Author Topic: ISO LXQt 0.8 64 bits & 32 CD-Size released (to test)  (Read 9519 times)
gingermatty
  • Guest
Re: ISO LXQt 0.8 64 bits released (to test)
« Reply #15 on: 16. October 2014, 15:30:06 »
Thanks for the updated ISO, I will download it now and report back if there are any problems. :)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
Re: ISO LXQt 0.8 64 bits & 32 CD-Size released (to test)
« Reply #16 on: 16. October 2014, 21:02:13 »
ISO 32 bits uploaded, see the OP.  ;)
In VBox, it starts in almost 5" on my PC.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Orajnam
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: Nvidia GTX 750 Ti
  • GPU driver: non-free 352
  • Kernel: Linux44 x64
  • Skill: Intermediate
« Reply #17 on: 19. October 2014, 02:34:20 »
Recommanded use is :
Alt + Prt Screen + S -> Synchronize the file system
Alt + Prt screen + U -> try to remoUnt all file systems read-only
Alt + Prt Screen + B -> reBoot
I learned it as: Raising Skinny Elephants Is Utterly Boring
Quote
unRaw      (take control of keyboard back from X),
Sync     (flush data to disk),
tErminate (send SIGTERM to all processes, allowing them to terminate gracefully),
kIll      (send SIGKILL to all processes, forcing them to terminate immediately),
Unmount  (remount all filesystems read-only),
reBoot
From Wikipedia - Magic SysRq key
Offline linux_dream
    • My blog
  • Branch: Stable
  • Desktop: xfce
  • GPU Card: Intel
  • GPU driver: free
  • Kernel: linux40-x64
  • Skill: Novice
« Reply #18 on: 19. October 2014, 04:14:32 »
I tested the 64 bits version on my desktop pc (Intel core 2 duo E6300 at 1.86 Ghz, graphics card Geforce 7300 GS). I chose the non free drivers and I think all worked fine, except that the resolution of my screen is slightly less than the one I have under Lubuntu (I also use the non free drivers there), no idea why.
Very beautiful and fast DE.
I would have to get used to the programs though, but that's really no big deal.
If I had to wipe out my Lubuntu, I would do it for Manjaro lxqt I think.
Offline samigina
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: LXQT and Gnome
  • GPU Card: AMD Apu A4
  • GPU driver: Non-free
  • Kernel: The latest one!
« Reply #19 on: 19. October 2014, 05:26:06 »
Im having problems with connman and my laptop wifi. It doesnt show any network, when trying to connect from the commandline i get:
error: 'No carrier' First enable wifi with 'connmanctl enable wifi'
And running 'connmanctl enable wifi': wifi already on
Offline petrea
  • Branch: stable
  • Desktop: lxqt
  • GPU Card: Intel HD 4400
  • Kernel: 3.14-x64
  • Skill: Novice
« Reply #20 on: 19. October 2014, 10:40:19 »
Yes, it's beautiful now, and faster, but still there are many problems to solve.
 - No Android connection.
 - Time and date changing doesn't work. I need to change it because after installing,  it didn't select time zone and time correctly. In Live session it set my timezone and time correctly.
 - Wi-fi icon disappears.
 - I was unable to put .Xmodmap in autostart.
« Last Edit: 19. October 2014, 10:43:16 by petrea »
Acer Aspire V7 582P i5 256 SSD
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #21 on: 19. October 2014, 11:09:58 »
You must use cmst ? The icon is in the tray icon. On my PC, I get :
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #22 on: 19. October 2014, 11:12:53 »
Quote
When exactly ? You must click on Minimize. If you click on Exit, it disappears, but come back after 1".
Offline Zileene
  • Held Mitglied
  • Branch: Stable
  • Desktop: awesomeWM,Gnome
  • GPU Card: various
  • GPU driver: the one that works
  • Kernel: 4.1
« Reply #23 on: 19. October 2014, 12:57:02 »
Ooh, a new flavour to taste.  ;D
It's actually REISUB. Always better to do term and kill before flushing the cache and files via sync. ;)
That would make it "Raising Elephants Is So Utterly Boring".
(I prefer the other mnemonic: "Reboot Even If System Utterly Broken") :P
Have Fun! ^-^
Z.
While I may not always have the correct solution, my input could lead you in the right direction...
If you don't know what a command does, then type 'man <command>' or '<command> --help' to find out.
Offline samigina
  • Jr. Mitglied
  • Branch: Stable
« Reply #24 on: 19. October 2014, 16:04:10 »
Already tried that wifi seems to be enabled but there no networks to connect.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #25 on: 19. October 2014, 16:05:23 »
and it works with another system ? It can be an hardware switch.
Offline samigina
  • Jr. Mitglied
  • Branch: Stable
« Reply #26 on: 19. October 2014, 16:41:02 »
I works fine in Ubuntu and Manjaro XFCE.
It finally worked, enabling from terminal, then disabling from Fn key, and enabling again with Fn key. Strange, but it worked.
« Last Edit: 19. October 2014, 17:02:55 by samigina »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #27 on: 19. October 2014, 17:15:58 »
It's a laptop, I think.
Offline samigina
  • Jr. Mitglied
  • Branch: Stable
« Reply #28 on: 19. October 2014, 17:33:48 »
Yea, it is a laptop. And the sound just work with Pulseaudio.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #29 on: 19. October 2014, 17:38:02 »
Maybe I will add pulseaudio in the next ISO. But a lot of people uninstall it.
