Author Topic: ISO LXQt 0.8 64 bits & 32 CD-Size released (to test)  (Read 9790 times)
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
  • Skill: Intermediate
Re: ISO LXQt 0.8 64 bits & 32 CD-Size released (to test)
« Reply #60 on: 24. October 2014, 00:15:14 »
i have just installed the 64bit version on an external hard drive and found a couple of bugs:
1. otter-browser is still set as default browser, although the 64bit version does not contain otter-browser anymore (instead chromium).
2. the privilege method is set to "su". "sudo" feels much more natural to me. i had to set the privilege method to "sudo" before i could use "sudo" in a terminal. the privilege method can be set within lxqt (start menu --> settings --> privileges ...).
3. i tried to set the "qterminal drop down" to my caps lock key. i use xmodmap to remap caps lock to F14 (i have done this in kde and xfce successful before and i could do it in lxqt). somehow, "qterminal drop down" does not save the F14 key as start/stop key. it always sets the default F12 key as start/stop key. this is strange.
4. i have updated to the latest sddm version 0.10. i created a config file for sddm:
Code: [Select]
sudo sddm --example-config > /etc/sddm.conf
i can edit the sddm.conf file and edit the code to:
Code: [Select]
User=ex
(ex is my username for lxqt)
despite that change, sddm does NOT autologin.
5. after changing a lot of settings (i do not remember which anymore), i was unable to boot using kernel 3.17.1. the system booted with kernel 3.14.22.
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #61 on: 24. October 2014, 00:33:09 »
Thanks for the feedbacks.
1) OK, I will change it.
2) strange, sudo works for me. I will do some tries.
3) to see also, but it's a bit advanced  ;)
4) sddm in the latest releases is a problem. I don't trust it for the moment.  I tried it, but stayed on a preceeding version who works very well. So long it will not be solved, please don't use it.
5) same than for sddm. The 3.17 has a lot of known problems, I use a 3.14 LTS for stability reasons.  My next will probably be the 3.16, but only when it will reach at least 10 subversions.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #62 on: 24. October 2014, 01:11:20 »
4) and 5) are not really important, i just wanted to tell you.
other bugs:
6. i tried to boot my system (using kernel 3.14.22 and the open/free nauveau graphics driver) without sddm. i disabled sddm:
Code: [Select]
sudo systemctl disable sddm
and rebooted. i logged in in a tty and i tried to start lxqt. but these commands did not work (both gave me strange error messages):
Code: [Select]
startx
Code: [Select]
startlxqt
can you check those error messages?
one error message was about xorg...
7. i even tried this: https://wiki.manjaro.org/index.php?title=Auto-Login_without_a_Graphical_Desktop_Manager_%26_with_Systemd
but i received the same error messages as in 6.)
« Last Edit: 24. October 2014, 01:14:09 by excalibur1234 »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #63 on: 24. October 2014, 01:25:59 »
You are very far of the intended behaviour.  :D
For startx, as usual, you must first configure properly the .xinitrc. Have you done it ?
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #64 on: 24. October 2014, 10:38:48 »
i have figured out bug #6:
this is manjaro lxqt's default ~/.xinitrc file (i am not sure about the last line, i have messed quite a bit with this file in the last 24 hours):
Code: [Select]
#!/bin/sh
# ~/.xinitrc
# Executed by startx (run your window manager from here)
export GTK2_RC_FILES="$HOME/.gtkrc-2.0"
DEFAULT_SESSION=startlxde-qt
case $1 in
   lxde-qt) exec  ck-launch-session dbus-launch startlxde-qt ;;
   *) exec ck-launch-session dbus-launch  $DEFAULT_SESSION ;;
esac
# fix pcmanfm
dbus-launch pcmanfm
exec startx
i tried to modify the last line to this:
Code: [Select]
exec startlxqt
but when i booted without sddm and logged-in in a tty, i received an error message when i typed
Code: [Select]
startx
so i deleted the entire .xinitrc file and tried the default .xinitrc (as recommended in the arch wiki):
Code: [Select]
#!/bin/sh
# ~/.xinitrc
if [ -d /etc/X11/xinit/xinitrc.d ]; then
  for f in /etc/X11/xinit/xinitrc.d/*; do
    [ -x "$f" ] && . "$f"
  done
  unset f
fi
exec startlxqt
with this .xinitrc file, i was able to log-in without sddm and type "startx" without any error message. my lxqt started. i could use pcmanfm without any noticeable problem.
so, what is that code (i deleted) in .xinitrc for?
why did it cause an error message?
is the pcmanfm fix still necessary (if yes, i would run it in the background)?
edit: with this new .xinitrc bug #7 is solved, too. i just tried it and it works beautifully.
edit2: i uninstalled and reinstalled kernel 3.17.1. it seems to work again (because i reinstalled it or because i use the default .xinitrc file). just to let you know.
