time reading .pdf so these features are kind of essential. But I found zathura, this seems to work quite well once you have memorized the relevant keyboard commands... :o
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #7 on: 28. November 2014, 22:47:35 »
did not know and i will study this (zathura). thx... ;)
vlw fwi, Holmes :)
Offline Aliraza47
  • Neuling
  • I'm new. Be nice!
  • Branch: aaaaaaaaa
  • Desktop: aaaaaaaaa
  • GPU Card: aaaaaaaaa
  • GPU driver: aaaaaaaaa
  • Kernel: aaaaaaaaa
  • Skill: Advanced
« Reply #8 on: 15. April 2015, 12:03:12 »
That printer doesn't require hplip-plugin however, To solve the problem, specify the IP address of the HP printer for hp-setup to locate the printer.????
