Author Topic: Binary repos for Lxqt Qt5 available !  (Read 8283 times)
Offline melkhatt
  • Jr. Mitglied
  • Branch: Parabola
  • Desktop: lxqt Compiz
  • Kernel: linux-ck-core2
  • Skill: Novice
Re: Binary repos for Lxqt Qt5 available !
« Reply #45 on: 23. August 2014, 15:11:46 »
You must change the .desktop in /usr/share/applications
I created a new one  ;)
And another needed for weather-app
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #46 on: 23. August 2014, 16:52:28 »
Quote
Pastebin me it, please ?  ;) I will integrate that.
(edit)
From my side, I integrated sumopaint (thx Citroen)?
« Last Edit: 23. August 2014, 16:59:18 by Esclapion »
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline melkhatt
  • Jr. Mitglied
  • Branch: Parabola
  • Skill: Novice
« Reply #47 on: 23. August 2014, 18:37:46 »
http://pastebin.com/QvE7493r
btw it's just a copy of cmst (newbie inside  :-[ )
« Last Edit: 23. August 2014, 18:46:29 by melkhatt »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #48 on: 23. August 2014, 18:53:54 »
Thanks. I was especially interested by the icons, but I don't have that in Humanity-wise...   ;)
(edit)
« Last Edit: 23. August 2014, 19:01:08 by Esclapion »
Offline melkhatt
  • Jr. Mitglied
  • Branch: Parabola
  • Skill: Novice
« Reply #49 on: 23. August 2014, 19:13:10 »
(edit)
I use the icon from "status" icons
oxygen
faience
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #50 on: 23. August 2014, 19:18:04 »
I found (today) a better system : I put the icon in /usr/share/pixmaps, so it's icon-theme-independent. Beginner also...  ^-^
« Last Edit: 23. August 2014, 19:23:03 by Esclapion »
Offline melkhatt
  • Jr. Mitglied
  • Branch: Parabola
  • Skill: Novice
« Reply #51 on: 23. August 2014, 19:28:01 »
yes i use this for octopi & searchmonkey
PS: Wise is gnome-icons dependent , so you can use "Icon=weather-few-clouds", it's present in gnome, oxygen so also faenza, wise...
« Last Edit: 23. August 2014, 19:33:06 by melkhatt »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #52 on: 23. August 2014, 19:38:07 »
I have nothing like 'weather*' in my Humanity-wise. But it's a leight one.
Offline melkhatt
  • Jr. Mitglied
  • Branch: Parabola
  • Skill: Novice
« Reply #53 on: 23. August 2014, 19:49:37 »
- I don't have "humanity-wise", but i think it's depends on "gnome-icons", so when it don't find an icon, it looks in the "gnome" folder, and in "gnome/**x**/ status" you have some weather icons.
But the "pixmap" solution is the best.
- And in the same way, i copied a "system-reboot.png" icon in "/usr/share/pixmaps", because I don't have a "reboot icon" with faience & other gnome-dependent icon themes
Edit: i installed "gnome-colors" to test. so:
      "gnome-wise" depends on "gnome-colors-common" which depends on "gnome"
« Last Edit: 23. August 2014, 19:59:16 by melkhatt »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #54 on: 23. August 2014, 20:52:55 »
pixmaps is no perfect, because it don't appears in pcmanfm -> applications,  nor if you do a copy to the desktop.
I try now to put icons of differents sizes in hicolor/apps. Will see...
lazpaint is very good to work on pictures.  :)
Offline melkhatt
  • Jr. Mitglied
  • Branch: Parabola
  • Skill: Novice
« Reply #55 on: 24. August 2014, 12:14:08 »
I always found this feature of pcmanfm useless. I don't understand why they keep it in pcmanfm-qt, we have lxqt-panel-menu for that.
Try "Icon=weather-few-clouds", it gonna work even with humanity-wise
+1
Offline dicktater
  • Held Mitglied
  • Skill: Novice
« Reply #56 on: 24. August 2014, 12:49:17 »
Found this one somewhere. I had to make minor edit and use this one for weather-app in Enlightenment. Looks nice in menu and on panel.
The Manjaro Forum Revised Rules  How to Report Issues Properly   Please Read the Manjaro Wiki
Offline hifi25nl
  • Neuling
  • Skill: Advanced
« Reply #57 on: 15. September 2014, 12:15:09 »
Hello, thank you for your work on the repo.
I have been using repolxqt for some time now without a problem, but with today update lxqt is not starting any more.
After I have downgraded to previous packages (26 August I think) and all is fine.
This is happening in a system with kde installed and kdm starting lxqt.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #58 on: 15. September 2014, 13:18:04 »
Do you use THIS REPO, or the old one ?
Offline hifi25nl
  • Neuling
  • Skill: Advanced
« Reply #59 on: 15. September 2014, 13:32:18 »
I have changed today to the new one.
The libqtxdg-qt5-git link libQt5Xdg.so to libQt5Xdg.so.1 but starting lxqt with startlxqt I have this error:
lxqt-session: error while loading shared libraries: libQt5Xdg.so.0: cannot open shared object file: No such file or directory
