Author Topic: Binary repos for lxqt moved to sourceforge  (Read 2083 times)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« on: 30. August 2014, 14:38:07 »
Hi all  :)
The old repos are always available, but no more maintained.
The new repos are located here :
Code: [Select]
[repolxqt]
SigLevel = Optional TrustAll
Server = https://sourceforge.net/projects/repolxqt/files/$arch/
so, to change in you pacman.conf;)
They are Q5 repos, of course.
« Last Edit: 15. September 2014, 00:58:53 by Esclapion »
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Gnome 3.20x
  • GPU Card: Intel HD4400
  • GPU driver: free
  • Kernel: 4.4.5-1-ARCH
  • Skill: Intermediate
Re: Binary repos for lxqt moved to sourceforge
« Reply #1 on: 23. September 2014, 22:54:05 »
I never even payed attention that you have made binary repos. I yesterday lost my nerves when compiling from aur with in virtualbox for Antergos base-install and then forgot my rooot password (or some such bug there was >:D) but now from binaries with better luck
 O:-)
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Desktop: LXQT/Plasma5, openrc & eudev
  • Kernel: x86_64
  • Skill: Advanced
« Reply #2 on: 07. October 2014, 00:41:27 »
I wondered if you could introduce in pkgbuilds
Code: [Select]
groups=('lxqt')
PS: You could get rid of the meta package, and fine tune with something like this...
Code: [Select]
groups=('lxqt' 'lxqt-minimal')
« Last Edit: 07. October 2014, 00:46:16 by artoo »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #3 on: 07. October 2014, 00:47:29 »
It would be to be decided by J. Leclanché.
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
« Reply #4 on: 07. October 2014, 01:39:07 »
I see, but its easily implemented for git builds, as they won't change much.
The repo wouldn't care where the pkgbuild came from.
I assumed its your pkgbuilds you use for repo.  ;)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #5 on: 07. October 2014, 01:43:12 »
Quote
No more now. When possible, I use the officials.
(edit)
JLeclanché uses Manjaro  ;D, so he did packages for AUR.
« Last Edit: 07. October 2014, 01:46:25 by Esclapion »
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #6 on: 08. October 2014, 12:58:00 »
to sum up all my knowledge about lxqt packaging (please correct me, if i am wrong):
- JLeclanché is the package (= PKGBUILD) maintainer of all lxqt packages in the AUR.
- esclapion maintains a lxqt repository (actually 2, but one is outdated):
Code: [Select]
[repolxqt]
esclapion compiles all lxqt AUR packages every once in a while and uploads them to this repository.
- there is another lxqt repository available: https://wiki.archlinux.org/index.php/Unofficial_user_repositories#lxqt-git
Code: [Select]
[lxqt-git]
Server = http://repo.stobbstechnical.com/$arch
it is almost the same as esclapion's repository, but maintained by another guy.
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #7 on: 08. October 2014, 15:46:07 »
Yes, but we were a lot before. This repo is a new one, I didn't knew it.
Please don't mix both, or it will probably be some conflicts.
