Author Topic: What are your favorite qt4/qt5 applications ?  (Read 29106 times)
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
Re: What are your favorite qt4/qt5 applications ?
« Reply #45 on: 17. June 2014, 15:10:00 »
Since not yet mentioned: goldendict (the best dictionary app), luckybackup (the best backup tool), makemkv (not opensource but free, best DVD/Bluray to MKV convertion tool),  Cantata + MPD (the best audio player), LyX (the best document procssor), colord-fake (for printing packages without GTK cruft). gbscan (depending on gambas libraries other than Qt), flirc (remote app), convertall, copyq, xgrabcolor.
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #46 on: 17. June 2014, 16:02:03 »
qtcurve, supports both Qt4 and Qt5 and the developer mentions in github his willingness to create a Qt-only config utility for it which will be the only means to customise the appearance in a Qt-only system.
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #47 on: 17. June 2014, 16:05:56 »
ssx (instead of gksu) as su/sudo frontend, though not a Qt utility, doesn't depend on GTK either freeing me from another GTK cruft. Yet Octopi can't be used with it, you can use pacmanxg instead of octopi.
« Last Edit: 17. June 2014, 19:07:26 by qanjaro »
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #48 on: 17. June 2014, 17:12:09 »
udevil for mounting work, eliminating the need for gvfs (though another and easy alternative may be easymount – http://qt-apps.org/content/show.php/easymount?content=157956).
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
  • Skill: Intermediate
« Reply #49 on: 17. June 2014, 18:34:50 »
wow. this thread keeps getting better and better...
keep it coming.
i am trying to use manjaro kde exclusively at least for the next few weeks. i just wanted to try a qt based DE and lxqt is still missing a couple of imho essential features.
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #50 on: 18. June 2014, 00:41:41 »
Well, not an app, but a new functionality: To add custom actions to pcmanfm-qt see http://madebits.com/blog/comments.php?y=14&m=03&entry=entry140317-141947.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #51 on: 18. June 2014, 00:44:48 »
Hmmmm, thanks, really interesting if it works with the -qt.  :D
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #52 on: 18. June 2014, 00:46:47 »
Yes, it works, tried and tested. Mines are below (change apps and icons as you like). Put them in /home/YOUR_USERNAME/.local/share/file-manager/actions.
« Last Edit: 20. June 2014, 01:35:55 by qanjaro »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #53 on: 18. June 2014, 00:58:57 »
OK, I will try, thanks.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #54 on: 22. June 2014, 18:01:10 »
Hi,
No alternative for gparted ? partitionmanager depends on kdebase, and qtparted is orphan and doesn't work...  :(
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #55 on: 22. June 2014, 19:31:06 »
peazip doesnt work well also. And orphan.  ???
Offline salome
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: NVIDIA GT218 [GeForce 210]
  • GPU driver: Mesa / nouveau free drivers
  • Kernel: linux314-x64
« Reply #56 on: 22. June 2014, 22:13:29 »
Mmm, I like vlc and smplayer as video palyers, clementine as audio player, qupzilla as web browser, acetoneiso as .iso burner.
But, what about for the text editor, the office suite and the image editor, without kde dependences? Do you have any ideas?
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #57 on: 22. June 2014, 22:26:22 »
text-editor is juffed (recommended and done by the team). Same way, image viewer : lximage-qt
For office, I have nothing. libreoffice-installer, and maybe writer already installed ?  ::)
Offline salome
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: XFCE
« Reply #58 on: 22. June 2014, 23:01:04 »
What about the image editor (like GIMP)?
I'm surfing on http://qt-apps.org right now, searching some good stuff, but I haven't find image modification programs as good as GIMP or Krita :(
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #59 on: 22. June 2014, 23:27:03 »
I have one, I think, done by Leclanché, one of the lxqt devs : easypaint-git.
Absolutely not at the level of Gimp, but very light.
