Author Topic: Booting with OpenRC: An alternative to systemd  (Read 76994 times)
Offline schpankme
  • Held Mitglied
  • High Carb / Low Fat / Vegan
  • Branch: Stable
  • Desktop: Qt..i3..OpenRC..Eudev
  • GPU Card: GTX 780 Ti
  • GPU driver: video-nouveau
  • Kernel: 4.4.45-1 x64
  • Skill: Advanced
Re: Booting with OpenRC: An alternative to systemd
« Reply #15 on: 19. June 2014, 05:55:19 »
you could install lxdm-consolekit .. and .. xfce4-session-consolekit
Issue:  also need to configure lxdm and xfce4 to have boot and reboot GUI features
Yep, have these installed, have not figured out how to configure them properly;
still getting dropped to the command-line on boot and reboot.
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
  • Desktop: Xfce, Openbox
  • GPU Card: Intel HD 4000
  • Kernel: Linux 4.4 x86_64
  • Skill: Intermediate
« Reply #16 on: 19. June 2014, 05:58:02 »
Sorry, I think I forgot consolekit-openrc
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #17 on: 19. June 2014, 07:41:20 »
I have one more issue, if you care to hear it.
cpupower defaults to base CPU specs with the "ondemand" governor.
/etc/default/cpupower
My preference is to run CPU min=2600 and max=3600, with ondemand.
How to make this autostart?
cpupower can be set manually:
Code: [Select]
sudo cpupower frequency-set -d 2600000 -u 3340000 -g ondemand
aatoo openrc = fast
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
« Reply #18 on: 19. June 2014, 08:00:34 »
Code: [Select]
Sorry, dont know much about cpupower.
I had tried it once, and it had failed to start on my PC..
All I can tell you is that there is a cpupower-openrc package, dont know whether you are using it ot not..
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #19 on: 19. June 2014, 08:32:08 »
yes - installed "cpupower-openrc" - no joy, must manually set.
Will keep searching for solution.
« Last Edit: 22. June 2014, 04:59:15 by schpankme »
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #20 on: 19. June 2014, 09:03:49 »
You can set manually: sudo cpupower frequency-set -d 2600000 -u 3340000 -g ondemand
How to make "autostart" ?
cpupower
CPU set at min=2600 MHz, max=3340 MHz; with "ondemand governor".
Solution is to edit: /etc/conf.d/cpupower
START_OPTS="-d 2600000 -u 3340000 --governor ondemand"
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Desktop: LXQT/Plasma5, openrc & eudev
  • Kernel: x86_64
  • Skill: Advanced
« Reply #21 on: 19. June 2014, 10:19:29 »
You found out yourself. :)
As general rule, services can be configured in corresponding
/etc/conf.d/<service>
/etc/init.d/<service> reads the file in /etc/conf.d/<service>
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
Re: Booting with OpenRC: An alternative to systemd [general]
« Reply #22 on: 19. June 2014, 11:17:08 »
Here we go for the second update-pack for openRC:
Code: [Select]
### BoxIt memo ###
User philip committed following changes:
 - unstable community i686:  70 new and 67 removed package(s)
 - unstable community x86_64:  70 new and 67 removed package(s)
unstable_community_i686
