Author Topic: 7zip GUI  (Read 3624 times)
Offline ljuba
  • Vollwertiges Mitglied
  • Skill: Advanced
7zip GUI
« on: 20. November 2014, 09:32:08 »
Any intstructions how to exclude 7zip GUI (but not to exclude 7zip itself)?
Offline ljuba
  • Skill: Advanced
Re: 7zip GUI
« Reply #1 on: 22. November 2014, 06:21:21 »
BUMP
Nobody???
Offline Salinko
  • Held Mitglied
  • Branch: manjaro-xfce-16.06-pre1-x86_64 (unstable)
  • Desktop: Xfce 4.12.3
  • GPU Card: Gigabyte HD7870 GHz Edition
  • GPU driver: radeon free
  • Kernel: 4.5.0-2-MANJARO x86_64
  • Skill: Novice
Re: 7zip GUI
« Reply #2 on: 22. November 2014, 06:32:01 »
Can you explain what you're referring to when you say "7zip GUI" please?
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
Re: 7zip GUI
« Reply #3 on: 22. November 2014, 08:58:13 »
Yes I do it's listed in the optional dependencies:
wxgtk2.8: GUI
desktop-file-utils: desktop entries
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • GPU driver: non-free
  • Kernel: linux314 x64
  • Skill: Advanced
Re: 7zip GUI
« Reply #4 on: 22. November 2014, 09:11:25 »
If you just want the menu entry gone from your menu, this will do it:
Code: [Select]
mkdir -p ~/.local/share/applications/
cp /usr/share/applications/7zFM.desktop ~/.local/share/applications/
echo "Hidden=Yes" >> ~/.local/share/applications/7zFM.desktop
To actually not have the 7-zip FM binary on your system you'd need to roll your own modified p7zip package.
Offline AJSlye
  • Maintainer
  • GPU Card: Intel
  • GPU driver: Intel
  • Skill: Guru
Re: 7zip GUI
« Reply #5 on: 22. November 2014, 09:35:19 »
@Rob
They could just install p7zip-standalone from the AUR instead of p7zip from extra.
There are also quite a few other options for p7zip in the AUR as well:
https://aur.archlinux.org/packages/?O=0&K=p7zip
« Last Edit: 22. November 2014, 09:46:15 by AJSlye »
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
Re: 7zip GUI
« Reply #6 on: 22. November 2014, 09:44:37 »
@Rob
Cool. :)
Offline AJSlye
  • Maintainer
  • GPU Card: Intel
  • GPU driver: Intel
  • Skill: Guru
Re: 7zip GUI
« Reply #7 on: 22. November 2014, 09:45:55 »
Ooops, I misread the original question, my first post was advice on how to get the GUI to run.
Offline ljuba
  • Skill: Advanced
Re: 7zip GUI
« Reply #8 on: 22. November 2014, 10:41:24 »
NOPE
You answered correctly with post for AUR packages (as I don't want to include GUI, as it is basically useless and destruct attention overloading menu - but I searched for solution to not mess with meny entries).
Thanks for recording me to exist AUR also.
Offline AJSlye
  • Maintainer
  • GPU Card: Intel
  • GPU driver: Intel
  • Skill: Guru
Re: 7zip GUI
« Reply #9 on: 22. November 2014, 11:06:06 »
I was referring to my first post and not the second, but no biggie. :)
Anyway, think of the AUR as sort of what PPA's are to Ubuntu, only much easier to use.
If you can't find what your looking for in the repositories, then 10 to 1 it's in the AUR. :D
« Last Edit: 22. November 2014, 11:11:22 by AJSlye »
Offline ljuba
  • Skill: Advanced
Re: 7zip GUI
« Reply #10 on: 22. November 2014, 11:14:49 »
Yeah, I know, but sometimes you cant see the three from the jungle. I also forgot for AUR. Thanks again.
Offline clintwelbar
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
Re: 7zip GUI
« Reply #11 on: 19. October 2015, 10:10:18 »
Try this one......7-Zip 9.20
Clint
