Author Topic: [How-To] Using ManjaroISO  (Read 18029 times)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« on: 27. December 2012, 15:40:11 »
Video tutorial
I started to work on my ManjaroISO wiki. It explains how to modify the community edition Manjaro E17. Take a look and feel free to improve that post.
« Last Edit: 18. August 2013, 10:53:21 by philm »
Offline dicktater
  • Held Mitglied
  • Skill: Novice
Re: [How-To] Using ManjaroISO
« Reply #1 on: 27. December 2012, 20:58:39 »
Thank you, kind sir!  ;D
The Manjaro Forum Revised Rules  How to Report Issues Properly   Please Read the Manjaro Wiki
Offline cumali
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: stable
  • Desktop: Manjarobox, Xfce
  • GPU Card: İntel
  • GPU driver: free
  • Kernel: Linux38-x86
  • Skill: Novice
« Reply #2 on: 28. December 2012, 17:24:04 »
A good idea. Is not this narrative more easily? Ubuntu or SUSE Studio Is not it easier? http://www.tuxradar.com/content/build-your-own-linux-distribution-easy-way
This job should be easier Manjaro ;)
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
« Reply #3 on: 28. December 2012, 17:37:46 »
We aren't Ubuntu or Suse, so it won't work.
Offline tun in a cellar
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Hybrid graphic card (Intel/ATI)
  • GPU driver: free (the discrete card is switched off)
  • Kernel: linux313-x64 (the latest if possible)
  • Skill: Advanced
« Reply #4 on: 28. December 2012, 17:43:28 »
[spoiler]
[/spoiler]
Very interesting... Many thanks Phil
Why doing it yourself when manjaro-system can do it for you?
Offline ShalokShalom
  • Vollwertiges Mitglied
  • ~ Love like the way you wish to harvest Love ~
« Reply #5 on: 04. March 2013, 16:31:45 »
How to save Panel and Plasma Settings ?
Offline fassil
  • Support Team
  • Branch: stable/unstable
  • Desktop: E19/E20
  • GPU driver: free
  • Kernel: Linux314 & 318
  • Skill: Intermediate
« Reply #6 on: 28. March 2013, 15:15:41 »
Hi all,
If you copy (as root) the current hidden rep ~/.e in e17-overlay/etc/skel & replace the .local, .config & xinitrc by your current ones, you refind all your enlightenment settings in the buildiso (profiles, keybindings, ect) & you can also copy an .opera, in exemple. A kind of backup...
Inspired by the remastersys method.
A+
« Last Edit: 28. March 2013, 15:21:16 by fassil »
"Are you enlightened ?"
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #7 on: 01. April 2013, 07:06:29 »
New video is online ;) first post ...
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
« Reply #8 on: 01. April 2013, 09:01:52 »
Code: [Select]
sudo pacman -S manjaroiso manjaroiso-profiles
Added catalyst repo into:
Code: [Select]
/home/yfdogan/work/manjaroiso/configs/kde/pacman-x86_64.conf
Code: [Select]
[yfdogan@manjaro ~]$ cat /home/yfdogan/work/manjaroiso/configs/kde/pacman-x86_64.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
#CacheDir    = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
HoldPkg     = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst   = manjaro-system pacman
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#UseDelta
#TotalDownload
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
#SigLevel = Optional TrustedOnly
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official packages
# Manjaro Linux supports with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
[basis]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[platform]
[addon]
[extra]
[community]
[catalyst]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[basis-multilib]
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
Code: [Select]
[yfdogan@manjaro kde]$ sudo buildiso
    _     _              _                  _
   | |   | |            (_)                (_)
   | | _ | | ____ ____   _  ____  ____ ___  _  ___  ___
   | || || |/ _  |  _ \ | |/ _  |/ ___) _ \| |/___)/ _ \
   | || || ( ( | | | | || ( ( | | |  | |_| | |___ | |_| |
   |_||_||_|\_||_|_| |_|| |\_||_|_|   \___/|_(___/ \___/
                      (__/
 > KDE installation (kde-image)
 mkiso : Configuration Settings
        working directory:   work-x86_64
               image name:   none
====> Creating working directory: work-x86_64
====> Installing packages to 'work-x86_64/kde-image/'
 basis is up to date
 platform is up to date
 addon is up to date
 extra is up to date
 community is up to date
 catalyst is up to date
 basis-multilib is up to date
:: There are 11 members in group kde-telepathy:
:: Repository extra
   1) telepathy-kde-accounts-kcm
   2) telepathy-kde-approver
   3) telepathy-kde-auth-handler
   4) telepathy-kde-contact-applet
   5) telepathy-kde-contact-list
   6) telepathy-kde-contact-runner
   7) telepathy-kde-filetransfer-handler
   8) telepathy-kde-integration-module
   9) telepathy-kde-presence-applet
   10) telepathy-kde-send-file
   11) telepathy-kde-text-ui
Enter a selection (default=all):
:: There are 5 members in group telepathy:
:: Repository extra
   1) telepathy-gabble  2) telepathy-haze
   3) telepathy-idle  4) telepathy-rakia
   5) telepathy-salut
resolving dependencies...