« Last Edit: 24. October 2014, 11:14:19 by excalibur1234 »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #65 on: 24. October 2014, 12:28:55 »
I only did tries with startx at the begin of lxqt. After a lot of tries of login manager, I choosed sddm.
A the same time, there was a hesitation in the team between sddm and lightdm but sddm has win.
So, it's old, the use of startx. If I remember well, I had a .xinitrc with only exec startlxqt or exec lxqt-session, nothing else.
startlxqt is a script, have a look on it ?
« Last Edit: 24. October 2014, 12:31:20 by Esclapion »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #66 on: 24. October 2014, 12:56:04 »
You can also try autologin using THIS.
« Last Edit: 24. October 2014, 13:48:36 by Esclapion »
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #67 on: 24. October 2014, 13:46:41 »
You can alsi try autologin using THIS.
i have tried it, but it did not work.
however, it works when my .xinitrc file looks like this:
Code: [Select]
#!/bin/sh
# ~/.xinitrc
  done
  unset f
fi
exec startlxqt
you need the "exec startlxqt" at the bottom, otherwise "startx" and autologin does not work.
i prefer to use "exec startlxqt" instead of "exec lxqt-session", because the arch wiki says so: https://wiki.archlinux.org/index.php/Lxqt#Manually
i will probably upate the wiki page later.
edit: i have edited and updated the wiki page: https://wiki.manjaro.org/index.php?title=Auto-Login_without_a_Graphical_Desktop_Manager_%26_with_Systemd
i have added an additional wiki page: https://wiki.manjaro.org/index.php?title=Proper_~/.xinitrc_File
« Last Edit: 24. October 2014, 17:36:02 by excalibur1234 »
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #68 on: 24. October 2014, 13:59:48 »
i found more bugs:
8. this happens a lot in juffed (the text editor) but it sometimes happens on the panel, too (when i want to click on y minimized window icon).
with a probability of about 30% when i want to save a file and i move my mouse cursor to "file" --> "save file". when my mouse cursor crosses the "recent documents", it looses focus. i am unable to click "save file". i have to click "file" --> "save file" again before i can save my file/document.
when i want to enlarge/maximize a minimized window and i click the icon in the lxqt-panel, my mouse click does not get registered (or my mouse pointer looses focus). i have to move my mouse pointer a little bit and click the icon again. then, it works.
this is probably a bug in lxqt, but it would help to know, whether other people experience the same bug (then, i can file a bug report).
9. i have otter-browser installed. when i open/start otter-browser it always opens a webpage "http:/" (obviously, this is not a proper webpage). i tried to delete all config files of otter-browser in ~/.config/otter, but i still have this bug.
is this a bug of otter-browser or is it related to manjaro lxqt?
« Last Edit: 24. October 2014, 14:01:44 by excalibur1234 »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #69 on: 24. October 2014, 15:02:29 »
8) juffed is not a part of lxqt, it's only a recommanded application. To see...
9) how do you run otter-browser. Try to run it from the command line or from the menu, I think it will work (a prob of xdg-open). If it works, do a shortcut directly to otter-browser (not to the default browser) in the taskbar.
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #70 on: 25. October 2014, 01:57:18 »
about 8 ) : it does not happen only in juffed. it happens on the panel icons, too. it bothers me more when it happens on the panel, because i know i can use another text editor, but i cannot use another panel.
i found another bug:
10. when you open the hotkey settings, you can see every hotkey twice. it does not affect hotkeys and their functionality, but it looks strange.
« Last Edit: 26. October 2014, 16:22:17 by excalibur1234 »
Offline petrea
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: lxqt
  • GPU Card: Intel HD 4400
  • GPU driver: non-free
  • Kernel: 3.14-x64
  • Skill: Novice
« Reply #71 on: 26. October 2014, 07:40:38 »
Please run the command like this:
"sudo journalctl -r"
Run this before and after connecting the phone.
