Author Topic: [SOLVED] Key could not be imported error during update  (Read 18631 times)
Offline letian
  • Neuling
  • Branch: stable
  • Desktop: awesome 3.5.6-2
  • GPU Card: Intel Haswell-ULT
  • Kernel: Kernel~4.0.8-1-MANJARO x86_64
  • Skill: Novice
« on: 07. June 2014, 12:22:36 »
I installed manjaro today and cannot update it. After running casual
Code: [Select]
sudo pacman-key --init
sudo pacman-key --populate archlinux manjaro
sudo pacman-key --refresh-keys
I started updating with:
Code: [Select]
sudo pacman -Syyuu
Code: [Select]
 core                                                             125.1 KiB   107K/s 00:01 [####################################################] 100%
 extra                                                           1762.2 KiB   132K/s 00:13 [####################################################] 100%
 community                                                          2.3 MiB   133K/s 00:18 [####################################################] 100%
warning: glamor-egl: downgrading from version 0.6.0-2 to version 0.6.0-1
:: Replace mesa-libgl with core/mhwd? [Y/n] y
:: Replace shared-color-profiles with extra/colord? [Y/n] y
resolving dependencies...
looking for inter-conflicts...
Total Installed Size:   1000.92 MiB
Net Upgrade Size:       30.13 MiB
:: Proceed with installation? [Y/n] y
(242/242) checking keys in keyring                                                         [####################################################] 100%
downloading required keys...
:: Import PGP key 4096R/, "Joshua Strot <joshua@manjaro.org>", created: 2014-04-10? [Y/n] y
error: key "Joshua Strot <joshua@manjaro.org>" could not be imported
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
What did I forget to do?
« Last Edit: 07. June 2014, 13:24:59 by letian »
Offline Hertz
  • Held Mitglied
  • Skill: Novice
Hi letian,
tried to modify your update with:
Code: [Select]
sudo pacman -Syy
sudo pacman -S manjaro-keyring
sudo pacman -Suu
« Last Edit: 07. June 2014, 12:49:38 by Hertz »
Offline letian
  • Neuling
  • Branch: stable
  • Skill: Novice
Thank you Hertz, it worked. I successfully updated.
Offline Hertz
  • Held Mitglied
  • Skill: Novice
Re: [SOLVED] Key could not be imported error during update
« Reply #3 on: 07. June 2014, 13:29:28 »
Hi letian,
I am glad that you have solve your issue.  :)
Offline House712A
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
Offline 1Miguel1
  • Neuling
  • Branch: stable
  • Desktop: KDE, LXQt
  • GPU driver: free
  • Kernel: x86
  • Skill: Intermediate
Re: Key "Joshua Strot <joshua@manjaro.org>" could not be imported error
« Reply #5 on: 15. October 2015, 23:31:25 »
Hi letian,
Code: [Select]
sudo pacman -Syy
sudo pacman -Suu
This worked for me after replacing
Code: [Select]
with
Code: [Select]
sudo pacman -S manjaro-keyring archlinux-keyring
Offline barthodian
  • Neuling
  • I'm new. Be nice!
  • Skill: Advanced
Hi letian,
Code: [Select]
sudo pacman -Syy
sudo pacman -Suu
Also confirming it to work. It's an old post, I know. I just want to make sense of why after so long the automatic updater still don't work on it's own. Had trouble updating with pacman on every machine. Sounds like an issue to address?
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #7 on: 22. March 2016, 02:33:27 »
It's always tricky when a new packager key gets added - which was the case recently again - even though we do our best to make these transitions smooth ...
On the other hand you can say it's good that pacman's security system is a bit over-sensitive ;) ::)
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline barthodian
  • Neuling
  • I'm new. Be nice!
  • Skill: Advanced
« Reply #8 on: 22. March 2016, 02:51:47 »
Oh well, since the workaround isn't that much of a pain in the butt. Thanks for the more technical insight.