warning: cannot resolve "mhwd-db>=0.2.4-2", a dependency of "mhwd-db-catalyst"
:: There are 2 providers available for phonon-backend:
:: Repository extra
   1) phonon-gstreamer  2) phonon-vlc
Enter a number (default=1):
:: The following package cannot be upgraded due to unresolvable dependencies:
      mhwd-db-catalyst
Do you want to skip the above package for this upgrade? [y/N]
error: failed to prepare transaction (unexpected error)
Switched to catalyst-unstable :
Code: [Select]
 basis is up to date
 addon is up to date
 extra is up to date
error: failed retrieving file 'catalyst-unstable.db' from mirror.dacentec.com : The requested URL returned error: 404 Not Found
error: failed to update catalyst-unstable (download library error)
error: target not found: mhwd-db-catalyst
« Last Edit: 01. April 2013, 09:10:56 by YFDogan »
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
Offline Warez
  • Mirror Support Team
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU Card: GeForce GT 740M / Intel® HD Graphics 4000
  • Kernel: 4.1.6-3-MANJARO x86_64
« Reply #9 on: 01. April 2013, 09:52:11 »
Started to build E17  8)
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #10 on: 01. April 2013, 13:23:46 »
Removed 'catalyst' from pacman.conf and switched all repos to unstable and it works:
Code: [Select]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir     = /
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#UseDelta
#TotalDownload
CheckSpace
#VerbosePkgLists
# REPOSITORIES
#       [repo-name]
[basis-unstable]
[platform-unstable]
[addon-unstable]
[extra-unstable]
[community-unstable]
[basis-multilib-unstable]
[multilib-unstable]
#[custom]
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #11 on: 01. April 2013, 16:16:35 »
With same settings I built Manjaro-Mate and it was succesfull. But KDE fails again.
BTW, if someone wants to build a community release like E17 and KDE,
Code: [Select]
pacman -S manjaroiso manjaroiso-profilesis not enough. You can get E17 and KDE profiles with:
Code: [Select]
pacman -S manjaroiso manjaroiso-profiles manjaroiso-community-profiles
Offline Warez
  • Branch: Stable
  • Desktop: Cinnamon
« Reply #12 on: 01. April 2013, 18:25:00 »
i have succesfully build a e17 iso. :)
Sent from my SGM2 using Tapatalk
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #13 on: 01. April 2013, 18:56:03 »
Wit building KDE:
Code: [Select]
kde-l10n-it-4.10.1-1-any     9.4 MiB   581K/s 00:17 [###########################] 100%
 kde-l10n-pl-4.10.1-1-any    15.7 MiB   456K/s 00:35 [###########################] 100%
 kde-l10n-pt-4.10.1-1-any     5.5 MiB   504K/s 00:11 [###########################] 100%
 kde-l10n-ru-4.10.1-1-any    21.5 MiB   663K/s 00:33 [###########################] 100%
 kde-l10n-ro-4.10.1-1-any     2.2 MiB   579K/s 00:04 [###########################] 100%
 kde-l10n-sv-4.10.1-1-any    15.5 MiB   669K/s 00:24 [###########################] 100%
 kde-l10n-tr-4.10.1-1-any     3.2 MiB   401K/s 00:08 [###########################] 100%
 kde-l10n-uk-4.10.1-1-any    26.1 MiB   600K/s 00:45 [###########################] 100%
:: Retrieving packages from community-unstable...