Before:
Code: [Select]
[root@timotin timotin]# journalctl -r
-- Logs begin at Sun 2014-10-19 12:29:21 EEST, end at Sun 2014-10-26 11:48:08 EET. --
Oct 26 11:48:08 timotin connmand[224]: wlan0 {newlink} index 3 operstate 6 <UP>
Oct 26 11:48:08 timotin connmand[224]: wlan0 {newlink} index 3 address 00:15:AF:94:0E:8B mtu 1500
Oct 26 11:48:08 timotin connmand[224]: wlan0 {TX} 47565 packets 4535686 bytes
Oct 26 11:48:08 timotin connmand[224]: wlan0 {RX} 85204 packets 122510751 bytes
Oct 26 11:48:08 timotin connmand[224]: eth0 {newlink} index 2 operstate 2 <DOWN>
Oct 26 11:48:08 timotin connmand[224]: eth0 {newlink} index 2 address 00:22:15:4A:3E:C4 mtu 1500
Oct 26 11:48:08 timotin connmand[224]: lo {newlink} index 1 operstate 0 <UNKNOWN>
Oct 26 11:48:08 timotin connmand[224]: lo {newlink} index 1 address 00:00:00:00:00:00 mtu 65536
Oct 26 11:48:05 timotin su[5166]: pam_unix(su:session): session opened for user root by (uid=1000)
Oct 26 11:48:05 timotin su[5166]: (to root) timotin on pts/0
Oct 26 11:48:05 timotin lxqt-panel[715]: execAction "/usr/share/applications/gksu.desktop"
Oct 26 11:48:02 timotin pcmanfm-qt[711]: delete FolderModel
Oct 26 11:48:02 timotin pcmanfm-qt[711]: delete CachedFolderModel
Oct 26 11:48:02 timotin pcmanfm-qt[711]: delete ProxyFolderModel
Oct 26 11:48:02 timotin pcmanfm-qt[711]: delete TabPage
Oct 26 11:48:01 timotin lxqt-powermanagement[804]: "<?xml version='1.0' standalone='no'?>
                                                   <!DOCTYPE svg PUBLIC '-//W3C//DTD SVG 1.1//EN' 'http://www.w3.org/Graphics/SVG/1.1/DTD/svg11
                                                   <svg xmlns='http://www.w3.org/2000/svg'  version='1.1' viewBox='0 0 210 210'>
                                                       <circle cx='100' cy='100' r='100' fill='rgb(210,210,210)' stroke-width='0'/>
                                                       <circle cx='100' cy='100' r='55' fill='rgb(255,255,255)' stroke-width='0'/>
                                                       <g fill-rule='evenodd' fill='rgb(40,200,40)' stroke-width='0'>
                                                           <path d='M 100,0 A 100,100 0 0,0 41,181 L 65,149 A 60,60 0 0,1 100,40 z'/>
                                                       </g>
                                                       <path d='M 60,100 h 80' stroke='black' stroke-width='20' />
                                                   </svg>
Oct 26 11:48:01 timotin lxqt-powermanagement[804]: Angle: 4.08407
Oct 26 11:48:01 timotin lxqt-powermanagement[804]: BatteryChanged discharging: true chargeLevel: 40 powerlow: false actionTime: QTime("")
Oct 26 11:48:01 timotin lxqt-powermanagement[804]: props: QMap(("Capacity", QVariant(double, 100) ) ( "Energy" ,  QVariant(double, 17.472) ) (
Oct 26 11:47:59 timotin pcmanfm-qt[711]: finish-loading
Oct 26 11:47:58 timotin connmand[224]: wlan0 {newlink} index 3 operstate 6 <UP>
Oct 26 11:47:58 timotin connmand[224]: wlan0 {newlink} index 3 address 00:15:AF:94:0E:8B mtu 1500
Oct 26 11:47:58 timotin connmand[224]: wlan0 {TX} 47564 packets 4535600 bytes
Oct 26 11:47:58 timotin connmand[224]: wlan0 {RX} 85191 packets 122505821 bytes
Oct 26 11:47:58 timotin connmand[224]: eth0 {newlink} index 2 operstate 2 <DOWN>
Oct 26 11:47:58 timotin connmand[224]: eth0 {newlink} index 2 address 00:22:15:4A:3E:C4 mtu 1500
lines 1-37
After:
Code: [Select]
-- Logs begin at Sun 2014-10-19 12:29:21 EEST, end at Sun 2014-10-26 11:57:31 EET. --
Oct 26 11:57:31 timotin lxqt-powermanagement[804]: "<?xml version='1.0' standalone='no'?>
                                                       <g fill-rule='evenodd' fill='rgb(120,160,40)' stroke-width='0'>
                                                           <path d='M 100,0 A 100,100 0 0,0 5,131 L 43,119 A 60,60 0 0,1 100,40 z'/>
