Author Topic: my mirrors are ok?  (Read 1409 times)
Offline chrismanjaro
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Kde
  • GPU Card: nVidia FeForce GT 635M
  • GPU driver: free
  • Kernel: linux 4.1.10.1
  • Skill: Novice
my mirrors are ok?
« on: 21. October 2014, 12:54:13 »
Hi guys
i'm in italy. i try to upgrade with sudo pacman -Syu
the shell show me this......
Code: [Select]
[chris@Linux ~]$ sudo pacman -Syu
[sudo] password for chris:
:: Sincronizzazione dei database in corso...
Initializing download: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/core/x86_64/core.db
File size: 131168 bytes
Opening output file /var/lib/pacman/sync/core.db.part
Starting download
Connection 0 finished                                                          ]
Connection 2 finished                                                          ]
Connection 1 finished                                                          ]
[100%] [..................................................] [  89,1KB/s] [00:00]
Downloaded 128,1 kilobytes in 1 second. (89,15 KB/s)
Initializing download: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/core/x86_64/core.db.sig
HTTP/1.1 404 Not Found
Initializing download: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/extra/x86_64/extra.db
File size: 1919152 bytes
Opening output file /var/lib/pacman/sync/extra.db.part
Starting download
Connection 3 finished                                                          ]
[100%] [..................................................] [ 176,3KB/s] [00:00]
Downloaded 1874,2 kilobytes in 10 seconds. (176,33 KB/s)
Initializing download: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/extra/x86_64/extra.db.sig
Initializing download: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/community/x86_64/community.db
File size: 2575237 bytes
Opening output file /var/lib/pacman/sync/community.db.part
Starting download
[100%] [..................................................] [ 219,0KB/s] [00:00]
Downloaded 2514,9 kilobytes in 11 seconds. (218,95 KB/s)
Initializing download: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/community/x86_64/community.db.sig
Initializing download: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/multilib/x86_64/multilib.db
File size: 136954 bytes
Opening output file /var/lib/pacman/sync/multilib.db.part
Starting download
[100%] [..................................................] [ 130,5KB/s] [00:00]
Downloaded 133,7 kilobytes in 1 second. (130,47 KB/s)
Initializing download: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/multilib/x86_64/multilib.db.sig
:: Aggiornamento del sistema in corso...
 non ci sono aggiornamenti disponibili
[chris@Linux ~]$
There are some problems? thanks
Offline Holmes
  • Mirror Support Team
  • Brazilian and Hispanic Support Team
    • Manjaro Brasil
  • Branch: Stable
  • Desktop: Manjaro XFCE
  • GPU Card: Mobile Intel (R) 945
  • GPU driver: Non-free
  • Kernel: kernellinux
  • Skill: Novice
Re: my mirrors are ok?
« Reply #1 on: 21. October 2014, 13:23:15 »
with comand
Code: [Select]
sudo pacman-mirrors -g
after
Code: [Select]
sudo pacman -Syyu
vlw fwi, Holmes :)
==> Manjaro Brasil I Manjaro Hispano
==> IRC Manjaro Brasil: #manjaro-br I IRC Manjaro Hispano: #manjaro-es
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Kde
  • GPU driver: free
  • Skill: Novice
« Reply #2 on: 21. October 2014, 23:08:41 »
thanks for your help.
i wonder if is normal that my shell show me several   -  HTTP/1.1 404 Not Found -
if u try to upgrade ...you have the same message?
Offline Jonathan
  • Held Mitglied
  • Branch: testing
  • Desktop: Cinnamon
  • GPU Card: ATI Mobility Radeon HD 4330/4350/4550
  • GPU driver: free
  • Kernel: 3.18.0-1-mainline
  • Skill: Intermediate
« Reply #3 on: 21. October 2014, 23:50:34 »
If your mirrorlist is old then some of them might be offline or inactive.
Thus errors are normal.
But I don't see "HTTP/1.1 404 Not Found" - just "Error".
I update frequently (every few days) and also refresh my mirrorlist then - so I have very few unreachable mirrors in the list.
You can try to edit /etc/pacman-mirrors.conf and use only mirrors in your own country or near you:
Code: [Select]
## Specify to use only mirrors from a specific country
## Disabled by default
OnlyCountry=Germany
The check will be faster but the list of servers to choose from might be quite limited for your country.
The mirrors in the example are close to you and also long term reliable as far as I know.
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Kde
  • GPU driver: free
  • Skill: Novice
« Reply #4 on: 22. October 2014, 00:22:21 »
I type  edit /etc/pacman-mirrors.conf   in the shell end i have this
Code: [Select]
"/etc/pacman-mirrors.conf" [Read only] 21 lines, 490 characters
now...what i have to do?
Offline Jonathan
  • Held Mitglied
  • Branch: testing
  • Desktop: Cinnamon
  • GPU driver: free
« Reply #5 on: 22. October 2014, 00:33:13 »
You don't have to do this - it was just a suggestion.
If you want to edit that file, you have to do it as the root user. It is a system file only writable by root.
Use whatever editor you are familiar with.
Start it from a terminal as the root user - like this:
Code: [Select]
sudo gedit /etc/pacman-mirrors.conf
(if your editor is "gedit" - I don't know which editor you have installed)
Cheers
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Kde
  • GPU driver: free
  • Skill: Novice
« Reply #6 on: 22. October 2014, 00:44:44 »
Code: [Select]
## Branch Pacman should use (stable, testing, unstable)
Branch=stable
## Generation method
## 1) rank   - rank mirrors depending on their access time
## 2) random - randomly generate the output mirrorlist
Method=rank
# OnlyCountry=Germany
## Input mirrorlist directory
MirrorlistsDir="/etc/pacman.d/mirrors"
## Output mirrorlist
OutputMirrorlist="/etc/pacman.d/mirrorlist"
this is my mirror....
Offline Jonathan
  • Held Mitglied
  • Branch: testing
  • Desktop: Cinnamon
  • GPU driver: free
« Reply #7 on: 22. October 2014, 01:02:11 »
That is the file which controls how your mirrorlist is created.
Code: [Select]
will do that.
What I suggested was cutting down the number of mirrors that are probed by uncommenting the one line
(remove the "#" in front of: # OnlyCountry=Germany)
But: it was a just suggestion, something you might try.
You should be fine using the command:
Code: [Select]
sudo pacman-mirrors -gwithout editing the file.
Sorry for the confusion.
[edit]: fix typo
« Last Edit: 22. October 2014, 09:47:46 by Jonathan »
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Kde
  • GPU driver: free
  • Skill: Novice
« Reply #8 on: 22. October 2014, 09:37:43 »
don't worry, thanks