 hunspell-pl-20120911-...   899.3 KiB   553K/s 00:02 [###########################] 100%
(67/67) checking package integrity                   [###########################] 100%
rm: cannot remove 'work-x86_64/lng-image/opt/manjaro/lng/thunderbird-1*': No such file or directory
pacman.conf and packages-kde of /home/yfdogan/work/manjaroiso/configs/kde/:
Code: [Select]
## Base Packages
base
linux-firmware
lsb-release
manjaro-firmware
manjaro-release
memtest86+
syslog-ng
## Kernel
KERNEL
## Extra Base Packages
grub-bios
mkinitcpio-nfs-utils
os-prober
pkg-config
squashfs-tools
sudo
syslinux
xdg-utils
xdg-user-dirs
## Compression Codecs
arj
lzop
unrar
unzip
xz
zip
## needed by cli-installer
dialog
dmidecode
gptfdisk
parted
pv
rsync
tcpdump
wget
## efi support
efilinux-efi
grub-efi-i386
grub-efi-x86_64
gummiboot-efi
refind-efi
## Filesystem Packages
btrfs-progs
dmraid
dosfstools
testdisk
nilfs-utils
nfs-utils
ntfsprogs
## Fonts
terminus-font
ttf-bitstream-vera
ttf-dejavu
ttf-inconsolata
ttf-indic-otf
ttf-liberation
ttf-ms-fonts
ttf-linux-libertine
ttf-source-sans-pro
## Network
b43-fwcutter
iptables
ipw2100-fw
ipw2200-fw
mobile-broadband-provider-info
modemmanager
nbd
networkmanager
networkmanager-dispatcher-ntpd-systemd
openresolv
usb_modeswitch
wpa_actiond
wpa_supplicant
zd1211-firmware
## Laptop power management
acpid
cpupower
ethtool
sdparm
hdparm
laptop-mode-tools
wireless_tools
xorg-xset
## ucode for new cpus
amd-ucode
intel-ucode
Code: [Select]
## Language Support
#American English
hunspell-en
#libreoffice-en-US
#Belarusian
firefox-i18n-be
thunderbird-i18n-be
libreoffice-be
#British English
firefox-i18n-en-gb
thunderbird-i18n-en-gb
libreoffice-en-GB
#Brazilian Portuguese
firefox-i18n-pt-br
thunderbird-i18n-pt-br
>kde kde-l10n-pt_br
libreoffice-pt-BR
#Bulgarian
firefox-i18n-bg
thunderbird-i18n-bg
libreoffice-bg
>kde kde-l10n-bg
#Deutsch
firefox-i18n-de
thunderbird-i18n-de
hunspell-de
>kde kde-l10n-de
libreoffice-de
#Espanol
firefox-i18n-es-es
thunderbird-i18n-es-es
hunspell-es
libreoffice-es
>kde kde-l10n-es
#Espanol (Argentina)