                                                       </g>
                                                   </svg>
Oct 26 11:57:31 timotin lxqt-powermanagement[804]: Angle: 3.45575
Oct 26 11:57:31 timotin lxqt-powermanagement[804]: BatteryChanged discharging: true chargeLevel: 30 powerlow: false actionTime: QTime("")
Oct 26 11:57:31 timotin lxqt-powermanagement[804]: props: QMap(("Capacity", QVariant(double, 100) ) ( "Energy" ,  QVariant(double, 13.104) ) (
Oct 26 11:57:28 timotin connmand[224]: wlan0 {newlink} index 3 operstate 6 <UP>
Oct 26 11:57:28 timotin connmand[224]: wlan0 {newlink} index 3 address 00:15:AF:94:0E:8B mtu 1500
Oct 26 11:57:28 timotin connmand[224]: wlan0 {TX} 48014 packets 4595242 bytes
Oct 26 11:57:28 timotin connmand[224]: wlan0 {RX} 87339 packets 125150536 bytes
Oct 26 11:57:28 timotin connmand[224]: eth0 {newlink} index 2 operstate 2 <DOWN>
Oct 26 11:57:28 timotin connmand[224]: eth0 {newlink} index 2 address 00:22:15:4A:3E:C4 mtu 1500
Oct 26 11:57:28 timotin connmand[224]: lo {newlink} index 1 operstate 0 <UNKNOWN>
Oct 26 11:57:28 timotin connmand[224]: lo {newlink} index 1 address 00:00:00:00:00:00 mtu 65536
Oct 26 11:57:20 timotin su[5419]: pam_unix(su:session): session opened for user root by (uid=1000)
Oct 26 11:57:20 timotin su[5419]: (to root) timotin on pts/0
Oct 26 11:57:19 timotin lxqt-panel[715]: execAction "/usr/share/applications/gksu.desktop"
Oct 26 11:57:18 timotin connmand[224]: wlan0 {newlink} index 3 operstate 6 <UP>
Oct 26 11:57:18 timotin connmand[224]: wlan0 {newlink} index 3 address 00:15:AF:94:0E:8B mtu 1500
Oct 26 11:57:18 timotin connmand[224]: wlan0 {TX} 48013 packets 4595156 bytes
Oct 26 11:57:18 timotin connmand[224]: wlan0 {RX} 87335 packets 125148136 bytes
Oct 26 11:57:18 timotin connmand[224]: eth0 {newlink} index 2 operstate 2 <DOWN>
Oct 26 11:57:18 timotin connmand[224]: eth0 {newlink} index 2 address 00:22:15:4A:3E:C4 mtu 1500
Oct 26 11:57:18 timotin connmand[224]: lo {newlink} index 1 operstate 0 <UNKNOWN>
Oct 26 11:57:18 timotin connmand[224]: lo {newlink} index 1 address 00:00:00:00:00:00 mtu 65536
Oct 26 11:57:08 timotin connmand[224]: wlan0 {newlink} index 3 operstate 6 <UP>
Oct 26 11:57:08 timotin connmand[224]: wlan0 {newlink} index 3 address 00:15:AF:94:0E:8B mtu 1500
Oct 26 11:57:08 timotin connmand[224]: wlan0 {TX} 48011 packets 4595008 bytes
lines 1-37
Acer Aspire V7 582P i5 256 SSD
Offline samigina
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: LXQT and Gnome
  • GPU Card: AMD Apu A4
  • GPU driver: Non-free
  • Kernel: The latest one!
« Reply #72 on: 26. October 2014, 15:29:01 »
Before:
Code: [Select]
                                                       </g>
                                                   </svg>
lines 1-37
After:
Code: [Select]
                                                       </g>
                                                   </svg>
lines 1-37
You need to run them as sudo so we can see the kernel log. Maybe you should open a new thread to debug this issue? We are kidnapping the Esclapion thread.
Offline petrea
  • Branch: stable
  • Desktop: lxqt
  • Kernel: 3.14-x64
  • Skill: Novice
« Reply #73 on: 26. October 2014, 18:43:03 »
I  ran  them as sudo, using root  terminal.
Offline petrea
  • Branch: stable
  • Desktop: lxqt
  • Kernel: 3.14-x64
  • Skill: Novice
« Reply #74 on: 23. November 2014, 12:22:54 »
Now that I have a new Aspire 582p, I tried to see how it works with latest manjaro lxqt. Sadly there is no sound. And wifi connection works only with non-free drivers. I really want to install it as my main system, but I am afraid it will be unusable. Also touch support is really poor. I like its speed but I wish to see soon a reliable manjaro-lxqt.
