Author Topic: LXQT install help  (Read 1864 times)
Offline rabideau
  • Sr. Mitglied
  • just another day older...
    • ManyRoads
  • Branch: stable... and usually up to date
  • Desktop: xfce 4.12
  • GPU Card: nVidia
  • Kernel: 4.4-MANJARO x86_64
  • Skill: Intermediate
LXQT install help
« on: 16. November 2014, 14:36:01 »
Has anyone been able to successfully install LXQT on Manjaro?  I keep getting a non-described error that hangs the install/ build at:
[100%] Building CXX object CMakeFiles/lxqt-qt5.dir/lxqt-qt5_automoc.cpp.o
My most recent attempt was with the installation via pacman of: lxqt-desktop-git  0.8.0.12.g137e4b1-1
Pax vobiscum,
...mark
“Letting go gives us freedom, and freedom is the only condition for happiness. If, in our heart, we still cling to anything - anger, anxiety, or possessions - we cannot be free.”  ― Thích Nhất Hạnh
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
Re: LXQT install help
« Reply #1 on: 16. November 2014, 14:54:28 »
how do you try to install?
on real hardware or virtualbox?
on manjaro net edition or another edition of manjaro?
what commands do you use for installation (it sounds like you use pacman to install git versions?)?
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline rabideau
  • Sr. Mitglied
    • ManyRoads
  • GPU Card: nVidia
« Reply #2 on: 16. November 2014, 15:11:52 »
I am using pacman and installing from my cinnamon manjaro desktop.  Everything runs on my Samsung 5 Ultra Netbook in full control of everything.  My only Windows install runs in virtualbox.
I am one of those guys who likes to run and select desktops from the login screen.
Pax vobiscum,
...mark
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #3 on: 16. November 2014, 15:18:21 »
i am installing lxqt at the moment. i want to install the latest packages from git in a quick and dirty way:
1. i installed manjaro net edition
2. i run these commands:
Code: [Select]
sudo pacman-mirrors -g -b unstable
sudo pacman -Syyuu
sudo pacman -Syyuu
sudo mhwd-kernel -i linux317
reboot
sudo pacman -S base-devel yaourt
yaourt -S lxqt-desktop-git oxygen-icons pcmanfm-qt-git qterminal-git openbox obconf-qt-git sddm-git --noconfirm
3.
Code: [Select]
sudo systemctl enable sddm
reboot
if you prefer more GUIs and do not want to use the latest packages (but all git packages from lxqt), do this:
1. install manjaro openbox edition and update it
2. run these commands:
Code: [Select]
yaourt -S lxqt-desktop-git oxygen-icons pcmanfm-qt-git qterminal-git --noconfirm
3.
reboot. in your login-manager, select "lxqt-desktop"
at the moment the "yaourt -S lxqt-desktop-git" fails with an error in lxqt-admin-git. i just ran
Code: [Select]
yaourt -S lxqt-admin-git
manually. then, i started the lxqt installation, again.
« Last Edit: 16. November 2014, 15:37:12 by excalibur1234 »
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #4 on: 16. November 2014, 15:22:32 »
so you want to install lxqt on a stable system.
include this repo and install all packages from there: https://forum.manjaro.org/index.php?topic=17216.0
just edit your /etc/pacman.conf file (as root) and add these lines at the bottom:
Code: [Select]
[repolxqt]
SigLevel = Optional TrustAll
Server = https://sourceforge.net/projects/repolxqt/files/$arch
then, you can install stable lxqt packages from octopi/pamac/pacman.
i recommend to install lxqt's file manager, too: pcmanfm-qt
Offline rabideau
  • Sr. Mitglied
    • ManyRoads
  • GPU Card: nVidia
« Reply #5 on: 16. November 2014, 17:55:31 »
Hi excalibur1234
I tried your initial recommendation and received the following error:
error: failed to commit transaction (conflicting files)
boost-libs: /usr/lib/libboost_filesystem.so.1.57.0 exists in filesystem
UPDATE: I renamed the offending file and the updates are underway.
