Author Topic: NEW : ISOs Manjaro 0.8.10 Lxqt-Qt5 ready for testing !  (Read 12736 times)
Offline schpankme
  • Held Mitglied
  • High Carb / Low Fat / Vegan
  • Branch: Stable
  • Desktop: Qt..i3..OpenRC..Eudev
  • GPU Card: GTX 780 Ti
  • GPU driver: video-nouveau
  • Kernel: 4.4.45-1 x64
  • Skill: Advanced
Re: NEW : ISOs Manjaro 0.8.10 Lxqt-Qt5 ready for testing !
« Reply #45 on: 10. July 2014, 21:57:31 »
LxqtQt5 + openrc = ?
Have you tried? Just curious.
Yes - there is no problem converting Manjaro to OpenRC.
« Last Edit: 23. September 2014, 23:52:10 by schpankme »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #46 on: 10. July 2014, 22:22:34 »
lxqt is more qt5, else the main part is the same.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #47 on: 12. July 2014, 05:37:34 »
LxqtQt5 + Openrc
Just installed LXQt5 without issues.
« Last Edit: 14. July 2014, 22:22:35 by schpankme »
Offline dicktater
  • Held Mitglied
  • Skill: Novice
« Reply #48 on: 12. July 2014, 06:19:03 »
Just installed LXQt5 without issues, possible changes down-stream.
Thanks. I'm curious how each of editions with openrc will work or whether there the edition should matter. so, I wondered how well two of your interests would mesh together. :)
The Manjaro Forum Revised Rules  How to Report Issues Properly   Please Read the Manjaro Wiki
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #49 on: 14. July 2014, 21:46:42 »
I tried meshing Xfce with LxQt5, and things got ugly.   :P
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #50 on: 16. July 2014, 19:58:12 »
Esclapion,
1. mpc is a great convenience (if not mandatory!) for global keyboard shortcuts, so I would put it in the ISO if I were you.
2. Hiding dev submenu in Application Menu is user unfriendly! Can't see qtcreator. I believe there're many users needing qt dev apps. Besides, some other general purpose apps get there too (some cad apps for instance as far as I can remember).
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #51 on: 16. July 2014, 20:41:43 »
Hi Qanjaro,
1) mpc can be good, but we already have a tool included in lxqt (lxqt-config-globalkeyshortcuts). They will do the same, no ?
2) oki oki oki. I can unhide it, but I tried to do a lxqt as simple as possible, and those mysterious qt tools are disturbing for a beginner. And I have 6 of them : 2 x 3. One set for Qt4, another for Qt5...
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #52 on: 16. July 2014, 20:45:22 »
Thank you Esclapion. Well, mpc is necessary to globally controll mpd. With it one can use lxqt shortcuts.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #53 on: 16. July 2014, 21:00:04 »
mpc added ! (37 KB, depends on libmpdclient 54 KB. So, if the ISO is too big, we will know why, lol  :)))
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #54 on: 16. July 2014, 21:03:06 »
 ;D ;D
I knew you would like it!
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #55 on: 20. July 2014, 22:48:11 »
Esclapion, can't chage font size via lxqt-config, it's stuck at 11 pt. Removing .gtk things haven't helped either.
Besides, guess lxqt devs are aware of these though, unminimising from the panel doesn't work properly (requires multiple clicks, annoying); and pcmanfm loses bookmarks; and pcmanfm-qt annoying to type (as all other words with hypen)!!!
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #56 on: 20. July 2014, 22:51:54 »
I can do it without problem. Try several things in Control center ? I don't remember if qtconfig has not also an effect
(edit)
What's the right size for an user ? I was in 12p before.
« Last Edit: 20. July 2014, 22:54:05 by Esclapion »
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #57 on: 20. July 2014, 23:06:19 »
10pt seems optimal to me though either 9 or 11 is not absurd
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • Kernel: 4.6
  • Skill: Intermediate
« Reply #58 on: 21. July 2014, 14:23:16 »
i use a 1920x1080 pixel display with a size of 18.4 inches.
even i think that all texts are a little too big (font size 11), too.
please make it a little smaller by default.
font size 9 or 10 sounds good.
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #59 on: 21. July 2014, 14:28:01 »
Yes, I've got a 27" (1920 x 1080) and 11pt is a bit large. The real issue (here) is that I can't change it. System obeys gtkrc file, but not the lxqt-config. I've removed all gtk files and folders in Home, but no joy. I'll remove the ones in /root now as well and see if it makes any difference.
