Author Topic: Binary repo for LXQt (Arch compatible) available  (Read 9638 times)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
Re: Binary repo for LXQt (Arch compatible) available
« Reply #30 on: 23. May 2014, 13:25:48 »
New stuff for the repo ? http://blog.lxde.org/?p=1127  8)
Yes, I read that yesterday on the mailing list. I dont know if he will write the PKGBUILD or if I do it.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #31 on: 23. May 2014, 15:32:35 »
Update done, see HERE.
Offline sdch
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: nvidia
  • GPU driver: nvidia
  • Kernel: 3.12 LTS x86_64
  • Skill: Novice
« Reply #32 on: 23. May 2014, 18:38:10 »
i think pcmanfm qt is using libfm instead of libfm-git
menu-cache is used a dependency instead of menu-cache -git
i was able to uninstall menu-cache and install  menu-cache -git but it was not possible in libfm
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #33 on: 23. May 2014, 18:45:00 »
pcmanfm-qt-git uses libfm, yes. I don't know why.
menucache-git replace menucache, that it provides.
More info HERE.
Offline arnt
  • Core Team
« Reply #34 on: 24. May 2014, 22:45:53 »
Great work, Esclapion!
Octopi 0.4.0 will support this awesome DE.
Thanks.
Offline sdch
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: nvidia
  • Skill: Novice
« Reply #35 on: 25. May 2014, 07:59:15 »
Qterminal not working after yesterdays update of qtermwidget
Code: [Select]
LxQtGuiPlatformPlugin constructed
LxQtGuiPlatformPlugin::systemIconThemeName() is called
TRANSLATIONS_DIR: Loading translation file "qterminal_en.qm" from dir /usr/shar/qterminal/translations
load success: false
LxQtGuiPlatformPlugin::platformHint() is called
Properties constructor called
Canot open file "/home/john/.config/qterminal.org/qterminal_bookmarks.xml"
default KB_LAYOUT_DIR:  "/usr/share/qtermwidget4/kb-layouts/"
loadAllColorSchemes
qterminal: symbol lookup error: qterminal: undefined symbol: _ZN11QTermWidget15etTerminalFontER5QFont
« Last Edit: 25. May 2014, 08:57:21 by sdch »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #36 on: 25. May 2014, 11:40:09 »
Works always for me, but I dont use the english translation, and it seems to be the problem.
(edit)
qterminal is not a part of official LXQt. It's a separate development.
« Last Edit: 25. May 2014, 12:17:03 by Esclapion »
Offline LoE
  • Neuling
    • HelLoEworld
  • Branch: Stable
  • Desktop: Xfce
  • GPU Card: AMD A10, R9 270x, 560GTX Ti
  • GPU driver: non-free
  • Kernel: linux312-x64
  • Skill: Intermediate
« Reply #37 on: 17. June 2014, 17:08:20 »
Thanks for your effort with the repo. I had some trouble building one of the packages out of the AUR for LXQt, but this made it much easier (and less time-consuming).
Offline schpankme
  • Held Mitglied
  • High Carb / Low Fat / Vegan
  • Branch: Stable
  • Desktop: Qt..i3..OpenRC..Eudev
  • GPU Card: GTX 780 Ti
  • GPU driver: video-nouveau
  • Kernel: 4.4.45-1 x64
  • Skill: Advanced
« Reply #38 on: 25. September 2014, 05:21:13 »
juffed: error while loading shared libraries: libenca.so.0: cannot open shared object file: No such file or directory
sudo pacman -S enca
Thx Mr Green.
Shouldn't you have a green avatar ?
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #39 on: 25. September 2014, 13:58:31 »
Whats the simple answer for replacing "gnome-keyring" with QT alternative?
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • Kernel: 4.6
« Reply #40 on: 25. September 2014, 14:09:55 »
that might be it: https://forum.manjaro.org/index.php?topic=16679.0
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #42 on: 03. October 2014, 11:39:46 »
Any suggestion on actual "qt" based File manger, that can be installed ?
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #43 on: 03. October 2014, 12:13:37 »
For the moment, it's pcmanfm-qt, full qt5. The desktop is managed by it, it's not independent.
Offline schpankme
  • Held Mitglied
  • Branch: Stable
  • Skill: Advanced
« Reply #44 on: 03. October 2014, 12:44:43 »
OK, we'll just stick with pcmanfm-qt, it works very well.
I'm looking for something slick like Dolphin, but don't want to pay the KDE tax to use it!   :P