firefox-i18n-es-ar
thunderbird-i18n-es-ar
#Francais
firefox-i18n-fr
thunderbird-i18n-fr
hunspell-fr
libreoffice-fr
>kde kde-l10n-fr
#Italian
firefox-i18n-it
thunderbird-i18n-it
hunspell-it
libreoffice-it
>kde kde-l10n-it
#Polish
firefox-i18n-pl
thunderbird-i18n-pl
hunspell-pl
libreoffice-pl
>kde kde-l10n-pl
#Portuguese
firefox-i18n-pt-pt
thunderbird-i18n-pt-pt
libreoffice-pt
>kde kde-l10n-pt
#Russian
firefox-i18n-ru
thunderbird-i18n-ru
libreoffice-ru
>kde kde-l10n-ru
#Romanian
firefox-i18n-ro
thunderbird-i18n-ro
hunspell-ro
libreoffice-ro
>kde kde-l10n-ro
#Swedish
firefox-i18n-sv-se
thunderbird-i18n-sv-se
libreoffice-sv
>kde kde-l10n-sv
#Turkish
firefox-i18n-tr
thunderbird-i18n-tr
libreoffice-tr
>kde kde-l10n-tr
#Ukrainian
firefox-i18n-uk
thunderbird-i18n-uk
libreoffice-uk
>kde kde-l10n-uk
#cleanup
>cleanup thunderbird-1*
>cleanup mime-types*
>cleanup libnotify*
>cleanup hunspell-1*
>cleanup firefox-1*
>cleanup startup-notification*
Code: [Select]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir     = /
SyncFirst   = pacman
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#UseDelta
#TotalDownload
CheckSpace
#VerbosePkgLists
# PGP signature checking
# NOTE: None of this will work without running `pacman-key --init` first.
# The compiled in default is equivalent to the following line. This requires
# you to locally sign and trust packager keys using `pacman-key` for them to be
# considered valid.
# If you wish to check signatures but avoid local sign and trust issues, use
# the following line. This will treat any key imported into pacman's keyring as
# trusted.
# For now, off by default unless you read the above.
SigLevel = Never
# REPOSITORIES
#       [repo-name]
[manjaro-lng]
Server = file:///opt/manjaro/lng
Code: [Select]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir     = /
SyncFirst   = pacman
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#UseDelta
#TotalDownload
CheckSpace
#VerbosePkgLists
# considered valid.
# trusted.
SigLevel = Never
# REPOSITORIES
#       [repo-name]
[manjaro-pkgs]
Server = file:///opt/manjaro/pkgs
Code: [Select]
## Xorg Drivers
>free_uni xorg-drivers
>free_uni xf86-video-ati
xf86-video-intel
>free_uni xf86-video-nouveau
>free_uni ati-dri
intel-dri
>free_uni nouveau-dri
## Bumblebee Support
bumblebee
virtualgl
KERNEL-bbswitch
>x86_64 lib32-virtualgl
## Proprietary Drivers
>nonfree_uni catalyst-input
>nonfree_uni catalyst-server
>nonfree_uni catalyst-video
>nonfree_uni catalyst-utils
>nonfree_uni KERNEL-catalyst
>nonfree_uni catalyst-legacy-utils
>nonfree_uni KERNEL-catalyst-legacy
>nonfree_uni nvidia-utils
>nonfree_uni KERNEL-nvidia
>nonfree_uni nvidia-legacy-utils
>nonfree_uni KERNEL-nvidia-legacy
>nonfree_x64 lib32-catalyst-utils
>nonfree_x64 lib32-catalyst-legacy-utils
>nonfree_x64 lib32-nvidia-utils
>nonfree_x64 lib32-nvidia-legacy-utils
>nonfree_x64 lib32-gcc-libs
>nonfree_x64 lib32-zlib
## Virtualbox Drivers
>free_uni virtualbox-guest-utils
>free_uni KERNEL-virtualbox-guest-modules
## Xorg Packages
libxaw
libxpm
libxvmc
pangox-compat
## Xorg x86_64 Packages
>x86_64 lib32-libxvmc
>x86_64 lib32-libgl
>free_x64 lib32-ati-dri
>x86_64 lib32-intel-dri
>free_x64 lib32-nouveau-dri
## Cleanup Xorg packages
>cleanup xf86-input*
Code: [Select]
### Manjaro Packages
## Xorg
mhwd
mhwd-db
mhwd-db-catalyst
## Xorg Packages
inxi
libdnet
mesa
mesa-demos
>x86_64 lib32-mesa-demos
netkit-bsd-finger
uriparser
xf86-input-acecad
xf86-input-aiptek
xf86-input-evdev
xf86-input-joystick
xf86-input-keyboard
xf86-input-mouse
xf86-input-synaptics
xf86-input-void
xf86-input-wacom
xinetd
xorg-server
xorg-server-utils
xorg-twm
xorg-utils
xorg-xinit
## Artwork
manjaro-artwork
## KDE (minimal base)
kdebase
kdeadmin
kde-telepathy
kdeartwork
kdebindings
kdegraphics
kdemultimedia
kdenetwork
kdepim
kdeplasma-addons
kdetoys
kdeutils
kmymoney
krename
oxygen-icons
## KDE (everything else)
kdeadmin-kuser
kdeadmin-kcron