[New Packages]
acpid-openrc-20140619-1-any.pkg.tar.xz
alsa-utils-openrc-20140619-1-any.pkg.tar.xz
apache-openrc-20140619-1-any.pkg.tar.xz
autofs-openrc-20140619-1-any.pkg.tar.xz
avahi-openrc-20140619-1-any.pkg.tar.xz
bind-openrc-20140619-1-any.pkg.tar.xz
bitlbee-openrc-20140619-1-any.pkg.tar.xz
bluez-openrc-20140619-1-any.pkg.tar.xz
connman-openrc-20140619-1-any.pkg.tar.xz
consolekit-openrc-20140619-1-any.pkg.tar.xz
cpupower-openrc-20140619-1-any.pkg.tar.xz
cronie-openrc-20140619-1-any.pkg.tar.xz
cryptsetup-openrc-20140619-1-any.pkg.tar.xz
cups-openrc-20140619-1-any.pkg.tar.xz
cyrus-sasl-openrc-20140619-1-any.pkg.tar.xz
dbus-openrc-20140619-1-any.pkg.tar.xz
device-mapper-openrc-20140619-1-any.pkg.tar.xz
dhcp-openrc-20140619-1-any.pkg.tar.xz
dhcpcd-openrc-20140619-1-any.pkg.tar.xz
displaymanager-openrc-20140619-1-any.pkg.tar.xz
eudev-openrc-20140619-1-any.pkg.tar.xz
fcron-openrc-20140619-1-any.pkg.tar.xz
fuse-openrc-20140619-1-any.pkg.tar.xz
git-openrc-20140619-1-any.pkg.tar.xz
glibc-openrc-20140619-1-any.pkg.tar.xz
gpm-openrc-20140619-1-any.pkg.tar.xz
haveged-openrc-20140619-1-any.pkg.tar.xz
hostapd-openrc-20140619-1-any.pkg.tar.xz
inetutils-openrc-20140619-1-any.pkg.tar.xz
iptables-openrc-20140619-1-any.pkg.tar.xz
krb5-openrc-20140619-1-any.pkg.tar.xz
libpulse-eudev-5.0-1-i686.pkg.tar.xz
lighttpd-openrc-20140619-1-any.pkg.tar.xz
lirc-utils-openrc-20140619-1-any.pkg.tar.xz
lm_sensors-openrc-20140619-1-any.pkg.tar.xz
lvm2-openrc-20140619-1-any.pkg.tar.xz
mdadm-openrc-20140619-1-any.pkg.tar.xz
metalog-openrc-20140619-1-any.pkg.tar.xz
mpd-openrc-20140619-1-any.pkg.tar.xz
mysql-openrc-20140619-1-any.pkg.tar.xz
networkmanager-openrc-0.9.8.10-7-i686.pkg.tar.xz
nfs-utils-openrc-20140619-1-any.pkg.tar.xz
ntp-openrc-20140619-1-any.pkg.tar.xz
openldap-openrc-20140619-1-any.pkg.tar.xz
openntpd-openrc-20140619-1-any.pkg.tar.xz
openrc-core-0.12.4-17-i686.pkg.tar.xz
openslp-openrc-20140619-1-any.pkg.tar.xz
openssh-openrc-20140619-1-any.pkg.tar.xz
openvpn-openrc-20140619-1-any.pkg.tar.xz
polipo-openrc-20140619-1-any.pkg.tar.xz
postfix-openrc-20140619-1-any.pkg.tar.xz
postgresql-openrc-20140619-1-any.pkg.tar.xz
privoxy-openrc-20140619-1-any.pkg.tar.xz
quota-tools-openrc-20140619-1-any.pkg.tar.xz
rpcbind-openrc-20140619-1-any.pkg.tar.xz
rsync-openrc-20140619-1-any.pkg.tar.xz
rsyslog-openrc-20140619-1-any.pkg.tar.xz
salt-openrc-20140619-1-any.pkg.tar.xz
samba-openrc-20140619-1-any.pkg.tar.xz
sane-openrc-20140619-1-any.pkg.tar.xz
squid-openrc-20140619-1-any.pkg.tar.xz
subversion-openrc-20140619-1-any.pkg.tar.xz
syslog-ng-openrc-20140619-1-any.pkg.tar.xz
transmission-openrc-20140619-1-any.pkg.tar.xz
ufw-openrc-20140619-1-any.pkg.tar.xz
vsftpd-openrc-20140619-1-any.pkg.tar.xz
wpa_supplicant-openrc-20140619-1-any.pkg.tar.xz
xinetd-openrc-20140619-1-any.pkg.tar.xz
ypbind-mt-openrc-20140619-1-any.pkg.tar.xz
ypserv-openrc-20140619-1-any.pkg.tar.xz
[Removed Packages]
acpid-openrc-20140614-1-any.pkg.tar.xz
alsa-utils-openrc-20140614-1-any.pkg.tar.xz
apache-openrc-20140614-1-any.pkg.tar.xz
autofs-openrc-20140614-1-any.pkg.tar.xz
