Author Topic: How do I start a program that is installed but does not show in the menu?  (Read 5450 times)
Offline wuftanoz
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
  • GPU Card: ATi
  • GPU driver: free
  • Kernel: linux 3.10.54-1 x64
  • Skill: Novice
Just installed a program succesfully that I can't find in any of the menu's.
So what do I do?
Thanks for your tips  :-*
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
  • Skill: Intermediate
It would help if you told us what program it is....
You could launch it from the Run dialogue.
You could launch it from the cli/shell.
You could create a '.desktop' entry for the app and it will appear in your menu.
Offline darso
  • Held Mitglied
  • Keep 'er between the hedges!
  • Branch: OpenRC-Stable
  • Desktop: OpenBox+XFCE
  • GPU Card: nVidia GT610
  • GPU driver: non-free
  • Kernel: linux43-x64
  • Skill: Novice
Hi wuftanoz, pressing ALT+F2 brings you up a run menu, from there you can type the program name and press return or if know the path to it you can create a shortcut to the program.
To find the path I bring up the package manager, do a search for the application and you can find it under the "files" tab, there may be an easier way, if someone would like to elaborate even I would appreciate it
Cheers,
darso.
EDIT: Cheers mips, you got in there just before me.  ;D
It must be difficult... for those who have taken authority as the truth, rather than truth as the authority.
-G. Massey, Egyptologist.
Linux Counter Reg Number #578558
Offline wuftanoz
  • Jr. Mitglied
  • Branch: stable
  • Desktop: xfce
  • GPU Card: ATi
  • GPU driver: free
  • Skill: Novice
Thank you for your answers.
 8)
It's very helpful!
Offline darso
  • Held Mitglied
  • Skill: Novice
You're welcome
EDIT: Sorry for the "windoze speak" "shortcut" sheesh  :-[
Offline charlesay
  • Vollwertiges Mitglied
  • Branch: unstable
  • Desktop: Xfce / Gnome
  • GPU Card: integrated intel
  • GPU driver: free
  • Kernel: 3.18
  • Skill: Novice
also, in xfce: if you type the name of a newly installed programme that isn't listed in the whisker menu, it will suggest to run 'program' too.
Offline Jonathan
  • Held Mitglied
  • Branch: testing
  • Desktop: Cinnamon
  • GPU Card: ATI Mobility Radeon HD 4330/4350/4550
  • GPU driver: free
  • Kernel: 3.18.0-1-mainline
If you want to quickly know the path - for putting it into a .desktop file for instance,
you can use:
Code: [Select]
which your_programs_name
Offline darso
  • Held Mitglied
  • Skill: Novice
Cheers Jonathon, I didn't know about that one and I forgot about that one of yours charlesay  :-[ see, I knew you all would enlighten us  ;D
Cheers,
darso.
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Branch: stable, unstable
  • Desktop: Xfce
  • GPU Card: GTX780/HD3000/AMD8400
  • GPU driver: Nvidia/Intel/Catalyst
  • Kernel: latest stable+lts (64)
  • Skill: Advanced
If the program has an odd name, you can also do "pacman -Ql <package>" to see a list of files installed by the package. Binaries are usually in /usr/bin or /opt .
« Last Edit: 08. February 2015, 01:50:41 by Ayceman »
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
So what do I do?
What program did you install?
Not all programs are GUI based and/or have menu entries for them.
Offline Fatboy
  • Sr. Mitglied
  • "Spiral out. Keep going..."
  • Branch: stable
  • Desktop: Xfce, KDE plasma 5
  • GPU Card: nVidia GeForce 210
  • GPU driver: 340.xx
  • Kernel: Manjaro Kernel 4.4 LTS
You can always use MenuLibre to "create a new launcher" thus creating a launcher for the program in the whisker menu. And yes, it would help if you told us what the program is called.haha.
Goodluck
"I'm reaching for the random or whatever will bewilder me. Whatever will bewilder me."
