Author Topic: Nvidia Optimus  (Read 2368 times)
Offline YFDogan
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
Nvidia Optimus
« on: 30. August 2012, 21:52:32 »
I have Dell Inspiron N5110 with Nvidia Optimus, 8 GB Ram.
Code: [Select]
[yfdogan@manjaro ~]$ lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b5)
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b5)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
00:1c.7 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 8 (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation HM67 Express Chipset Family LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108 [GeForce GT 540M] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GF108 High Definition Audio Controller (rev a1)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 05)
09:00.0 Network controller: Intel Corporation Centrino Wireless-N 1030 (rev 34)
0b:00.0 USB controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 04)
For example, with ALT-F2 and
Code: [Select]
optirun firefox firefox is working and there are some forum pages and a game ( lost bubble in facebook) are open. And the laptop is about 70-85 Celsius. Is this normal? What should I do to get the temperature down?
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
Offline Anja Noir
  • Neuling
Re: Nvidia Optimus
« Reply #1 on: 31. August 2012, 03:21:24 »
My temp stays around 46-54 C. Right now it is 50 C with room temp at 25.5 C.
Of course, my laptop is setting atop a usb fan powered base at all times...
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
Re: Nvidia Optimus
« Reply #2 on: 31. August 2012, 09:30:43 »
-Did you changed any configuration?
- Do you use 'optirun <appliacation name>' for run the applications like firefox?
Offline water spirit
  • Neuling
Re: Nvidia Optimus
« Reply #3 on: 31. August 2012, 11:05:43 »
Code: [Select]
Password:
09:00.0 Network controller: Intel Corporation Centrino Advanced-N 6230
I have same Laptop and optirun firefox and optirun vlc playing a video, my temperature is 50 to 58 celsius. I installed Manjaro KDE 64 bit.
Offline hsngrms
  • Neuling
Re: Nvidia Optimus
« Reply #4 on: 31. August 2012, 16:15:13 »
I think, your PC has i5 CPU, YFDogan's i7.
Offline Anja Noir
  • Neuling
Re: Nvidia Optimus
« Reply #5 on: 31. August 2012, 18:59:49 »
@YFDogan
Currently running Cinnamon x64 on my Asus Core i7 laptop.
I have edited /etc/conf.d/cpufreq to look like this:
Code: [Select]
#configuration for cpufreq control
# valid governors:
#  ondemand, performance, powersave,
#  conservative, userspace
governor="ondemand"
# limit frequency range (optional)
# valid suffixes: Hz, kHz (default), MHz, GHz, THz
min_freq="800MHz"
max_freq="2GHz"
# use freq to set up the exact cpu frequency using it with userspace governor
#freq=
lsmod shows 'acpi_cpufreq' is loaded which is required if using
cpufrequtils (already was installed in Cinnamon). That's it.
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
Re: Nvidia Optimus
« Reply #6 on: 01. September 2012, 09:41:47 »
Code: [Select]
min_freq="800MHz"
max_freq="2GHz"
Thank you for answer. I made the changes as you but temp. is still high.
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
Re: Nvidia Optimus
« Reply #7 on: 15. September 2012, 09:35:57 »
This is the default setting. Is it OK with bumblebee? Or need changes?
Code: [Select]
  GNU nano 2.2.6                    File: /etc/conf.d/cpufreq
# valid governors:
#governor="ondemand"
#min_freq="2.25GHz"
#max_freq="3GHz"
#freq=
Offline hsngrms
  • Neuling
Re: Nvidia Optimus
« Reply #8 on: 16. September 2012, 00:44:48 »
Code: [Select]
# valid governors:
governor="ondemand"
min_freq="800MHz"
max_freq="2GHz"
#freq=
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
Re: Nvidia Optimus
« Reply #9 on: 16. September 2012, 01:07:00 »
@hsngrms, I have i7 processor. I m not sure about change this values because they should be depends on hardware.
Or is there a standart value configuration for bumblebee ?
Offline hsngrms
  • Neuling
Re: Nvidia Optimus
« Reply #10 on: 17. September 2012, 01:55:33 »
IDK, only forwarded Anja Noir's settings for you.
