Author Topic: Long startup time because of updatedb.service and man-db.service  (Read 12037 times)
Offline dicktater
  • Held Mitglied
  • Skill: Novice
Re: Long startup time because of updatedb.service and man-db.service
« Reply #15 on: 10. July 2014, 01:04:58 »
Svajs,
I found this dev discussion from April of this year just before you posted about your recent startup issue (for which I don't have an immediate answer. sorry). Regardless, I wanted to get this posted. There are only about 7 posts in the thread, the last has perhaps with a /etc/systemd/system/updatedb.service.d/delay.conf trick/fix (may be deprecated? i dunno).
[arch-general] On-boot delay due to timer units
https://mailman.archlinux.org/pipermail/arch-general/2014-April/035935.html
edit:
Adding this from April 28th
Quote
updatedb.service slows down boot a lot. 1min and some secs for this service ? and this is happening in every boot. WTF ? I've disabled it. Better to run manually before locate command.
https://plus.google.com/wm/1/+NikTh/posts/CDdTjixAz6W
further discussion in the comments.
« Last Edit: 10. July 2014, 01:08:33 by dicktater »
The Manjaro Forum Revised Rules  How to Report Issues Properly   Please Read the Manjaro Wiki
Offline dicktater
  • Held Mitglied
  • Skill: Novice
Offline Hadi
  • Jr. Mitglied
  • Branch: Unstable
  • Desktop: Gnome3.18
  • GPU Card: AMD Radeon 6370M
  • GPU driver: nonfree
  • Kernel: linux-319-x64
  • Skill: Novice
« Reply #17 on: 10. July 2014, 01:15:01 »
Hello guys
I have recently installed manjaro and I'm not skilled with the command line yet.
But I have also a terrible boot time.  I typed system-analyze blame and it shows me that  man.db takes about   1 minute and 40 seconds.
I'm not sure what to do....
Thanks.
Offline Svajs
  • Jr. Mitglied
  • Branch: stable
  • Desktop: Xfce+compiz+emerald
  • GPU Card: Ati HD 5830
  • GPU driver: non-free
  • Kernel: linux316-x64
  • Skill: Intermediate
« Reply #18 on: 10. July 2014, 10:12:53 »
I'll add any other links that may be relevant to your boot issue to this post as I find them.
https://forum.manjaro.org/index.php?topic=7925.msg69960#msg69960
https://forum.manjaro.org/index.php?topic=6005.msg52611#msg52611
Thank you very much! I chrooted from livecd and reinstalled drivers:
Code: [Select]
mhwd -li --pci
mhwd -r pci video-catalyst
mhwd -a pci nonfree 0300
mhwd-gpu --setgl catalyst
And now I can boot into my system again.
Now I can go back to my original slow boot issue.
UPDATE: I'm booting very fast now that I installed linux315, but can't confirm anything just yet, will have to wait a few more days.
« Last Edit: 10. July 2014, 10:25:45 by Svajs »
Offline dicktater
  • Held Mitglied
  • Skill: Novice
« Reply #19 on: 10. July 2014, 10:33:13 »
Code: [Select]
mhwd -li --pci
Good! If you confirm your problems have been solved after testing, please make a final remark and mark this thread SOLVED.
Thanks.
Offline Svajs
  • Jr. Mitglied
  • Branch: stable
« Reply #20 on: 10. July 2014, 11:45:54 »
Thanks.
Sure thing! Thank you everyone for quick responses.
Offline Svajs
  • Jr. Mitglied
  • Branch: stable
« Reply #21 on: 11. July 2014, 08:53:11 »
Unfortunately, still not fixed after update pack and new kernel.
Code: [Select]
$ systemd-analyze blame
1min 35.285s man-db.service
1min 22.953s updatedb.service
Offline dicktater
  • Held Mitglied
  • Skill: Novice
« Reply #22 on: 13. July 2014, 11:18:46 »
Code: [Select]
Which kernels do you have installed? Was this 'systemd-analyze blame' after the first boot after the update? Maybe check again after a couple more boots.
What login manager are you using? I had issues with 0.8.10 xcfe on one machine after the very first update with an inexplicable ~60 second delay. After struggling with it for a while, I dumped MDM for SLiM and it boots almost as fast as I think it should be.
Offline Verändert2.0
  • Held Mitglied
  • Ni Dieu ni maître
  • Skill: Novice
« Reply #23 on: 13. July 2014, 11:54:14 »
Just restart a few times. This should at least fix that man.db problem.
