Author Topic: [2014-07-23] New ISO Lxqt-Qt5 available for testing  (Read 7058 times)
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
  • Skill: Intermediate
Re: [2014-07-23] New ISO Lxqt-Qt5 available for testing
« Reply #15 on: 24. July 2014, 00:23:39 »
If you are german, I need the translation for the 2 pcmanfm actions  ;)
Name[en]=Edit as Root
Name[de]=als Root bearbeiten
Name[en]=Set As Wallpaper
Name[de]=als Hintergrund einrichten
Name[xx]=Masaüstü deseni yap         (replace "xx" with a "tr" - i cannot write it, because the forum software thinks it is a command. sorry.)
the tr translation is from qanjaro.
« Last Edit: 24. July 2014, 00:27:09 by excalibur1234 »
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline schpankme
  • Held Mitglied
  • High Carb / Low Fat / Vegan
  • Branch: Stable
  • Desktop: Qt..i3..OpenRC..Eudev
  • GPU Card: GTX 780 Ti
  • Kernel: 4.4.45-1 x64
  • Skill: Advanced
« Reply #16 on: 24. July 2014, 00:26:54 »
But less RAM consumption, less disk space, and more speed.
Yes  --  lxqt-qt5-0.8.10B -- is definitely fast!
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #17 on: 24. July 2014, 00:30:25 »
the lxqt developers have not optimized lxqt yet (as far as i know). they will do this later.
lxqt is not as lean as openbox, but it is lightest DE based on qt5. this is the great thing about it!
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #19 on: 24. July 2014, 01:10:33 »
LXQt window managing like as i3   ;)
thx for the link.
this lxqt version is definitely not very light anymore, but it looks good.
do you know how the launcher is called?
(a small windows in the middle of the screen. you can see it in the video at 0:13 - 0.14)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #20 on: 24. July 2014, 01:21:11 »
Quote
214 MB of RAM for the 64 bits installed in VBox. Not so much.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #21 on: 24. July 2014, 01:23:38 »
i meant the lxqt version in the youtube video!
it has custom theme and panel style and compositor enabled.
sorry for these off topic posts.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #22 on: 24. July 2014, 01:29:58 »
compton is heavy. You have it installed in mine, but not activated. I'm not sure it works well, but to see for the next ISO.
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #23 on: 24. July 2014, 01:31:59 »
xcompmgr is used in the video.
ref:  https://wiki.archlinux.org/index.php/xcompmgr
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #24 on: 24. July 2014, 01:47:07 »
Something found now for the ugly windows (Thus, pavucontrol). Run lxappearance from terminal, change of interface,apply, go back to Menda, apply.
Before :
After :
I will search the difference tomorrow (1H45 AM, here  ;D).
Offline petrea
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: lxqt
  • GPU Card: Intel HD 4400
  • GPU driver: non-free
  • Kernel: 3.14-x64
  • Skill: Novice
« Reply #25 on: 24. July 2014, 10:46:05 »
I'm using 32bit version. I can't connect my Android phone. Pcman is terrible: no shift+delete; I can't copy a link to a file and paste it to terminal. Otter crashes too often. Window titlebar of Skype's dialog window is missing. I can't figure out how to pin apps to panel. Suspend/hibernate  doesn't work on lid close, even if lid watcher is checked in settings. I think manjaro lxqt is fast, lightweight, but still immature.
Acer Aspire V7 582P i5 256 SSD
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Gnome 3.20x
  • GPU Card: Intel HD4400
  • GPU driver: free
  • Kernel: 4.4.5-1-ARCH
« Reply #26 on: 24. July 2014, 10:50:14 »
@Escaplion: Are you going to replace Openbox with Kwin/kwindowsystem now that it is portable?
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #27 on: 24. July 2014, 10:51:11 »
We follow the development.  ;) I will try to release the 32 bits version for this week-end.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #28 on: 24. July 2014, 11:01:04 »
Hi Lukimya,  :)
The preceeding kwin stand alone was not really standalone. Each time we wanted do something, we had to install kdebase, etc...
I know than some devs are working for integrate that to lxqt, but really standalone this time. I have no news since a moment.
That and the porting to wayland are two known goals.
Now, must we integrate that to a Manjaro, or produce an "howto" to explain what to do ? No idea, I must try it first to see the speed and the weight.
But an lxqt kwin-based would be awesome.  ^-^
Offline petrea
  • Branch: stable
  • Desktop: lxqt
  • Kernel: 3.14-x64
  • Skill: Novice
« Reply #29 on: 24. July 2014, 11:13:30 »
And one more thing: is there a way to get titleless maximised windows?
