Author Topic: LXQt with kwin  (Read 7963 times)
Offline conky57
  • Held Mitglied
  • Branch: testing
  • Desktop: KDE Plasma 5.8.4 (16.10 Fringilla) w/OpenRC
  • GPU Card: M92 Ati Mobility Radeon HD 4500 Series
  • GPU driver: free
  • Kernel: 3.18.32-1-MANJARO - x86_64
  • Skill: Novice
Re: LXQt with kwin
« Reply #30 on: 16. May 2015, 14:40:36 »
that is installed. Unfortunately it just simply does not show up in the menu.
And you replaced openbox with kwin_x11? I am not familiar with using kwin as replacement for openbox, but it does seem strange that KDE Systemsettings isn't available in your menu. Try running "systemsettings5" in a terminal and see if that works.
Best regards.
Be kind to everyone, because everyone is fighting some sort of battle.
LinuxCounter registered user  #278931
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Gnome 3.20x
  • GPU Card: Intel HD4400
  • GPU driver: free
  • Kernel: 4.4.5-1-ARCH
  • Skill: Intermediate
Re: LXQt with kwin
« Reply #31 on: 16. May 2015, 14:54:40 »
Best regards.
systemsettings5 launches it. Openbox is not even on my system anymore. I installed synaptic and it appears to work with that. Thanks for the help  ;)
Offline urbanomad64
  • Vollwertiges Mitglied
  • Branch: testing
  • Desktop: LXQt + OpenRC + eudev
  • GPU Card: nVidia GTX 750 Ti
  • GPU driver: non-free
  • Kernel: Linux45-x64
Re: LXQt with kwin
« Reply #32 on: 16. May 2015, 16:09:03 »
I replaced openbox with Kwin and the window borders and effects are all working. What turns me into Madness however, is the fact when i go to preferences-->lxqt settings I dont find Kde-systemsettings anywhere? what is this? Also when i click the window panel and try to go to window manager settings, it does not work.
I have this problem as well since two updates ago. systemsettings5 has disappeared from my LXQt Settings menu
Offline conky57
  • Held Mitglied
  • Branch: testing
  • GPU driver: free
  • Skill: Novice
Re: LXQt with kwin
« Reply #33 on: 16. May 2015, 16:42:35 »
Glad that worked. You could manually create an entry in your menu, for ease of access. :)
Best regards.
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
Re: LXQt with kwin
« Reply #34 on: 16. May 2015, 16:44:19 »
What turns me into Madness however, is the fact when i go to preferences-->lxqt settings I don't find Kde-systemsettings anywhere? what is this?
i have nothing in start menu --> preferences --> lxqt settings, too.
but i have 2 links to systemsettings5 in start menu --> preferences. in english, they are called "kde system settings" and "system settings". these links have been there at least since lxqt 0.8.
please look at my attached screenshot. in german these links are called "kde-systemeinstellungen" and "systemeinstellungen".
you are right. it does not work for me either.
i have never used this method for opening systemsettings5 before, so i cannot tell you whether this has worked in the past or not.
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
Re: LXQt with kwin
« Reply #35 on: 16. May 2015, 17:33:06 »
It would be very interesting to know how your links are done... a .desktop ?  ;)
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
Re: LXQt with kwin
« Reply #36 on: 16. May 2015, 19:32:09 »
i never created these links, i just installed kwin and systemsettings.