« Last Edit: 16. November 2014, 18:31:15 by rabideau »
Pax vobiscum,
...mark
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #6 on: 16. November 2014, 18:52:00 »
when did you encounter that error?
with the following command?
Code: [Select]
if this is the case, try to install the part with the error message manually (this means without the "--noconfirm" flag)
Offline rabideau
  • Sr. Mitglied
    • ManyRoads
  • GPU Card: nVidia
« Reply #7 on: 16. November 2014, 19:17:06 »
Here's the latest error....
Linking CXX shared library liblxqt-qt5.so
/usr/bin/ld: cannot find -lQt5Xdg
collect2: error: ld returned 1 exit status
CMakeFiles/lxqt-qt5.dir/build.make:830: recipe for target 'liblxqt-qt5.so.0.8.0' failed
make[2]: *** [liblxqt-qt5.so.0.8.0] Error 1
CMakeFiles/Makefile2:60: recipe for target 'CMakeFiles/lxqt-qt5.dir/all' failed
make[1]: *** [CMakeFiles/lxqt-qt5.dir/all] Error 2
Makefile:137: recipe for target 'all' failed
make: *** [all] Error 2
==> ERROR: A failure occurred in build().
    Aborting...
==> ERROR: Makepkg was unable to build liblxqt-git.
By the way 3.17 hangs with a kernel panic error on boot.
Pax vobiscum,
...mark
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #8 on: 16. November 2014, 19:29:14 »
on manjaro net edition, i can do
Code: [Select]
yaourt -S liblxqt-git
without any errors.
maybe you should try to install the stable version of lxqt:
Code: [Select]
yaourt -S lxqt openbox obconf-qt-git oxygen-icons qterminal
Offline rabideau
  • Sr. Mitglied
    • ManyRoads
  • GPU Card: nVidia
« Reply #9 on: 16. November 2014, 19:49:14 »
I tried and here is the next failure....
CMakeFiles/lxqt-qt5.dir/build.make:863: recipe for target 'liblxqt-qt5.so.0.8.0' failed
    Aborting...
==> ERROR: Makepkg was unable to build liblxqt.
==> Restart building liblxqt ? [y/N]
Pax vobiscum,
...mark
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #10 on: 16. November 2014, 19:54:26 »
sorry, but i cannot reproduce this error.
therefore, i do not know how to fix it for you.
maybe somebody else can help rabideau?
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #11 on: 16. November 2014, 20:16:26 »
libqtxdg-git is installed ?
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline rabideau
  • Sr. Mitglied
    • ManyRoads
  • GPU Card: nVidia
« Reply #12 on: 16. November 2014, 20:23:22 »
Here's what is installed:
libqtxdg-git  1.0.0.7.g0503cf7-1
Pax vobiscum,
...mark
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #13 on: 16. November 2014, 20:27:28 »
I have the same.  :(
Offline rabideau
  • Sr. Mitglied
    • ManyRoads
  • GPU Card: nVidia
« Reply #14 on: 25. November 2014, 19:56:24 »
So here is what I ended up doing that seems to have worked:
Code: [Select]
sudo pacman -Syyuu
sudo pacman -Syyuu
reboot
reboot
As this was being run, there was an update notification via pacman (It was greybird theme). I ran the update once all the initial installation (of the stable version) was complete and ran:
Code: [Select]
reboot
On reboot LXQT was available on my mdm Login screen.  At login the following error appeared:
GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: An authentication agent already exists for the given subject
I played with the settings for a bit, then went back to xfce opened a terminal window and ran:
Code: [Select]
Once again this command died with the following error:
Quote
-- Configuring incomplete, errors occurred!
See also "/tmp/yaourt-tmp-mark/aur-liblxqt-git/src/build/CMakeFiles/CMakeOutput.log".
    Aborting...
So I have stable LXQT but not the 'new stuff'.
Pax vobiscum,
...mark
