Author Topic: What are your favorite qt4/qt5 applications ?  (Read 26322 times)
Offline Salinko
  • Held Mitglied
  • Branch: manjaro-xfce-16.06-pre1-x86_64 (unstable)
  • Desktop: Xfce 4.12.3
  • GPU Card: Gigabyte HD7870 GHz Edition
  • GPU driver: radeon free
  • Kernel: 4.5.0-2-MANJARO x86_64
  • Skill: Novice
Re: What are your favorite qt4/qt5 applications ?
« Reply #105 on: 25. June 2014, 11:25:18 »
Qupzilla uses flash click-to-play by default. Check /Preferences/Extensions/WebKit Plugins/Allow Click to Flash.
I have youtube and other similar sites working with out the need to add anything. Flash seems to be installed by default.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #106 on: 25. June 2014, 11:29:13 »
Yes, we can see that here :
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Egavas
  • Vollwertiges Mitglied
  • Aut viam inveniam aut faciam
  • Branch: Stable
  • Desktop: NET Install > Plasma Desktop
  • GPU Card: ATI Radeon R9 270X
  • GPU driver: free
  • Kernel: linux45-x64
  • Skill: Intermediate
« Reply #107 on: 25. June 2014, 11:29:24 »
@Salinko
Yes, I know but this is my custom lxqt buld without gtk at all, so flashplugin is not installed. I was trying to mess around with libflashplugin.so from adobe but with no luck, anyway I will stick to my openbox for a while.
Cheers!
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #108 on: 25. June 2014, 11:31:13 »
Hmmm, in mine, flashplugin is installed.
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #109 on: 25. June 2014, 11:32:33 »
Yes, as Salinko said, disable "Allow Click to Flash". It's known (in github issues) to have trouble with flash.
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #110 on: 25. June 2014, 11:35:43 »
Esclapion, no. As he said see /Preferences/Extensions/WebKit Plugins/Allow Click to Flash or see the below screenshot.
Offline fassil
  • Support Team
  • Branch: stable/unstable
  • Desktop: E19/E20
  • GPU driver: free
  • Kernel: Linux314 & 318
« Reply #111 on: 25. June 2014, 11:35:53 »
Hi,
None, just need gtk2... (it's a joke)  ;)
"Are you enlightened ?"
Offline Salinko
  • Held Mitglied
  • Skill: Novice
« Reply #112 on: 25. June 2014, 11:36:41 »
As an aside, white-listing sites made no difference in my case.
« Last Edit: 25. June 2014, 11:38:15 by Salinko »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #113 on: 25. June 2014, 11:37:44 »
Hmmm, OK. Half awake. Thanks to both.  :) I will try to pre-configure it.
I only must find a video who not worked, to be sure of the change  ;D
« Last Edit: 25. June 2014, 11:39:33 by Esclapion »
Offline Egavas
  • Branch: Stable
  • GPU driver: free
« Reply #114 on: 25. June 2014, 11:39:03 »
It is disabled, and flashplugin requires gtk2 so I don't want to install it. Anyway thanks for replies, I will try it again in few months, or will waiting for new Esclapions build.
Cheers!
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #115 on: 25. June 2014, 11:42:50 »
Cheers!
Flashplugin requires gtk2 if you install it, but if you just download adobe flash package and extract libflashplayer.so and put it in usr/lib/qupzilla you're done without any gtk.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #116 on: 25. June 2014, 11:43:14 »
Yep, but it's difficult to absolutely suppress gtk, 2 AND 3.
For example, to suppress gtk3, we must suppress gnome-keyring and network-manager. lxqt-kwallet and qconnman seem not be ready.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #117 on: 25. June 2014, 11:45:04 »
Hmmm, one less ? A link  ? ;) I will try.
Offline qanjaro
  • Sr. Mitglied
  • Skill: Novice
« Reply #118 on: 25. June 2014, 11:45:35 »
I have everything here, every functionality and no GTK (2 or 3). Well, I just have network-manager but not its applet (so no gtk) and don't need gnome-keyring or lxqt-kwallet.
« Last Edit: 25. June 2014, 11:50:42 by qanjaro »
Offline Egavas
  • Branch: Stable
  • GPU driver: free
« Reply #119 on: 25. June 2014, 11:46:09 »
As I said, extracting libflashplugin.so to qupzilla didn't help
Cheers!
