Author Topic: Manjaro i3 Edition: base > rc2/up8/testing  (Read 7097 times)
Offline sebrei
  • Vollwertiges Mitglied
  • i3 wm, jwm-respin, eeepc 901; Dell Latitude E6510;
  • Skill: Intermediate
Re: Manjaro i3 Edition: base > rc2/up8/testing
« Reply #15 on: 08. July 2014, 10:05:00 »
I suppose bad .iso. Try downloading new and burn according to Wiki. It really should work, I have tried on two different machines.
Moral: Es gibt nichts Gutes, außer man tut es.
Offline nomadpenguin
  • Neuling
  • Skill: Novice
« Reply #16 on: 09. July 2014, 03:10:17 »
I'm beginning to think that it's user error.  I just downloaded a new iso and burned it using the instructions on the wiki. I can open applications with meta+d, and switch workspaces with meta+num.  However, it's always in the tabbed layout, and meta+e does not switch to the tiled layout.  I can, however, use meta+shit+space to make a window floating.  meta+enter opens up a borderless terminal in the middle of the screen.  pressing meta-shift-q only results in the letter q being typed.  Is this supposed to be the default behavior, and I'm just using i3 wrong?
Offline sebrei
« Reply #17 on: 18. July 2014, 06:48:59 »
Have a look in your i3 config, it is undern .i3 folder in /home.
You can change all behaiviour to your needs. http://i3wm.org/docs/userguide.html
Offline schpankme
  • Held Mitglied
  • High Carb / Low Fat / Vegan
  • Branch: Stable
  • Desktop: Qt..i3..OpenRC..Eudev
  • GPU Card: GTX 780 Ti
  • GPU driver: video-nouveau
  • Kernel: 4.4.45-1 x64
  • Skill: Advanced
« Reply #18 on: 22. July 2014, 09:23:08 »
anex, et al,
This is my revision of your i3 build, combined with Xfce.
Thank you
i3X peek
i3X desktop
My only obstacle is changing the style and size of the dmenu font.  The syntax below works and look correct, but the fonts stay as default.
i3 config file (v4)
# start dmenu for  launching System programs
bindsym $mod+mod1+space exec dmenu_run -i -p 'Manjaro System' -fn 'Comfortaa:bold:size=15' -nb '#222222' -nf '#7DA555' -sf '#222222' -sb '#7DA555'
# start j4-dmenu-desktop for lunching GUI programs
bindsym $mod+space exec --no-startup-id j4-dmenu-desktop --dmenu="dmenu -i -p 'Manjaro GUI' -fn 'Comfortaa:bold:size=15' -nb '#222222' -nf '#7DA555' -sf '#222222' -sb '#7DA555'"
Offline aaditya
  • OpenRC Team
    • My Website
  • Branch: Testing
  • Desktop: Xfce, Openbox
  • GPU Card: Intel HD 4000
  • Kernel: Linux 4.4 x86_64
« Reply #19 on: 22. July 2014, 15:51:59 »
i3 config file (v4)
I use the xfontsel utility from the xorg-xfontsel package to browse the X fonts and select/copy them.
My dmenu line looks like the following:
Code: [Select]
dmenu_run -fn "-*-helvetica-bold-r-*-*-*-100-*-*-*-*-iso8859-*"
https://wiki.archlinux.org/index.php/X_Logical_Font_Description
Offline dhaunac
  • Neuling
  • Skill: Novice
« Reply #20 on: 20. October 2014, 17:15:21 »
I am currently running i3 under xfce settings and need to have a somewhat stable work enviroment. It seems to be really good, but I don't want to risk going for another installation. I was wondering if you could post how to get to that toolbar, since I would like to get my i3bar in those colors. So I could start to get a similar enviroment by rebuilding it step by step.
« Last Edit: 20. October 2014, 17:17:47 by dhaunac »
Offline anex
  • Support Team
  • Klarity » Manjaro » KDE
  • Branch: beyond unstable
  • Desktop: deepin » awesome » xfce » openbox » lxqt » mate » i3 » gnome » cinnamon » enlightenment » kde » pekwm
  • GPU Card: MSI N660 Gaming 2GD5/OC GeForce GTX 660 2GB
  • GPU driver: non-free
  • Kernel: 318
  • Skill: Advanced
« Reply #21 on: 20. October 2014, 17:29:28 »
you could download the iso and run it in virtual box and copy the configs and modify them for you pretty easily, import, import, import
Offline Bimbada
  • Neuling
  • Skill: Novice
« Reply #22 on: 22. December 2014, 13:54:14 »
@anex
It looks good mate, well done !
Unfortunately I can't try it , I think it's because of my graphic card GTX 750, the driver nvidia got some issues that it doesn't have with the 8.11 ISO's .
Could you please share your profile to ManjaroIso if it's possible of course or somewhere else if you'd like to, thank you .
@serbei
Your config seems good too, good job .
Offline anex
  • Support Team
  • Kernel: 318
  • Skill: Advanced
« Reply #23 on: 22. December 2014, 14:03:11 »
here you go, if you wouldn't mind download it and repost a new link cause that one will die soon
https://www.wuala.com/anex/manjaro-i3-rc1/
Offline Bimbada
  • Neuling
  • Skill: Novice
« Reply #24 on: 22. December 2014, 14:17:41 »
Thank you  ;)
I'll post a new link today no problem .
PS:
New link
i3-overlay.tar.gz https://mega.co.nz/#!3QcEja7Y!tnXv0OyyTUIkwWY_xexVN8TV5AuGBlJEu6EhUtE6Jj4
overlay-livecd.tar.gz https://mega.co.nz/#!aNU1FCJQ!AShxAkYi1I5O8wFb1EF5KaO8_t4b-5WUqruIAmnIotM
« Last Edit: 22. December 2014, 14:51:41 by Bimbada »
Offline mxx
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Openbox/i3wm
  • Kernel: linux4
« Reply #25 on: 22. December 2014, 14:44:55 »
I get panic every time I land in vi
nano would be a panic-neutral option
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #26 on: 21. February 2015, 20:49:24 »
i3 Status bar "can't read temp"
Note that Kernel updates newer than 3.14 change the "temp2_input" path.
To locate new path:  find /sys -name "temp*_input"
.i3status.conf
cpu_temperature 0 {
        format = "CPU: %degrees °C"
        # find /sys -name "temp*_input"
        # old path = "/sys/devices/platform/coretemp.0/temp2_input"
        path = "/sys/devices/platform/coretemp.0/hwmon/hwmon1/temp2_input"
Offline DiscipleOfDante
  • Sr. Mitglied
  • Branch: Unstable
  • Desktop: Plasma 5
  • GPU driver: Free
  • Kernel: linux-ck-x64
« Reply #27 on: 06. April 2015, 18:37:06 »
Is there any plan to make a more recent iso? The one in there is kind of old.
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #28 on: 06. April 2015, 19:15:39 »
you want it ?
Dutch go the dutch site :)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #29 on: 06. April 2015, 19:21:17 »
Yes pleeeeeez! Me too! :)
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