Offline FadeMind
  • Support Team
    • gravatar
  • Branch: Arch x86_64
  • Desktop: Plasma 5
  • GPU Card: Intel + NVIDIA
  • GPU driver: Intel + NVIDIA
  • Kernel: linux
« Reply #24 on: 13. July 2014, 12:03:36 »
There is something in this. My results from today morning startup:
Code: [Select]
[tomasz@manjaro ~]$ systemd-analyze blame
    1min 13.679s updatedb.service
    1min 12.920s man-db.service
         18.897s NetworkManager.service
          9.152s cups.service
          7.362s bluetooth.service
          5.516s thermald.service
          3.804s logrotate.service
          3.786s ufw.service
          2.120s lm_sensors.service
          1.988s alsa-restore.service
          1.939s systemd-logind.service
          1.914s rpcbind.service
          1.761s user@1000.service
          1.595s systemd-vconsole-setup.service
          1.422s systemd-remount-fs.service
          1.281s sys-kernel-debug.mount
          1.261s dev-hugepages.mount
          1.260s dev-mqueue.mount
          1.229s tmp.mount
          1.035s keyboardctl.service
           853ms systemd-modules-load.service
           831ms shadow.service
           754ms tlp.service
           705ms polkit.service
           495ms systemd-udev-trigger.service
           481ms rtkit-daemon.service
           426ms systemd-tmpfiles-setup-dev.service
           396ms sys-kernel-config.mount
           371ms home.mount
           290ms ntpd.service
           260ms systemd-rfkill@rfkill3.service
           256ms dev-disk-by\x2duuid-f20111de\x2d986f\x2d471b\x2d84e2\x2dc46c161e5f13.swap
           252ms kmod-static-nodes.service
           202ms systemd-rfkill@rfkill1.service
           179ms upower.service
           178ms udisks2.service
           150ms systemd-user-sessions.service
           136ms systemd-rfkill@rfkill0.service
           136ms systemd-tmpfiles-setup.service
           112ms wpa_supplicant.service
           104ms systemd-update-utmp.service
            94ms systemd-journal-flush.service
            90ms systemd-random-seed.service
            61ms systemd-sysctl.service
            58ms systemd-udevd.service
            51ms systemd-backlight@backlight:acpi_video1.service
            51ms systemd-tmpfiles-clean.service
            48ms systemd-backlight@backlight:acpi_video0.service
            26ms systemd-backlight@backlight:intel_backlight.service
            15ms systemd-rfkill@rfkill2.service
             2ms sys-fs-fuse-connections.mount
lines 7-51/51 (END)
Code: [Select]
Startup finished in 2.899s (kernel) + 1min 23.249s (userspace) = 1min 26.148s
KDE, branch unstable, x64, Kernel LTS 3.14 (3.14.12-1-MANJARO)
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Desktop: LXQT/Plasma5, openrc & eudev
  • Kernel: x86_64
  • Skill: Advanced
« Reply #25 on: 13. July 2014, 12:06:56 »
It shouldn't be a solution to reboot countless times just to sync the damn man db.
This is a ridiculous error, a race condition I guess.
Can't the systemd users just simply run
Code: [Select]
systemdctl disable man-db
Code: [Select]
systemctl disable updatedb
« Last Edit: 13. July 2014, 12:10:01 by artoo »
Offline Hadi
  • Jr. Mitglied
  • Branch: Unstable
  • Skill: Novice
« Reply #26 on: 13. July 2014, 12:18:21 »
I just removed mandb from my system
That was a bad thing.... but I wasn't going to wait 2 minutes for my system to boot.
Offline Svajs
  • Jr. Mitglied
  • Branch: stable
« Reply #27 on: 13. July 2014, 12:51:39 »
I have kernels 314 and 315, currently using 315.
No, it wasn't just after the first boot, it happens again.
I'm using LXDM with autologin feature.
Of course it will fix it because it will get synced up, but then after a few days it will start happening again. Not a solution.
Code: [Select]
Code: [Select]
I guess I will have to do that, if there is no other fix. Better not having man pages than waiting for system to boot for 2 mins.
Offline FadeMind
  • Support Team
    • gravatar
  • Desktop: Plasma 5
  • Kernel: linux
« Reply #28 on: 13. July 2014, 13:13:26 »
Code: [Select]
Code: [Select]
Disabling these services is SAFE?
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
« Reply #29 on: 13. July 2014, 13:14:39 »
I think you would still have man pages available.
For reference, openrc doesn't start any mandb service or tries to update man db.
I don't really know why systemd does it at all.
