Author Topic: Issue With Mirrors and upgrade  (Read 1655 times)
Offline screaming jet
  • Vollwertiges Mitglied
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: Various Nvidia
  • GPU driver: non-free
  • Kernel: linux39-x64
  • Skill: Novice
« on: 26. May 2014, 08:46:20 »
For some reason I can't upgrade one of my machines. I've done the other 3 fine but I am getting:
Code: [Select]
[media@batcave ~]$ sudo pacman -Syy
--2014-05-26 16:41:51--  http://manjaro.mirror.serversaustralia.com.au/stable/core/x86_64/core.db
Resolving manjaro.mirror.serversaustralia.com.au (manjaro.mirror.serversaustralia.com.au)... 27.50.85.3
Connecting to manjaro.mirror.serversaustralia.com.au (manjaro.mirror.serversaustralia.com.au)|27.50.85.3|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 128021 (125K) [application/x-tar]
Saving to: ‘/var/lib/pacman/sync/core.db.part’
100%[======================================>] 128,021      417KB/s   in 0.3s
2014-05-26 16:41:52 (417 KB/s) - ‘/var/lib/pacman/sync/core.db.part’ saved [128021/128021]
--2014-05-26 16:41:52--  http://manjaro.mirror.serversaustralia.com.au/stable/core/x86_64/core.db.sig
HTTP request sent, awaiting response... 404 Not Found
2014-05-26 16:41:52 ERROR 404: Not Found.
--2014-05-26 16:41:54--  http://manjaro.mirror.serversaustralia.com.au/stable/extra/x86_64/extra.db
Length: 1741679 (1.7M) [application/x-tar]
Saving to: ‘/var/lib/pacman/sync/extra.db.part’
100%[======================================>] 1,741,679    670KB/s   in 2.5s
2014-05-26 16:41:57 (670 KB/s) - ‘/var/lib/pacman/sync/extra.db.part’ saved [1741679/1741679]
--2014-05-26 16:41:57--  http://manjaro.mirror.serversaustralia.com.au/stable/extra/x86_64/extra.db.sig
2014-05-26 16:41:57 ERROR 404: Not Found.
--2014-05-26 16:41:59--  http://manjaro.mirror.serversaustralia.com.au/stable/community/x86_64/community.db
Length: 2363912 (2.3M) [application/x-tar]
Saving to: ‘/var/lib/pacman/sync/community.db.part’
100%[======================================>] 2,363,912    651KB/s   in 3.5s
2014-05-26 16:42:03 (658 KB/s) - ‘/var/lib/pacman/sync/community.db.part’ saved [2363912/2363912]
--2014-05-26 16:42:03--  http://manjaro.mirror.serversaustralia.com.au/stable/community/x86_64/community.db.sig
2014-05-26 16:42:03 ERROR 404: Not Found.
--2014-05-26 16:42:05--  http://manjaro.mirror.serversaustralia.com.au/stable/multilib/x86_64/multilib.db
Length: 117251 (115K) [application/x-tar]
Saving to: ‘/var/lib/pacman/sync/multilib.db.part’
100%[======================================>] 117,251      465KB/s   in 0.2s
2014-05-26 16:42:06 (465 KB/s) - ‘/var/lib/pacman/sync/multilib.db.part’ saved [117251/117251]
--2014-05-26 16:42:06--  http://manjaro.mirror.serversaustralia.com.au/stable/multilib/x86_64/multilib.db.sig
2014-05-26 16:42:06 ERROR 404: Not Found.
I am connected online as I've posted this from the machine
Can someone please help me with this issue?
« Last Edit: 26. May 2014, 08:49:15 by screaming jet »
Offline Hertz
  • Held Mitglied
  • Skill: Novice
Re: Issue With Mirrors and upgrade
« Reply #1 on: 26. May 2014, 08:56:04 »
Hi screaming jet,
try for resolve it to reboot the system, and repeat the command line
Code: [Select]
sudo pacman -Syy
if don't work you must do:
Code: [Select]
sudo pacman-mirrors -g
and
Code: [Select]
sudo pacman -Syyu
if don't work again you must:
Code: [Select]
sudo pacman -Syy
and
Code: [Select]
sudo pacman -S manjaro-keyring
and
Code: [Select]
sudo pacman -Suu
if don't work again too:
Code: [Select]
sudo pacman-key -r CB6CDD17
sudo pacman-key --lsign-key CB6CDD17
or
Code: [Select]
sudo pacman-key -r 5C0102A6
sudo pacman-key --lsign-key 5C0102A6
  • Branch: Stable
  • Desktop: XFCE
  • Skill: Novice
« Reply #2 on: 26. May 2014, 13:02:44 »
I went through all of the above and I got it to do the update prior to the:
Code: [Select]
But it was still throwing the errors up. Have these servers not synced over yet or is there another reason for this? Because it seems like it would be another issue seeing I updated 3 other machines all without a hitch. Obviously I would like to resolve this before the next update.
Offline Hertz
  • Held Mitglied
  • Skill: Novice
« Reply #3 on: 26. May 2014, 13:47:52 »
Hi screaming jet,
Code: [Select]
maybe this could help you for resolve your problem, I have search on the forum if someone has same issue and I have found this:
https://forum.manjaro.org/index.php?topic=139.msg635#msg635
or
https://forum.manjaro.org/index.php?topic=2099.msg16038#msg16038
Good luck.
« Last Edit: 26. May 2014, 13:53:36 by Hertz »
  • Branch: Stable
  • Desktop: XFCE
  • Skill: Novice
« Reply #4 on: 26. May 2014, 14:28:15 »
Thanks. I've had a look at those threads and nothing has helped.
Offline Hertz
  • Held Mitglied
  • Skill: Novice
« Reply #5 on: 26. May 2014, 14:31:20 »
Hi screaming jet,
Sorry but I have spent my possibility for to be help you. :'(
  • Branch: Stable
  • Desktop: XFCE
  • Skill: Novice
« Reply #6 on: 26. May 2014, 14:35:33 »
Hi screaming jet,
No need to be sorry. I appreciate your effort and assistance.
Offline Enindu
  • Sr. Mitglied
  • Keep it simple stupid..!
  • Desktop: Xfce
  • GPU driver: Free
  • Kernel: Linux 4.5.1-1-ARCH
  • Skill: Novice
« Reply #7 on: 26. May 2014, 14:42:16 »
Try deleting all *db files from /var/lib/pacman/sync/ directory and doing Hertz commands again?
Offline Hertz
  • Held Mitglied
  • Skill: Novice
« Reply #8 on: 26. May 2014, 14:47:07 »
Hi screaming jet,
Thank you very much for your thought.
I have a question:
perhaps have you commented with # other server e maintain and enable only that in your country in /etc/pacman.d/mirrorslist.conf?
@Enindu:
Quote
Thanks this operation had missed.
« Last Edit: 26. May 2014, 15:09:58 by Hertz »
