Author Topic: look of lxqt  (Read 5204 times)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
Re: look of lxqt
« Reply #15 on: 16. July 2014, 19:50:03 »
Quote
Quote
export QT_STYLE_OVERRIDE=gtk
Thx, I will verify and add it if not.
Quote
GTK+ as widget style
yep, It's what I forgot.
Quote
lxappearance-ob
thx, I will do some tries...
Quote
DarkOrangeBird
nice, yes. But in Manjaro graphic chart, they prefer green :-( I find also that Ambiance is the best, maybe except flat-dark (rudy).
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline dicktater
  • Held Mitglied
  • Skill: Novice
Re: look of lxqt
« Reply #16 on: 16. July 2014, 19:55:16 »
On openbox I use Adwaita and Adwaita-ob which I find quite nice looking... but you better like white/grey.
http://box-look.org/content/show.php/Adwaita-ob?content=162589&PHPSESSID=a08200113a7724adb57e7908dabe44b2
Cheers,
My eyes! What's the albedo of that theme? ;D
The Manjaro Forum Revised Rules  How to Report Issues Properly   Please Read the Manjaro Wiki
Offline megapop
  • Vollwertiges Mitglied
  • Wired.
    • megapop
  • Branch: stable
  • Desktop: plain xfce
  • GPU Card: nvidia 8800GT
  • GPU driver: non-free
  • Kernel: x86
  • Skill: Novice
Re: look of lxqt
« Reply #17 on: 16. July 2014, 19:55:33 »
Ah yes, of course! :) (... that was just for demonstration purposes anyway.)
« Last Edit: 16. July 2014, 20:05:12 by megapop »
return null;
Offline poker98face
  • Held Mitglied
  • Open your Source, Open your Mind
  • Branch: stable Arch
  • Desktop: KDE
  • GPU Card: ATI 5470
  • GPU driver: free
  • Kernel: 3.15 Arch
  • Skill: Intermediate
Re: look of lxqt
« Reply #18 on: 16. July 2014, 20:02:20 »
PC: Windows 7 Notebook: Arch
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
Re: look of lxqt
« Reply #19 on: 17. July 2014, 14:29:30 »
What's the best for the widget style, please ? GTK+ or Fusion ? And why ?
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
Re: look of lxqt
« Reply #20 on: 17. July 2014, 15:00:51 »
I use Fusion (and qtcurve, virtuality), but I'm almost gtk free. Since ISO will inevitably contain GTK it's better to stick with GTK because this is the only way of having a unified global style for Qts and GTKs, with mediterranian nigth for instance.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
Re: look of lxqt
« Reply #21 on: 17. July 2014, 15:04:52 »
Hmm, OK, thanks for the explanation.  :)
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
Re: look of lxqt
« Reply #22 on: 17. July 2014, 15:06:33 »
My pleasure!
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
Re: look of lxqt
« Reply #23 on: 17. July 2014, 15:46:04 »
Since ISO will inevitably contain GTK it's better to stick with GTK because this is the only way of having a unified global style for Qts and GTKs.
i kind of agree - for now.
do you think gtk2 or gtk3 or both should be kept?
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
Re: look of lxqt
« Reply #24 on: 17. July 2014, 15:51:34 »
GTK3 is used by some system utilities (cups for example) if not by any default app. Having said that there're some workarounds to have cups etc. without GTK3 and I'll hopefully soon list all these together with some other tips as a wiki.
Offline Phil67
  • Jr. Mitglied
  • Skill: Advanced
Re: look of lxqt
« Reply #25 on: 17. July 2014, 16:16:54 »
Many thanks in advance ! 8)
I'm also trying to get rid of GTK3 as much as possible.
The latest upgrade from 3.10 to 3.12 generated several bugs on my XFCE and LXDE systems without any other benefit (for my usage).
I didn't have time to investigate and tried to replace the GTK3 package (v3.12) with the GTK310 package in "extras" (and gedit310). Unfortunately this downgrade broke CUPS and I had to return back to GTK3 (3.12) and its ugly interface and side effects on several applications. >:(
I think that it would be better in the long-term for LXQT Manjaro to avoid as much as possible dependencies with GTK3 (at least for most critical applications).
« Last Edit: 17. July 2014, 16:19:37 by Phil67 »
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
Re: look of lxqt
« Reply #26 on: 17. July 2014, 16:23:51 »
You're wellcome, Phil67. … That's why the whole Linux community is in the process of abandoning GTK!!! … LXQt's long-term goal is this, I believe. And I'll focus in the wiki especially for geting rid of GTK, just as KDE without KDE and Qt-er!
Offline fassil
  • Support Team
  • Branch: stable/unstable
  • Desktop: E19/E20
  • GPU driver: free
  • Kernel: Linux314 & 318
Re: look of lxqt
« Reply #27 on: 17. July 2014, 17:29:11 »
Hi,
A bit "out of subject" (how do you say that ?), but E works like a charm without gtk3 & it's not so bad  ^-^
Ps: I don't remember my last print with my two laptops , it helps a bit, if i understand fine...
"Are you enlightened ?"
Offline PCMan
  • Neuling
  • Skill: Novice
Re: look of lxqt
« Reply #28 on: 17. July 2014, 18:46:48 »
First, using an environment var to override the style is a bad idea.
Since Qt5 qtconfig tool is gone. The style name is provided by the platform plugin.
In the case of LXQt, that's lxqt-qtplugin. Qt will ask the platform plugin for the style name.
Please use lxqt-config-appearance tool and select a style from it then everything will work automatically.
Alternatively, edit /etc/xdg/lxqt/lxqt.conf and change the default style for your distro.
I personally will recommend "Fusion" since it's light and good-looking.
If you use GTK+, you can have the same look and feel as Gtk+ programs, but the price is Gtk+ must be loaded and used to paint your Qt widgets. You get nice gtk+ styles for the Qt widgets at the cost of increased resource usage.
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
Re: look of lxqt
« Reply #29 on: 17. July 2014, 18:58:28 »
Thank you for the explanation PCMan.
As a side note, the issue with Fusion is that it's impossible to customise, no way to customise colours. Well, to be honest, even GTK3 is better in that respect. A generous soul is needed for creation of a (better) qtconfig for Qt5.
