Author Topic: Is there a way to make the openbox menu bigger ?  (Read 3549 times)
Offline t101
  • Vollwertiges Mitglied
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Nvidia GeForce GTX 650
  • GPU driver: Non Free 343.36
  • Kernel: 3.19.1-1-MANJARO
  • Skill: Novice
« on: 23. August 2014, 18:24:45 »
Hi,
Recently I switched from LXQT to openbox. All seems fine, the only problem is the obmenu is appearing too small coz my monitor is positioned slightly far away from me.
How do I make the obmenu bigger ?
The loneliest people are the kindest. The saddest people smile the brightest. The most damaged people are the wisest.
Offline Halcyon
  • Jr. Mitglied
  • Branch: Arch Linux
  • Desktop: pekwm, awesome
  • GPU Card: Nvidia GeForce 8600M GT
  • GPU driver: non-free
  • Kernel: linux318-x64
  • Skill: Intermediate
Re: Is there a way to make the openbox menu bigger ?
« Reply #1 on: 23. August 2014, 18:31:46 »
Yes!
open .config/openbox/rc.xml with your favorite text editor and find this line:
Code: [Select]
<font place="MenuItem">
      <name>sans</name>
      <size>9</size>
      <!-- font size in points -->
      <weight>normal</weight>
      <!-- 'bold' or 'normal' -->
      <slant>normal</slant>
      <!-- 'italic' or 'normal' -->
Change the "9" to whatever font size you want, and your menu will get bigger once you reconfigure openbox or restart.
I'm So Meta, Even This Acronym...
Offline dicktater
  • Held Mitglied
  • Skill: Novice
« Reply #2 on: 23. August 2014, 18:54:59 »
That's what I was thinking. Doesn't obconf make that and other modifications easier?
http://openbox.org/wiki/ObConf:About
The Manjaro Forum Revised Rules  How to Report Issues Properly   Please Read the Manjaro Wiki
Offline t101
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #3 on: 23. August 2014, 19:13:09 »
I used obconf. Changed Menu header and Menu item to 16.
Offline Halcyon
  • Jr. Mitglied
« Reply #4 on: 23. August 2014, 19:33:31 »
Awesome.  I didn't know you could do that with obconf. I'm just so used to editing the xml and text files. Glad you found a simpler way!
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
« Reply #5 on: 23. August 2014, 21:28:55 »
OR...you could just right-click, Settings>Openbox Configuration Manager>Appearance, and change the font size(s) there.
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline Halcyon
  • Jr. Mitglied
« Reply #6 on: 24. August 2014, 00:07:45 »
I think that's the same application.
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
« Reply #7 on: 24. August 2014, 00:19:43 »
All you have to do is change your font size ;)
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #8 on: 24. August 2014, 02:27:07 »
Yep. Just the GUI way of doing it. :)
That's correct. But changing the font size of the theme under Customize Look and Feel does not change the default sizes of the Menu font. :)
Offline Halcyon
  • Jr. Mitglied
« Reply #9 on: 24. August 2014, 02:36:04 »
Indeed. "Customize Look and Appearance" is a link to lxappearance, whereas "Openbox Configuration Manager" is a link to obconf.
