Author Topic: NEW : ISOs Manjaro 0.8.10 Lxqt-Qt5 ready for testing !  (Read 12340 times)
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
Re: NEW : ISOs Manjaro 0.8.10 Lxqt-Qt5 ready for testing !
« Reply #75 on: 23. July 2014, 13:09:16 »
Hmm! Thank you sir.
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #76 on: 23. July 2014, 13:53:19 »
Very nice font size!
Offline petrea
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: lxqt
  • GPU Card: Intel HD 4400
  • GPU driver: non-free
  • Kernel: 3.14-x64
  • Skill: Novice
« Reply #77 on: 27. July 2014, 03:26:51 »
The new iso is better :) .Suspend on lid close works and no more video tearing. Thanks, Esclapion!  I'm waiting for android connection.
Acer Aspire V7 582P i5 256 SSD
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #78 on: 27. July 2014, 10:19:46 »
Thanks for the test.  dev's are discussing now of a lot of little things than they solve one after the other.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Xeto
  • Jr. Mitglied
  • Skill: Novice
« Reply #79 on: 27. July 2014, 15:58:02 »
1) After updating some days ago mouse acceleration is saved! But have to change it again to get it working  :P
2) Dual screen settings not saved. Have to redo after reboot
3) KeepassX / KeepassX2 auto type still doesn't work (tested different global shortcuts, right click -> perform auto-type inside keepassx works fine)
4) Qupzilla works better (manjaro.org dropdown menu works!!!  8), but some nice features missing (change tab from window A to B, right click & copy email address instead of copy mailto-link)
5) Chrome background apps (notifications, hangout extension, ...) works fine! But some sites opend with Chrome push cpu up near to 100%! -> just use Qupzilla  ;D
6) Moved panel to top. Show clock / date one below the other. Date is hidden because it's to high. Breaks one or two updates before? After first install lxqt (qt5) it fits the bar.
Manjaro LXQT looks more and more like a full featured and comfortable desktop! Great work done, Esclapion! I really like it!
"Leave" should also be placed into the panel for quick access "Leave -> Shutdown" instead of "Menu -> Leave -> Shutdown".
Usually I use "Synapse shortcut -> poweroff" as quick solution *g*
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #80 on: 27. July 2014, 16:05:16 »
Thanks for this very complete test.  ;)
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
  • Skill: Intermediate
« Reply #81 on: 27. July 2014, 16:55:56 »
i use a dedicated poweroff and reboot button on my panel. i could easily create them in xfce and kde, but i have not managed it in lxqt.
this (and other minor annoyances) keep me from using manjaro lxqt as my main OS. but - as esclapion has mentioned - the developers of lxqt work on a lot of bug fixes and cool stuff (like using kwin in lxqt and wayland support).
thx for your test and sharing the results with us!
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #82 on: 27. July 2014, 17:06:05 »
LXQt shortcuts seem shaky here too, but I didn't have issues regarding suspend, poweroff and reboot. Besides I could continue to use the Open/Flux-box hotkeys without problem.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #83 on: 27. July 2014, 17:34:54 »
Quote
Hmm, you will have a special appli to do that. But the system Menu -> Leave -> Shutdown exists in most DEs.
An separate application (lxqt-power-git) did that in the past, but the dev said that having a special package for it was not necessary.
In all case, it seems me easy to solve ?
Offline Xeto
  • Jr. Mitglied
  • Skill: Novice
« Reply #84 on: 27. July 2014, 18:35:56 »
I like it and use it daily ;)
"Leave" Menu in panel should be possible, but haven't take a look at it.
Keepassx auto type, mouse acceleration and dual screen config is annoying, but maybe it will work in the future.
*UPDATE*
Qupzilla has some problems with gmail, gcalendar and especially gdocs. But also Chromium have some problems with the latest version (gtasks crashes...)
@ Esclapion
 ::) sorry... I translated it to english *g*
I think you won't fix qupzilla / chromium bugs, but I'll think about and maybe send you wishlist lxqt desktop related ;)
« Last Edit: 27. July 2014, 21:38:29 by Xeto »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #85 on: 27. July 2014, 21:29:36 »
Answer of a Lxqt dev about this button : "can you fill me a feature request on the tracker ?".
So, if you can both define (and in english  ;D) exactly what you wish ?  ;)
« Last Edit: 27. July 2014, 21:35:59 by Esclapion »
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
Offline Xeto
  • Jr. Mitglied
  • Skill: Novice
« Reply #87 on: 27. July 2014, 21:41:45 »
Another utility for mouse:
http://qt-apps.org/content/show.php/MouseSense?content=137372
Thanks for your suggestion :)
Mouse speed / acceleration is present at configuration ("keyboard and mouse"), but doesn't work (value is saved, but not loaded after reboot). So it should be fixed instead of use a additional (qt4) software I think.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #88 on: 27. July 2014, 21:50:20 »
Will see it if there is a bug report about that, else I will fill one. But 248 bug reports are opened currently.  ;)
Offline schpankme
  • Held Mitglied
  • High Carb / Low Fat / Vegan
  • Branch: Stable
  • Desktop: Qt..i3..OpenRC..Eudev
  • GPU Card: GTX 780 Ti
  • Kernel: 4.4.45-1 x64
  • Skill: Advanced
« Reply #89 on: 27. July 2014, 21:52:41 »
Not able to install with -- Use Testing Installer (EFI Support)
    4 Set Filesystem Mountpoints
         "Error creating filesystem xfs on /dev/sda4"