avahi-openrc-20140614-1-any.pkg.tar.xz
bind-openrc-20140614-1-any.pkg.tar.xz
bitlbee-openrc-20140614-1-any.pkg.tar.xz
bluez-openrc-20140614-1-any.pkg.tar.xz
connman-openrc-20140614-1-any.pkg.tar.xz
consolekit-openrc-20140614-1-any.pkg.tar.xz
cpupower-openrc-20140614-1-any.pkg.tar.xz
cronie-openrc-20140614-1-any.pkg.tar.xz
cryptsetup-openrc-20140614-1-any.pkg.tar.xz
cups-openrc-20140614-1-any.pkg.tar.xz
cyrus-sasl-openrc-20140614-1-any.pkg.tar.xz
dbus-openrc-20140614-1-any.pkg.tar.xz
device-mapper-openrc-20140614-1-any.pkg.tar.xz
dhcp-openrc-20140614-1-any.pkg.tar.xz
dhcpcd-openrc-20140614-1-any.pkg.tar.xz
displaymanager-openrc-20140614-1-any.pkg.tar.xz
eudev-openrc-20140614-1-any.pkg.tar.xz
fcron-openrc-20140614-1-any.pkg.tar.xz
fuse-openrc-20140614-1-any.pkg.tar.xz
git-openrc-20140614-1-any.pkg.tar.xz
glibc-openrc-20140614-1-any.pkg.tar.xz
gpm-openrc-20140614-1-any.pkg.tar.xz
haveged-openrc-20140614-1-any.pkg.tar.xz
hostapd-openrc-20140614-1-any.pkg.tar.xz
inetutils-openrc-20140614-1-any.pkg.tar.xz
iptables-openrc-20140614-1-any.pkg.tar.xz
krb5-openrc-20140614-1-any.pkg.tar.xz
lighttpd-openrc-20140614-1-any.pkg.tar.xz
lirc-utils-openrc-20140614-1-any.pkg.tar.xz
lm_sensors-openrc-20140614-1-any.pkg.tar.xz
lvm2-openrc-20140614-1-any.pkg.tar.xz
mdadm-openrc-20140614-1-any.pkg.tar.xz
metalog-openrc-20140614-1-any.pkg.tar.xz
mysql-openrc-20140614-1-any.pkg.tar.xz
networkmanager-openrc-0.9.8.10-6-i686.pkg.tar.xz
nfs-utils-openrc-20140614-1-any.pkg.tar.xz
ntp-openrc-20140614-1-any.pkg.tar.xz
openldap-openrc-20140614-1-any.pkg.tar.xz
openntpd-openrc-20140614-1-any.pkg.tar.xz
openrc-core-0.12.4-16-i686.pkg.tar.xz
openslp-openrc-20140614-1-any.pkg.tar.xz
openssh-openrc-20140614-1-any.pkg.tar.xz
openvpn-openrc-20140614-1-any.pkg.tar.xz
polipo-openrc-20140614-1-any.pkg.tar.xz
postfix-openrc-20140614-1-any.pkg.tar.xz
postgresql-openrc-20140614-1-any.pkg.tar.xz
privoxy-openrc-20140614-1-any.pkg.tar.xz
quota-tools-openrc-20140614-1-any.pkg.tar.xz
rpcbind-openrc-20140614-1-any.pkg.tar.xz
rsync-openrc-20140614-1-any.pkg.tar.xz
rsyslog-openrc-20140614-1-any.pkg.tar.xz
samba-openrc-20140614-1-any.pkg.tar.xz
sane-openrc-20140614-1-any.pkg.tar.xz
squid-openrc-20140614-1-any.pkg.tar.xz
subversion-openrc-20140614-1-any.pkg.tar.xz
syslog-ng-openrc-20140614-1-any.pkg.tar.xz
transmission-openrc-20140614-1-any.pkg.tar.xz
ufw-openrc-20140614-1-any.pkg.tar.xz
vsftpd-openrc-20140614-1-any.pkg.tar.xz
wpa_supplicant-openrc-20140614-1-any.pkg.tar.xz
xinetd-openrc-20140614-1-any.pkg.tar.xz
ypbind-mt-openrc-20140614-1-any.pkg.tar.xz
ypserv-openrc-20140614-1-any.pkg.tar.xz
unstable_community_x86_64
[New Packages]
libpulse-eudev-5.0-1-x86_64.pkg.tar.xz
networkmanager-openrc-0.9.8.10-7-x86_64.pkg.tar.xz
openrc-core-0.12.4-17-x86_64.pkg.tar.xz
[Removed Packages]
networkmanager-openrc-0.9.8.10-6-x86_64.pkg.tar.xz
openrc-core-0.12.4-16-x86_64.pkg.tar.xz
_______________________________________________
manjaro-packages mailing list
manjaro-packages@manjaro.org
http://lists.manjaro.org/mailman/listinfo/manjaro-packages
You can readup on the first one here.
