Author Topic: Binary repos for Lxqt Qt5 available !  (Read 8438 times)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
Re: Binary repos for Lxqt Qt5 available !
« Reply #60 on: 15. September 2014, 13:41:59 »
32 or 64 bits ?
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #61 on: 15. September 2014, 13:46:37 »
I'm  up to date, and I have :
Code: [Select]
lrwxrwxrwx 1 root root     14 22.08.2014 15:36 libQt5Xdg.so -> libQt5Xdg.so.0*
lrwxrwxrwx 1 root root     18 22.08.2014 15:36 libQt5Xdg.so.0 -> libQt5Xdg.so.0.5.3*
-rwxr-xr-x 1 root root 494320 22.08.2014 15:36 libQt5Xdg.so.0.5.3*
Offline hifi25nl
  • Neuling
  • Skill: Advanced
« Reply #62 on: 15. September 2014, 13:52:25 »
64 bit.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #63 on: 15. September 2014, 13:57:38 »
Do you have the same links than me ?  (in /usr/lib64; see above)
Offline hifi25nl
  • Neuling
  • Skill: Advanced
« Reply #64 on: 15. September 2014, 14:06:56 »
Now, yes, but there is some problem: if I go to sourceforge site I can download the package libqtxdg-qt5-git-0.5.3.30.gf0c73ca-1-x86_64.pkg.tar.xz but if I try to update the system I have this:
Code: [Select]
Packages (1): libqtxdg-qt5-git-1.0.0.2.g456069a-1
Total Download Size:    0.15 MiB
Total Installed Size:   0.49 MiB
Net Upgrade Size:       -0.04 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages ...
error: failed retrieving file 'libqtxdg-qt5-git-1.0.0.2.g456069a-1-x86_64.pkg.tar.xz' from sourceforge.net : The requested URL returned error: 404 Not Found
warning: failed to retrieve some files
error: failed to commit transaction (download library error)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #65 on: 15. September 2014, 14:47:15 »
Try to pick this of AUR ?
Offline hifi25nl
  • Neuling
  • Skill: Advanced
« Reply #66 on: 15. September 2014, 15:54:32 »
As you can see it is in repolxqt:
Code: [Select]
[piero@archlinux ~]$ pacman -Si libqtxdg-qt5-git
Repository     : repolxqt
Version        : 1.0.0.2.g456069a-1
Description    : Library providing freedesktop.org specs implementations for Qt.
Architecture   : x86_64
URL            : http://lxqt.org
Licenses       : GPL2
Groups         : None
Provides       : libqtxdg-qt5
Depends On     : qt5-base  qt5-tools
Optional Deps  : None
Conflicts With : libqtxdg-qt5
Replaces       : None
Download Size  : 153.48 KiB
Installed Size : 499.00 KiB
Packager       : Unknown Packager
Build Date     : Mon 15 Sep 2014 01:14:12 AM CEST
Validated By   : MD5 Sum  SHA256 Sum
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #67 on: 15. September 2014, 16:02:53 »
May be a transmission problem with this of repolxqt. This of AUR is maybe sane.
Offline hifi25nl
  • Neuling
  • Skill: Advanced
« Reply #68 on: 15. September 2014, 17:57:09 »
But problem persists in two different installations. I think it is a lxqt bug. It can be fixed only (temporary solution) with this:
Code: [Select]
ln -s libQt5Xdg.so.0.5.3 libQt5Xdg.so.1
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #69 on: 15. September 2014, 19:57:10 »
OK, but I don(t have this problem.