kdeadmin-ksystemlog
kdemultimedia-kmix
kdesdk-kate
kdegraphics-kgamma
kdegraphics-gwenview
kdegraphics-ksnapshot
kdegraphics-okular
kdeutils-ark
kdeutils-kgpg
kdeutils-print-manager
kdeutils-sweeper
kdeplasma-addons-applets-icontasks
kdeplasma-applets-networkmanagement
live-installer
## Packages for Sound and Audio
gstreamer0.10-bad-plugins
gstreamer0.10-ffmpeg
gstreamer0.10-ugly-plugins
manjaro-alsa
manjaro-pulse
## Devel Packages
autoconf
automake
binutils
bison
fakeroot
flex
gcc
git
libtool
m4
make
patch
patchutils
svn
yaourt
## Applications
#rekonq
#kdepim-kmail
k3b
digikam
#smplayer
kdemultimedia-dragonplayer
simple-scan
amarok
partitionmanager-svn
gimp
imagewriter
vlc
skype
converseen
soundkonverter
## Package management
pamac
## GTK
firefox
thunderbird
oxygen-gtk2
oxygen-gtk3
kde-gtk-config
## Java
icedtea-web-java7
## Printing
manjaro-printer
## Office
libreoffice-en-US
#libreoffice-base
libreoffice-calc
#libreoffice-draw
#libreoffice-impress
libreoffice-kde4
#libreoffice-math
#libreoffice-postgresql-connector
libreoffice-writer
Code: [Select]
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir     = /
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#UseDelta
#TotalDownload
CheckSpace
#VerbosePkgLists
# REPOSITORIES
#       [repo-name]
[basis-unstable]
[platform-unstable]
[addon-unstable]
[extra-unstable]
[multilib-unstable]
#[custom]
And pacman.conf from my current system:
Code: [Select]
[yfdogan@manjaro ~]$ cat /etc/pacman.conf
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir     = /
Architecture = auto
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#UseDelta
#TotalDownload
CheckSpace
#VerbosePkgLists
# REPOSITORIES
#       [repo-name]
[basis-unstable]
[platform-unstable]
[addon-unstable]
[extra-unstable]
[multilib-unstable]
#[custom]
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #14 on: 01. April 2013, 21:51:23 »
And tried again:
Code: [Select]
firefox-i18n-tr-19.0....   255.5 KiB   468K/s 00:01 [###########################] 100%
 thunderbird-i18n-tr-1...   370.5 KiB   319K/s 00:01 [###########################] 100%
 libreoffice-tr-4.0.1-...     6.1 MiB   555K/s 00:11 [###########################] 100%
 firefox-i18n-uk-19.0....   286.1 KiB   453K/s 00:01 [###########################] 100%
 thunderbird-i18n-uk-1...   397.5 KiB   335K/s 00:01 [###########################] 100%
 libreoffice-uk-4.0.1-...     6.2 MiB   599K/s 00:11 [###########################] 100%
 kde-l10n-pt_br-4.10.1...    26.7 MiB   645K/s 00:42 [###########################] 100%
 kde-l10n-bg-4.10.1-1-any  1079.2 KiB   554K/s 00:02 [###########################] 100%
 kde-l10n-de-4.10.1-1-any    35.7 MiB   705K/s 00:52 [###########################] 100%
 kde-l10n-es-4.10.1-1-any    22.0 MiB   718K/s 00:31 [###########################] 100%
 kde-l10n-fr-4.10.1-1-any    42.2 MiB   808K/s 00:53 [###########################] 100%
 kde-l10n-it-4.10.1-1-any     9.4 MiB   738K/s 00:13 [###########################] 100%
 kde-l10n-pl-4.10.1-1-any    15.7 MiB   780K/s 00:21 [###########################] 100%
 kde-l10n-pt-4.10.1-1-any     5.5 MiB   750K/s 00:08 [###########################] 100%
 kde-l10n-ru-4.10.1-1-any    21.5 MiB   766K/s 00:29 [###########################] 100%
 kde-l10n-ro-4.10.1-1-any     2.2 MiB   636K/s 00:03 [###########################] 100%
 kde-l10n-sv-4.10.1-1-any    15.5 MiB   702K/s 00:23 [###########################] 100%
 kde-l10n-tr-4.10.1-1-any     3.2 MiB   377K/s 00:09 [###########################] 100%
 kde-l10n-uk-4.10.1-1-any    26.1 MiB   801K/s 00:33 [###########################] 100%
 hunspell-pl-20120911-...   899.3 KiB   656K/s 00:01 [###########################] 100%
(68/68) checking package integrity                   [###########################] 100%
rm: cannot remove 'work-x86_64/lng-image/opt/manjaro/lng/mime-types*': No such file or directory
There might be something wrong with KDE profile. Isn't it?
