Author Topic: LXQT install help  (Read 1961 times)
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
  • Skill: Intermediate
Re: LXQT install help
« Reply #15 on: 26. November 2014, 10:40:56 »
I played with the settings for a bit, then went back to xfce opened a terminal window and ran:
Code: [Select]
yaourt -S lxqt-desktop-git oxygen-icons pcmanfm-qt-git qterminal-git --noconfirm
Once again this command died with the following error:
So I have stable LXQT but not the 'new stuff'.
a build error during the installation of lxqt-deskotp-git happens often.
in your case, it happened in liblxqt-git.
you can try to install liblxqt-git manually (and replace some packages if needed):
Code: [Select]
yaourt -S liblxqt-gitIF this finished successfully, run this command again:
Code: [Select]
IF the build fails again, wait a couple of days (sometimes weeks) and try again... the git packages are not always stable.
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline rabideau
  • Sr. Mitglied
  • just another day older...
    • ManyRoads
  • Branch: stable... and usually up to date
  • Desktop: xfce 4.12
  • GPU Card: nVidia
  • Kernel: 4.4-MANJARO x86_64
« Reply #16 on: 26. November 2014, 17:27:03 »
Sadly... the liblxqt-git install still fails.
Pax vobiscum,
...mark
“Letting go gives us freedom, and freedom is the only condition for happiness. If, in our heart, we still cling to anything - anger, anxiety, or possessions - we cannot be free.”  ― Thích Nhất Hạnh
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Desktop: LXQT/Plasma5, openrc & eudev
  • Kernel: x86_64
  • Skill: Advanced
« Reply #17 on: 26. November 2014, 17:31:18 »
Thats not really necessary to build from AUR, lxqt is in testing too. :)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #18 on: 26. November 2014, 17:58:32 »
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline rabideau
  • Sr. Mitglied
    • ManyRoads
  • GPU Card: nVidia
« Reply #19 on: 26. November 2014, 19:04:18 »
Those crash with the same errors...  :(
Pax vobiscum,
...mark
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
« Reply #20 on: 26. November 2014, 22:57:24 »
How do you mean "crash", please provide a little more info.
Code: [Select]
pacman -S lxqt
should get you started.
Offline rabideau
  • Sr. Mitglied
    • ManyRoads
  • GPU Card: nVidia
« Reply #21 on: 27. November 2014, 00:38:16 »
The crash is on the build:
CMakeFiles/Makefile2:60: recipe for target 'CMakeFiles/lxqt-qt5.dir/all' failed
make[1]: *** [CMakeFiles/lxqt-qt5.dir/all] Error 2
Makefile:137: recipe for target 'all' failed
make: *** [all] Error 2
==> ERROR: A failure occurred in build().
    Aborting...
==> ERROR: Makepkg was unable to build liblxqt.
==> Restart building liblxqt ? [y/N]
Pax vobiscum,
...mark
