Author Topic: [wiki] How-To check that the DPI for your monitor is correct:  (Read 2352 times)
Offline handy
  • Global Moderator
  • Desktop: Openbox 3.6.1-3 & Worker :)
  • GPU Card: intel...
  • GPU driver: open-source
  • Kernel: OpenBSD
  • Skill: Intermediate
This How-To has been expanded & cleaned up, it is now available in the wiki, you should read it there:
Did X.server recognise your monitor correctly?
Please report any errors, improvements or post any questions on the topic in this thread.
_____________________________
« Last Edit: 26. August 2015, 13:56:21 by handy »
The ultimate tyranny in a society is not control
by martial law. It is control by the psychological
manipulation of consciousness, through which reality
is defined so that those who exist within do not even
realize that they are in prison.
  —  Barbara Marciniak
Offline handy
  • Global Moderator
  • Kernel: OpenBSD
Re: How-To check that the DPI for your monitor is correct:
« Reply #1 on: 31. December 2012, 03:10:43 »
This How-To has been expanded; cleaned up & wikified. You should read it there:
http://wiki.manjaro.org/index.php/Did_X.server_recognise_your_monitor_correctly%3F
« Last Edit: 31. December 2012, 03:31:56 by handy »
  —  Barbara Marciniak
Offline PositronicTomato
  • Neuling
  • Skill: Novice
Re: [wiki] How-To check that the DPI for your monitor is correct:
« Reply #2 on: 11. December 2015, 01:16:54 »
FYI for those with multiple monitors.
This command:
xdpyinfo | grep -B2 resolution
Will return one result that's a combination of your monitors.
For example, on my machine, it gave the following output:
screen #0:
  dimensions:    3360x1080 pixels (889x286 millimeters)
  resolution:    96x96 dots per inch
At first, I thought it wasn't configured correctly - since my main monitor is 1920x1080, I thought it got the dimensions of that one wrong and didn't give any info on my second monitor at all.
Then I realized that it added the horizontal pixels for both monitors - my second monitor is 1440x900.
1920+1440=3360
Offline handy
  • Global Moderator
  • Kernel: OpenBSD
« Reply #3 on: 11. December 2015, 09:51:05 »
Thanks for that info. :)
I just added the following to the wiki:
Quote
Note: If you are running more than one monitor, this test will most likely provide results that are created by combining the monitors that you have connected to your machine & treating them as though they are one monitor!
So you may need to do some arithmetic, OR, of course you could just connect one monitor at a time for the test. ;)
  —  Barbara Marciniak
Offline simgin
  • Held Mitglied
  • Branch: All.
  • Desktop: XFCE+Alpine Linux, Mate+Fedora, Ubuntu Server + Mate and NoX+LinuxBBQ
  • GPU Card: GeForce 8600M & GT 555M 2GB
« Reply #4 on: 15. December 2015, 21:35:34 »
This is sweet, thank you for the info guys :)
Cheers
simgin
