Author Topic: Manjaro Fluxbox 0.8.10  (Read 13900 times)
Offline dicktater
  • Held Mitglied
  • Skill: Novice
Re: Manjaro Fluxbox 0.8.10
« Reply #30 on: 03. July 2014, 14:10:49 »
Where can i find manjaro gray theme on yaourt ?
Is this something you have seen somewhere in the forum? I don't know about gray per se but there is Adwaita-Manjaro-light and Adwaita-Manjaro-dark in the xfce-theme-adwaita-manjaro-git
https://aur.archlinux.org/packages/xfce-theme-adwaita-manjaro-git/
And, xfce-theme-adwaita-manjaro-lighter
https://aur.archlinux.org/packages/xfce-theme-adwaita-manjaro-lighter/
Agust has recently posted 2 gray themes for Enlightment, A-18-Manjaro-Gray and A-18-Manjaro-Gray-Light. For latter, there is a GTK version called gnomishgray1. Look here in Artwork E17/E18 Manjaro:
https://forum.manjaro.org/index.php?topic=2380.msg108336#msg108336
The Manjaro Forum Revised Rules  How to Report Issues Properly   Please Read the Manjaro Wiki
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • GPU driver: non-free
  • Kernel: linux314 x64
  • Skill: Advanced
« Reply #31 on: 03. July 2014, 14:57:56 »
E17gtk is in our repos, it's a good grey theme.
Code: [Select]
sudo pacman -S gtk-theme-e17gtk
Offline Chuck
  • Jr. Mitglied
« Reply #32 on: 03. July 2014, 14:59:35 »
i've seen manjaro fluxbox use numix-manjaro-grey theme by default but there is not on aur
Offline UgoYak
  • Artwork Team
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: ATI
  • GPU driver: free
  • Kernel: linux3.14 (x64)
  • Skill: Novice
« Reply #33 on: 03. July 2014, 16:11:02 »
Hi Chuck,
I attached the Numix-Manjaro-Grey theme here for download.
(However, in next release it's highly probable to be changed, by Menda or similar).
Regards,   ;)
UgoYak on: DevianArt | Google+
Offline Chuck
  • Jr. Mitglied
« Reply #34 on: 03. July 2014, 16:53:24 »
Hi Chuck,
Regards,   ;)
I Like it, thx u ;)
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • GPU driver: nonfree
  • Kernel: linux46 - x64
  • Skill: Intermediate
« Reply #35 on: 11. July 2014, 17:38:19 »
Re: making XF86 keys work globally
in ~/.fluxbox/keys, comment out following
Code: [Select]
# volume settings, using common keycodes
# if these don't work, use xev to find out your real keycodes
# 176 :Exec amixer sset Master,0 1+
# 174 :Exec amixer sset Master,0 1-
# 160 :Exec amixer sset Master,0 toggle
Add following
Code: [Select]
XF86AudioRaiseVolume :amixer set Master 5%+
XF86AudioLowerVolume :amixer set Master 5%-
XF86AudioMute :amixer set Master toggle
Openmixer --> preferences (click mixer icon at panel)
check boxes all Hotkeys
Life is a sexually transmitted disease with a 100% mortality rate.
Offline fassil
  • Support Team
  • Branch: stable/unstable
  • Desktop: E19/E20
  • GPU driver: free
  • Kernel: Linux314 & 318
« Reply #36 on: 21. July 2014, 09:05:17 »
Hi,
I try this flavour since a couple of days on my 32 bits netbook & it's good to play on with something else than E like this.
Well done, bro  ;)
A+
"Are you enlightened ?"
Offline Devpaul
  • Neuling
  • Skill: Novice
« Reply #37 on: 30. July 2014, 12:40:25 »
Thank you for this excellent build.  Best Manjaro build I have tested.
Offline archiebunker
  • Vollwertiges Mitglied
  • Branch: Stable
  • Desktop: OB, FB, Mate
  • GPU Card: A10/APU/GPU/7670M
  • GPU driver: AMD/ATI OpenSource Graphics
  • Kernel: manjaro-*.*-x86_64
« Reply #38 on: 14. August 2014, 23:19:13 »
 Fluxbox is something I've always liked, but never really got into until Manj-Flux.
Seriously, thanks Phil&Company for this I really like it, and it'll walk with Openbox anyday,and in many performance respects. - I luv them bioth.
ok,
 But,  (here we go).
The "only" thing that irks me is this window moving lagginess, everything else is picture-perfect.
 I have tried it with and without free or non-free (nvidia) drivers, but it's the same thing, well actually the (non-free) nvidia-drivers do help a bit, but ...naa.
 And yes, I have disabled "Opaque Window Moving" and it has helped, but now it also leaves what appears to be ray-tracing artifiacts, after the moving ?!
I could go on, and on, but there is more than enough "minor complaints" about this just googling this.
 Is this an inherent issue with FB, that it keeps redrawing the window during every movement or what? -and yes this has been going on for years with FB.
I have seen this in Openbox too, but not near as pronounced as Fluxbox.
 Other than that, as I said before, FB is light, powerful, with years of experience behind it,
but...
Anybody else ?
« Last Edit: 14. August 2014, 23:23:42 by archiebunker »
Offline mcsfilho
  • Neuling
« Reply #39 on: 15. August 2014, 02:45:24 »
I'm trying to install and is giving the error:
IO charset iso8859-1 not found
How fix it?
EDITED:
I change from Rufus to ImageWriter (Windows) and worked...
« Last Edit: 15. August 2014, 03:12:21 by mcsfilho »
Offline Kurosawa
  • Neuling
  • Branch: Stable
  • Desktop: Xfce
  • Skill: Novice
« Reply #40 on: 25. August 2014, 18:30:27 »
What do you use as power manager in fluxbox ?
Offline fixed
  • Neuling
  • Skill: Novice
« Reply #41 on: 03. November 2014, 13:38:50 »
Thanks for your great work! I love fluxbox and now i also love Arch :)
I think there is some issues with poulsbo graphic cards though (as always).
But it works great on my zenbook ux32v
Would be so cool if there was incorpurated touchegg in this as well :). Or if fluxbox some day comes with hot corners...
Only think I have found kinda like that is skippy-xd (http://www.youtube.com/watch?v=JuvvvzykHTQ)
Is there an IRC channel dedicated to Manjaro fluxbox?
  • Branch: Stable
« Reply #42 on: 08. February 2015, 14:52:29 »
btw:  a "new" Fluxbox 1.3.7 has been released.
http://fluxbox.org/news/
« Last Edit: 08. February 2015, 14:56:12 by archiebunker »
Offline fredhoud
  • Sr. Mitglied
  • King of Liunx!
  • Branch: Stable
  • Desktop: KDE Plasma Version 5.6.3
  • GPU Card: Intel Quad Core i7-4790K - NVIDIA GeForce GTX 745
  • Kernel: 4.4.9-1 Manjaro
  • Skill: Novice
« Reply #43 on: 08. February 2015, 18:35:13 »
Looks very pretty, and fast, but I can't figure out how to install it on the hard drive!
Sorry, never mind. I figured it out.
« Last Edit: 08. February 2015, 19:24:52 by fredhoud »
Offline fredhoud
  • Sr. Mitglied
  • King of Liunx!
  • Branch: Stable
  • Skill: Novice
« Reply #44 on: 08. February 2015, 19:57:46 »
I intsalled it and there are 2 updates available, but when I try to apply the updates, it says 'Manjaro-system': transition not initialized.
How to do initialize or fix this?