As usual report all issues you might have with this!
Offline handy
  • Global Moderator
  • Desktop: Openbox 3.6.1-3 & Worker :)
  • GPU Card: intel...
  • GPU driver: open-source
  • Kernel: OpenBSD
« Reply #23 on: 19. June 2014, 12:44:55 »
I think that it is so cool that excalibur has put all of this effort into creating a QT only Manjaro spin. In combination with the work that artoo, aaditya & Phil are doing in their efforts to create a systemd & gtk free Manjaro spin, Manjaro is looking like it is going to come up with an Arch based systemd & gtk free release that will end up attracting people from the allover the GNU/Linux distro world. :D
Well done to all concerned in this, it really is a milestone in the GNU/Linux world that I see all of your combined efforts creating. :D :D :D
The ultimate tyranny in a society is not control
by martial law. It is control by the psychological
manipulation of consciousness, through which reality
is defined so that those who exist within do not even
realize that they are in prison.
  —  Barbara Marciniak
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
« Reply #24 on: 20. June 2014, 10:38:14 »
Schpankme, I took liberty to move your two posts to programming in dev talk openrc.
Don't wonder please.  :)
« Last Edit: 20. June 2014, 10:40:09 by artoo »
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #25 on: 20. June 2014, 11:53:28 »
On another positive note: moved to "eudev-openrc"
My System uses 1% less memory, and World of Warcraft video improved by 7 - 10 fps.
Issue:
How to get Thunar to auto-mount and show secondary HDD (/sdb1/Thing2).
aatoo openrc
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
« Reply #26 on: 20. June 2014, 14:29:02 »
Issue:
aatoo openrc
I think I had to rebuild gvfs to get it to display my mounted partitions..
I havent checked, but I think doing yaourt -S gvfs-nosystemd might work..
Another way is building from artoo's packages.. (makepkg -cs, followed by sudo pacman -U <path-of-package-you-want-to-install>)
(You may also need to reboot after installing built packages)
Offline viking60
  • Sr. Mitglied
    • bjoernvold.com
  • Branch: stable
  • Desktop: openbox
  • GPU Card: NVIDIA GT200b [GeForce GTX 275]
  • GPU driver: nonfree
  • Kernel: linux4.1-x86_64
« Reply #27 on: 20. June 2014, 14:40:53 »
It is surprising that Systemd is heavily criticized and a potentially growing hairball that makes it an "accident waiting to happen", now will be used by every distro with 1,5 exceptions:
Gentoo and Manjaro (the 0.5 part).
Ubuntu and Debian are caving in too (why?).
Does that make us Don Quijote and are we not fighting Windmills? Is not this "standardization" of Linux what everybody has been waitng for?
In any case I have a lot of sympathy for Don Quijote and Sancho Panza and personally I have never lost a fight with a Windmill yet  :)
« Last Edit: 21. June 2014, 00:45:19 by viking60 »
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
« Reply #28 on: 20. June 2014, 14:55:15 »
Here are some criticisms of systemd:
http://boycottsystemd.org/
Gentoo (I dont think Manjaro counts yet) is not the only one currently, there's Slackware also, besides CRUX, LSD, and the BSDs.
Offline viking60
  • Sr. Mitglied
    • bjoernvold.com
  • Branch: stable
  • Desktop: openbox
« Reply #29 on: 20. June 2014, 15:47:28 »
Yes that makes sense. And we do like choices and flexibility.
I have noticed that the chief penguin has swung his hammer too:
http://www.phoronix.com/scan.php?page=news_item&px=MTY1MzA
Once this hits stable I am will put openRC on an old low spec box here that runs Manjaro openbox now - I am convinced it will be snappier with OpenRC
