Author Topic: Problem with brightness Samsung Np300V5Z  (Read 2362 times)
Offline dadix
  • Neuling
« on: 30. August 2012, 19:37:04 »
Hello i have a laptop Samsung Np300V5Z. I instaled 64  bit version and the key for brightness not working. [Fn+F2 for (-) and Fn+F3 for (+)]
This is very important for my eyes.
Please help.
My laptop :
cpu : intel core i5 2410M
lcd: 15.6" LED HD (220 nit. Non Glass)
vram: NVidia GT520MX gDDR3 1GB HBR
memory: 4 GB
hdd: 640 GB
odd: Super Multi Dual Layer (SATA)
wired: 1 Gb LAN
communic: Intel 802.11 bgn(1x1) + BT3.0HS
and from : " lspci" i have this.
Quote
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b4)
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b4)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM65 Express Chipset Family LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 04)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 04)
01:00.0 3D controller: NVIDIA Corporation GF119 [GeForce GT 520MX] (rev a1)
02:00.0 Network controller: Intel Corporation Centrino Wireless-N 130 (rev 34)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
Samsung NP300v5z laptop, memory: 4 GB, Nvidia Optimus Technology
cpu : intel core i5 2410M (HD-3000 video) (Sandy Bridge second generation)
Offline Anja Noir
  • Neuling
Re: Problem with brightness Samsung Np300V5Z
« Reply #1 on: 31. August 2012, 03:34:17 »
Sounds to me more like a hardware problem. FWIW, I run the Cinn/Gnome x64-bit
version of MJ and my Fn key-functions are working fine.
I wish that I had a better answer for you...
Offline dadix
  • Neuling
« Reply #2 on: 31. August 2012, 09:35:51 »
i run Xfce version.
Offline hsngrms
  • Neuling
« Reply #3 on: 31. August 2012, 16:31:21 »
Install base-devel package set for compiling apps from aur.
Code: [Select]
pacman -S base-devel
Install nvidiabl from aur.
Add sudo modprobe nvidiabl in your autostart script.
Note: You must have sudo without password. Or you can run modprobe nvidiabl as root by hand.
Note2: nvidiabl module should load after X started.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #4 on: 01. September 2012, 13:39:27 »
I'll adopt this package to basis repo. I had that same issue on some of my hardware here at work. Should be fixed in our next release. Thanks for the hint hsngrms.
Just found out that you can't use that AUR pkg right away. Install our official packages with:
Code: [Select]
sudo pacman -S nvidiabl
Does this driver only work with nvidia driver or also with nouveau? I'd update nvidia-mhwd configs if needed to be installed by default. Will test this at work with the hardware having the same issue ...
« Last Edit: 01. September 2012, 15:36:35 by philm »
Offline hsngrms
  • Neuling
« Reply #5 on: 01. September 2012, 16:30:18 »
I tested it with only nvidia, did't test with nouveau. I'm waiting for your results.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #6 on: 01. September 2012, 19:00:30 »
You have to install it manual since I get this on my old GeForce 6150 LE:
Code: [Select]
ERROR: could not insert 'nvidiabl': No such device
« Last Edit: 01. September 2012, 19:11:13 by philm »
Offline hsngrms
  • Neuling
« Reply #7 on: 01. September 2012, 22:16:08 »
I didn't know yours old.
Quote from: pacman -Qi nvidiabl
Driver to adjust display backlight on modern mobile NVidia graphics adapters.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #8 on: 02. September 2012, 14:42:18 »
Does my driver module work for your hardware?
Offline hsngrms
  • Neuling
« Reply #9 on: 06. September 2012, 16:38:03 »
I'm using Manjaro on VM, using Arch on real machine (All disk partitions used). It doesn't work on VM. Anyone try it, who have a modern nvidia graphics card.
