Author Topic: NEW : ISOs Manjaro 0.8.10 Lxqt-Qt5 ready for testing !  (Read 12720 times)
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • GPU driver: nonfree
  • Kernel: linux46 - x64
  • Skill: Intermediate
Re: NEW : ISOs Manjaro 0.8.10 Lxqt-Qt5 ready for testing !
« Reply #15 on: 06. July 2014, 15:40:28 »
Preliminary. It's not good. Did not install anything new. All updates up to date with installation.
But livecd seems okay; just the installed system.
System keeps crashing; when attempting some apps, desktop turns black, everything freezes.
So I keep on rebooting. Maybe I'll recheck video drivers.
Will feedback more later.
Life is a sexually transmitted disease with a 100% mortality rate.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #16 on: 06. July 2014, 15:58:26 »
I installed on the hard disk of  my PC, with and without the nonfree drivers, and  it works ? To follow... All the drivers are included.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
« Reply #17 on: 06. July 2014, 16:07:13 »
Now everything seems okay.
Recheck video, nonfree installed okay
But I did not do anything.
Very sorry for the (bad) noise.
Will alert more if I find anything.
Again sorry.
Good job. Thanks!
ps; I have to install leafpad. (no preinstalled editor?)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #18 on: 06. July 2014, 16:09:16 »
And juffed ?
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
« Reply #19 on: 06. July 2014, 16:16:20 »
Re: Juffed
Arghh! I think I better be quiet for a while.
I'm more of a nuisance than a help.
Offline ErwinC
  • Vollwertiges Mitglied
  • Branch: Arch
  • Desktop: Openbox 3.6-1
  • GPU Card: nVidia GeForce 9100 mG
  • GPU driver: Free
  • Kernel: 4.1.12LTS - 4.2.5
  • Skill: Novice
« Reply #20 on: 06. July 2014, 16:26:25 »
Looks nice!  :)
Erwin
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #21 on: 06. July 2014, 19:50:09 »
Brilliant and original, probably the only system having mpd (+Cantata) as the default audio player. Yet unfortunately cantata-qt seems to be abondoned as an AUR package. AUR packages, cantata-kde and cantata-svn, both have kde dependencies.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #22 on: 06. July 2014, 20:03:14 »
Cantata is in community. Depends on qt5.
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #23 on: 06. July 2014, 20:36:20 »
I masked a lot of things in the menu, but apparently not enough. I will simplify that more.
in xfce, we have menulibre to edit the start menu.
is there an easy way to edit the lxqt start menu?
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #24 on: 06. July 2014, 20:56:14 »
No  :(. I tried menulibre, alacarte, lxmed, but not good result. I did all manually.
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #25 on: 07. July 2014, 00:41:00 »
i have tested the 64bit version more. i went through all the settings (which are much better arranged) and played with them. i noticed that a dark theme is missing (but i do not complain about that). it is great to be able to put the panel to the left screen edge.
i played around with a couple of virtual desktops and i like it a lot (changing virtual desktops can be almost as easy as with xfce).
i changed qupzilla's language to german.
i noticed some bugs within lxqt (e.g. in the "desktop settings" window or in pcmanfm-qt).
lxqt is really fast. this is already impressive (i know that lxqt is not optimized yet).
after a reboot i noticed i broke the autologin (it worked only 50% of the time). i do not know what caused it.
i was not able to create program shortcut on the desktop or the panel. i was not able to create a cusom starter icon in the panel. i am not sure, whether it is my fault or lxqt's.
overall, my first impression was correct: this release and lxqt in general has improved since the initial release!
i will still wait a little until i use lxqt as my primary  DE.
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
« Reply #26 on: 07. July 2014, 05:12:32 »
Check at /etc/sddm.conf if "Autouser=<autouser>" is correct.
.....i will still wait a little until i use lxqt as my primary  DE
Same here.
Re: setting numlock
~/.xprofile  --> /usr/bin/numlockx on &
~/.config/autostart/NumLock
Re: setting single click
/etc/xdg/lxqt/lxqt.conf  --> sinle_click_activate=true
/etc/xdg/pcmanfm-qt/lxqt/settings --> SingleClick=true
~/.config/pcmanfm-qt/lxqt/settings.conf --> SingleClick=true
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #27 on: 07. July 2014, 10:28:23 »
Check at /etc/sddm.conf if "Autouser=<autouser>" is correct.Same here.
Re: setting numlock
For numlockx, you already have a task Numlock at the start that you can customize ;
Nice, your trick for Single click, thanks.  :D
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
« Reply #28 on: 07. July 2014, 11:16:56 »
Numlockx......cool.
Simple and easy.
Nice.
Offline Xeto
  • Jr. Mitglied
  • Skill: Novice
« Reply #29 on: 07. July 2014, 20:44:42 »
Qupzilla seems to be more stable here, but also keepassx auto type doesn't work.
Chromium-bin (aur) is more stable and faster than with qt4. So it's useable again.
Because of the combination of chromium/ hangout and keepassx I switched back from qupzilla, which also is a good and lightning fast browser.
Nice look and feel. Much better than qt4 build.
Removeable media and volume control in the panel  :D
Mouse acceleration and dual screen settings can't be saved, but should be possible to set it directly to the config files.
Great work!!!
