Author Topic: What are your favorite qt4/qt5 applications ?  (Read 28569 times)
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
Re: What are your favorite qt4/qt5 applications ?
« Reply #120 on: 25. June 2014, 11:46:22 »
Hmmm, one less ? A link  ? ;) I will try.
just go to softpedia (for instance) download the package.
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #121 on: 25. June 2014, 11:46:59 »
As I said, extracting libflashplugin.so to qupzilla didn't help
Cheers!
All right, Egavas, sorry.
Offline Egavas
  • Vollwertiges Mitglied
  • Aut viam inveniam aut faciam
  • Branch: Stable
  • Desktop: NET Install > Plasma Desktop
  • GPU Card: ATI Radeon R9 270X
  • GPU driver: free
  • Kernel: linux45-x64
  • Skill: Intermediate
« Reply #122 on: 25. June 2014, 11:50:57 »
No harm is done :) I appreciate your help
Cheers!
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #123 on: 25. June 2014, 11:56:55 »
Did you try to put it in /usr/lib/mozilla/plugins;)
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #124 on: 25. June 2014, 12:00:13 »
I've got it there as well. So maybe that's why it seems to work here.
Offline Egavas
  • Branch: Stable
  • GPU driver: free
« Reply #125 on: 25. June 2014, 12:04:17 »
Yes I have tried that too, but no go, will mess around tomorrow to see if I can manage something out.
Cheers!
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #126 on: 25. June 2014, 12:06:24 »
Egavas, would you mind giving the link to the troubled flash content?
Offline Egavas
  • Branch: Stable
  • GPU driver: free
« Reply #127 on: 25. June 2014, 12:11:57 »
Sure http://www.youtube.com/watch?v=J51LPlP-s9o
In my openbox build without flashplugin installed and no libflashplayer.so it works just fine in firefox, but in virtualbox where I have built LXQT it won't work
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #128 on: 25. June 2014, 12:15:05 »
Hmmm, it works here. I'll shut up for now. By the way(!), I've got qupzilla-qt5 from AUR.
Offline Egavas
  • Branch: Stable
  • GPU driver: free
« Reply #129 on: 25. June 2014, 12:15:54 »
I will try it, I'm using qt4 version form manjaro repos
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #130 on: 25. June 2014, 12:22:30 »
I've got the below gstreamers. Other than those one can install from AUR these (though I haven't):
https://aur.archlinux.org/packages/gst-plugin-libde265-git/
https://aur.archlinux.org/packages/gstreamer0.10-good-plugins-slim/
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #131 on: 25. June 2014, 12:27:54 »
I use now also qupzilla-qt5-git
Offline Egavas
  • Branch: Stable
  • GPU driver: free
« Reply #132 on: 25. June 2014, 12:31:54 »
Heh, problem solved guys, just instaled qt5 version and it works, rofl
Big thanks for trouble! I might even do real install now to replace openbox!
Cheers!
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #133 on: 25. June 2014, 12:33:01 »
Cheers!
Gladdening!
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #134 on: 25. June 2014, 13:03:07 »
Not a Qt app, but doesn't depend on gtk either: https://aur.archlinux.org/packages/gphotofs/
udevil can eliminate the need for gvfs for mounting work, but I don't know how or if it hanles cameras. gphotofs handles them with minimum configuration. See its github page and Arch wiki: https://wiki.archlinux.org/index.php/Digital_Cameras#GPhoto2_usage.
After the configuration you just need to assign two keyboard shortcuts to mounting and unmounting commands.
EDIT: Or those commands can be integrated to pcmanfm-qt.
« Last Edit: 25. June 2014, 13:56:12 by qanjaro »
