Hi, Guest
Fresh from the dev:http://qt-apps.org/content/show.php/QScanner?content=166204
The new UI uses (for now) the stock Qt theme. This isn’t ugly per se, but it does look a little out of place on the Ubuntu desktop, especially compared to previous builds. Memory usage is also reportedly higher, in some cases jumping from 60MB when idle to more than 178MB. Those on low-end devices should resist the temptation to try this [experimental] build — at least until this particular bug has been addressed.http://www.omgubuntu.co.uk/2014/07/dropbox-experimental-linux-build-qt-rewrite
How to test Qt-based dropbox on your system1. First of all quit Dropbox either bu right clicking on the dropbox icon on the task-bar or running dropbox stop command in the Konsole 2. Download the experiment buld from this link 3. Extract the zip file (it would be a hidden folder) 4. Cd to the ‘dropbox-lnx’ foldermukt@the-mukt-online:~ > cd /home/mukt/Downloads/.dropbox-dist/dropbox-lnx.x86_64-2.11.0/5. Then run this command:dropbox startYou have the Qt based dropbox running on your system.If you want to go back to old Dropbox, simple stop dropbox again, delete the downloaded and extracted folder. Then run dropbox from your menu.http://www.themukt.com/2014/07/17/dropbox-switches-qt-looks-great-plasma-systems/
dicktater and Esclapion,There's no "registration" button in the Wiki pages and my forum name isn't accepted. May I ask you to read the attached file (.html and .wiki) and if useful put it in the Wiki?Other souls are certainly welcome to read and criticize too.
, luckybackup (the best backup tool),
