Author Topic: Flux box snap to edges [quarter of a screen size]  (Read 2066 times)
Offline bokiscout
  • Jr. Mitglied
  • Branch: Stable + AUR
  • Desktop: KDE
  • GPU Card: nVidia GTX 560
  • GPU driver: non-free
  • Kernel: 3.18 LTS
  • Skill: Novice
« on: 24. August 2014, 14:52:08 »
I have never being using Fluxbox before.
I'm trying different DE at the moment and found out that KDE have two superb features, to put two different applications in same window (as a tab, fluxbox have this to) and to snap to one quarter of a screen or half of a screen  depending where (on the edge) you drag the window.
If Fluxbox have this feature I will give it a try, otherwise will try to run KDE as light as possible.
Saying that Java is good because it works on every OS is like saying that anal sex is good because it works on every gender.
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
  • Skill: Intermediate
Re: Flux box snap to edges [quarter of a screen size]
« Reply #1 on: 24. August 2014, 15:35:00 »
Fluxbox does support snapping, I'm just not sure to what extent.
See http://daleswanson.blogspot.com/2014/01/snapping-windows-to-half-screen-in.html for some ideas.
Also read the fluxbox man page.
Offline bokiscout
  • Jr. Mitglied
  • Desktop: KDE
  • Kernel: 3.18 LTS
  • Skill: Novice
« Reply #2 on: 24. August 2014, 16:55:47 »
I have read that.
Actually this is what I'm asking for, is it possible to do the same (snap - shrink - place window to exactly one quarter of the screen size) with snapping to edge instead of pressing key combination.
Offline pjhalsli
  • Held Mitglied
  • Too old to know better - Still too young to care
  • Branch: Arch
  • Desktop: i3 - Awesome
  • Kernel: 3.16.1-1-ARCH
  • Skill: Novice
« Reply #3 on: 24. August 2014, 17:08:32 »
Does K support tabbing windows together?
I thought that was just an flux/pek thing
Please take the time to fill out your profile. This will make it much easier for those who are trying to help you.
If you don't know which skill level - you are a novice :)
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • Kernel: 3.16
« Reply #4 on: 24. August 2014, 19:08:38 »
I have read that.
I'' install FB tonight some time and let you know tomorrow if that's ok.
Offline bokiscout
  • Jr. Mitglied
  • Desktop: KDE
  • Kernel: 3.18 LTS
  • Skill: Novice
« Reply #5 on: 24. August 2014, 19:09:59 »
Thank you.
If K = KDE, then yes.
Offline dicktater
  • Held Mitglied
  • Skill: Novice
« Reply #6 on: 24. August 2014, 19:39:06 »
LXQt - KDE as light as possible?  ;)
https://forum.manjaro.org/index.php?board=20.0
The Manjaro Forum Revised Rules  How to Report Issues Properly   Please Read the Manjaro Wiki
Offline Zileene
  • Held Mitglied
  • Branch: Stable
  • Desktop: awesomeWM,Gnome
  • GPU Card: various
  • GPU driver: the one that works
  • Kernel: 4.1
« Reply #7 on: 28. August 2014, 16:46:03 »
While you're DE/WM hopping, do give the Awesome WM spin a try.
You might like it.  :P
Have Fun! ;D
Z.
While I may not always have the correct solution, my input could lead you in the right direction...
If you don't know what a command does, then type 'man <command>' or '<command> --help' to find out.
Offline tourada
  • Vollwertiges Mitglied
  • ManjaroPek Team
  • Branch: Testing
  • Desktop: ManjaroPek
  • GPU Card: nVidia GTX 750 Ti
  • GPU driver: Free
  • Kernel: Linux-3.14-x86_64
« Reply #8 on: 28. August 2014, 16:59:02 »
I've been DE/WM hopping around all week for fun. Trying out PekWM later today, now I want to try out awesomeWM. Good thing I have a 4-day weekend to play around!
Offline flippy
  • AKA "day|flip" manjaro irc
  • Branch: Testing
  • Desktop: xmonad & bspwm
  • GPU Card: nVidia GeForce GTX 550 Ti
  • GPU driver: Nvida
  • Kernel: Got 64?
« Reply #9 on: 29. August 2014, 15:26:33 »
http://forums.gentoo.org/viewtopic-t-790327.html
I been testing this out on lxqt with fluxbox as my main wm.  Scroll down to freitass and lyallp. Both of these work. Just need to play around with size of your screen. So take screenshot and do the math. W/2 and H/2.  :P
Good Luck ;D
« Last Edit: 29. August 2014, 16:32:47 by flippy »