but i have found this file. if it is not there for your, maybe you can create it manually:
Code: [Select]
/usr/share/applications/kdesystemsettings.desktop
this is the file content:
Code: [Select]
[Desktop Entry]
Exec=systemsettings5
Icon=preferences-system
Type=Application
X-KDE-StartupNotify=true
NotShowIn=KDE;
GenericName=KDE System Settings
GenericName[ar]=إعدادات نظام كدي
GenericName[bs]=Sistemske postavke KDE-a
GenericName[ca]=Arranjament del sistema del KDE
GenericName[ca@valencia]=Arranjament del sistema del KDE
GenericName[cs]=Nastavení systému KDE
GenericName[da]=KDE Systemindstillinger
GenericName[de]=KDE-Systemeinstellungen
GenericName[el]=Ρυθμίσεις συστήματος του KDE
GenericName[en_GB]=KDE System Settings
GenericName[es]=Preferencias del sistema de KDE
GenericName[et]=KDE Süsteemi seadistused
GenericName[eu]=KDE sistemaren ezarpenak
GenericName[fi]=KDE:n järjestelmäasetukset
GenericName[fr]=Configuration du système de KDE
GenericName[ga]=Socruithe an Chórais KDE
GenericName[gl]=Configuración do sistema KDE
GenericName[he]=הגדרות מערכת של KDE
GenericName[hu]=KDE Rendszerbeállítások
GenericName[ia]=Preferentias de systema KDE
GenericName[id]=Pengaturan Sistem KDE
GenericName[is]=KDE kerfisstillingar
GenericName[it]=Impostazioni di sistema KDE
GenericName[kk]=KDE жүйелік параметрлері
GenericName[km]=ការ​កំណត់​ប្រព័ន្ធ KDE
GenericName[ko]=KDE 시스템 설정
GenericName[lt]=KDE sistemos nustatymai
GenericName[lv]=KDE sistēmas iestatījumi
GenericName[mr]=केडीई प्रणाली संयोजना
GenericName[nb]=KDE Systeminnstillinger
GenericName[nds]=KDE-Systeeminstellen
GenericName[nl]=KDE-systeeminstellingen
GenericName[pa]=KDE ਸਿਸਟਮ ਸੈਟਿੰਗ
GenericName[pl]=Ustawienia systemowe KDE
GenericName[pt]=Configuração do Sistema KDE
GenericName[pt_BR]=Configurações do Sistema KDE
GenericName[ro]=Configurări de sistem
GenericName[ru]=Параметры системы KDE
GenericName[sk]=Nastavenie systému KDE
GenericName[sl]=KDE-jeve sistemske nastavitve
GenericName[sr]=КДЕ Системске поставке
GenericName[sr@ijekavian]=КДЕ Системске поставке
GenericName[sr@ijekavianlatin]=KDE Sistemske postavke
GenericName[sr@latin]=KDE Sistemske postavke
GenericName[sv]=KDE:s systeminställningar
GenericName[tr]=KDE Sistem Ayarları
GenericName[ug]=KDE سىستېما تەڭشىكى
GenericName[uk]=Системні параметри KDE
GenericName[vi]=Thiết lập hệ thống KDE
GenericName[x-test]=xxKDE System Settingsxx
GenericName[zh_CN]=KDE 系统设置
GenericName[zh_TW]=KDE 系統設定
Name[ko]=KDE 시스템 설정
Name[ro]=Configurări de sistem KDE
X-DBUS-StartupType=Unique
Categories=Qt;KDE;Settings;
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
Re: LXQt with kwin
« Reply #37 on: 16. May 2015, 20:23:53 »
Ok, thanks, excalibur.   :) I will search why I don't have it.
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
Re: LXQt with kwin
« Reply #38 on: 16. May 2015, 20:30:25 »
i have installed systemsettings for a while now. i think i installed it as version 5.0 or 5.1.
maybe the latest version 5.3 has a bug?
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
Re: LXQt with kwin
« Reply #39 on: 16. May 2015, 21:12:35 »
Sorry, I was busy.
It's simple, we have a line in systemsettings.desktop :
Code: [Select]
OnlyShowIn=KDE;
it must be changed into :
Code: [Select]
OnlyShowIn=LXQt;
(care to the word LXQt :) )
There are together 2 .desktop : 1 for KDE, and one for the others, it seems.
« Last Edit: 16. May 2015, 21:14:18 by Esclapion »
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
Re: LXQt with kwin
« Reply #40 on: 17. May 2015, 01:04:56 »
Code: [Select]
OnlyShowIn=KDE;
Code: [Select]
OnlyShowIn=LXQt;
Thank you! That worked!
edit: this post was originally by urbanomad64. i moved the rest of his post into a new thread: https://forum.manjaro.org/index.php?topic=22840.0
