Author Topic: Binary repos for Lxqt Qt5 available !  (Read 7924 times)
Offline Egavas
  • Vollwertiges Mitglied
  • Aut viam inveniam aut faciam
  • Branch: Stable
  • Desktop: NET Install > Plasma Desktop
  • GPU Card: ATI Radeon R9 270X
  • GPU driver: free
  • Kernel: linux45-x64
  • Skill: Intermediate
Re: Binary repos for Lxqt Qt5 available !
« Reply #15 on: 13. July 2014, 16:25:27 »
Hi there, I did lxqt-qt5 build (clean net install build with Esclapion repo) but for some reason b1 archiver doesn't work for me, thou it worked just fine on old lxqt-qt4 build, when I open it from terminal I get:
Code: [Select]
[bojan@manjaro ~]$ b1
Extract: b1 x <options> <archive path> <extract path>
Create:  b1 a <options> <archive path> <target path>
Listing: b1 l <options> <archive path>
And is it just me, or qupzilla-qt5 have some strange scrolling? When I scroll some internet page down, it gets down few lines, then it jumps back up from where I have started scrolling, this isn't happening in qupzilla-qt4. And yeah, html5 doesn't work again for me :D
Cheers!
« Last Edit: 13. July 2014, 16:39:22 by Egavas »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #16 on: 13. July 2014, 17:09:03 »
IT works in the ISO. html5 also, and I integrated the flash.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Egavas
  • Branch: Stable
  • GPU driver: free
« Reply #17 on: 13. July 2014, 17:19:53 »
I will try it, but I'm bit lazy at the moment to download it :D I will post back when I install it.
Cheers!
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #18 on: 13. July 2014, 17:37:21 »
Esclapion, would it be troublesome or unpractical to integrate b1 archiver into pcmanfm-qt? I don't have other GTK based archivers here and so have redundant "compress" and "extract here" context menu commands. I couldn't ingetrate b1 myself (probably because of wrong command line arguments I've tried for b1). Even if I can, with the next update of pcmanfm-qt my manual integration of b1 will be lost anyway.
Hmmm, I have a strong feeling that I should request this feature from the dev himself.
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #19 on: 13. July 2014, 17:38:53 »
i have noticed this behavior as well. sometimes it works and sometimes it does not. i installed lxqt-qt5 on an external hard drive.
i am not really worried about it, because qupzilla-qt5-git 1.7.0 is a developmental version. version 1.7.0 of qupzilla is not even out yet, so the qupzilla developers still have time to fix that problem.
if you want to, you can file a bug report: https://github.com/QupZilla/qupzilla/wiki/Bug-Reports
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #20 on: 14. July 2014, 12:59:12 »
Esclapion, does this have any use for you or LXQt devs?
https://aur.archlinux.org/packages/qtkeychain-qt5/
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #21 on: 14. July 2014, 13:08:44 »
Hi qanjaro,  :)
I never use this sort of program for myself, but thanks, it can be interesting.
In this area, more interesting for me would be a good replacement for gnome-keyring/kwallet. But for the moment, lxqt_wallet is absolutely not ready, I think.
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #22 on: 14. July 2014, 13:12:47 »
Right, I've thought (possibly erroneously) that it could be integrated to lxqt_wallet. Or something like that!!
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #23 on: 24. July 2014, 00:22:59 »
Binary repo repolxqt-qt5 updated for 64 bits.
Offline xircon
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Plasma
  • GPU Card: Intel 4th gen
  • GPU driver: free
  • Kernel: Always the newest!
  • Skill: Advanced
« Reply #24 on: 24. July 2014, 00:56:12 »
Lots of errors:
Code: [Select]
error: failed retrieving file 'libqtxdg-qt5-git-0.5.3.30.gf0c73ca-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
warning: failed to retrieve some files
error: failed retrieving file 'liblxqt-git-0.7.0.35.gceb8657-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'liblxqt-mount-git-0.7.0.11.gae22e05-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-common-git-0.7.0.9.g6f0dd0d-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-config-git-0.7.0.16.gac8b1b4-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-config-randr-git-0.7.0.4.g8467ef1-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-globalkeys-git-0.7.0.9.g76bb5a5-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-notificationd-git-0.7.0.6.g236541f-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'libsysstat-qt5-git-0.1.0.4.g151ef16-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-panel-git-0.7.0.50.ged5082b-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-session-git-0.7.0.11.gd57c257-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-runner-git-0.7.0.5.g581b924-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-qtplugin-git-0.7.0.17.gad8c650-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-policykit-git-0.7.0.5.g081a7ff-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-openssh-askpass-git-0.7.0.3.g23c5181-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-powermanagement-git-0.7.0.13.g29b815f-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-admin-git-13.342cf5a-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'lxqt-desktop-git-0.7.0.5.g2699d0f-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
error: failed retrieving file 'pcmanfm-qt-git-0.7.0.19.g4256518-1-x86_64.pkg.tar.xz' from esclapion.free.fr : The requested URL returned error: 404 Not Found
 lib32-gcc-libs-4.9.1-1-x86_64                     996.5 KiB   198K/s 00:05 [###########################################] 100%
 gcc-libs-multilib-4.9.1-1-x86_64                 1176.6 KiB   187K/s 00:06 [###########################################] 100%
 lib32-libltdl-2.4.2-14-x86_64                      16.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #25 on: 24. July 2014, 01:07:23 »
Which ISO used ?
Offline xircon
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Plasma
  • GPU driver: free
  • Skill: Advanced
« Reply #26 on: 24. July 2014, 19:38:25 »
Strange, works now!  Didn't install from a LXQT iso, its an old 0.8.9 openbox install.
Steve
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #27 on: 24. July 2014, 19:40:09 »
Steve
32 or 64 bits ?
Offline xircon
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Plasma
  • GPU driver: free
  • Skill: Advanced
« Reply #28 on: 24. July 2014, 19:43:37 »
64 bits.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #29 on: 24. July 2014, 19:46:42 »
Maybe the server ? I changed nothing to the 64.
