Author Topic: Binary repo for LXQt (Arch compatible) available  (Read 9640 times)
Offline Sunburst
  • Neuling
  • Skill: Novice
Re: Binary repo for LXQt (Arch compatible) available
« Reply #15 on: 18. May 2014, 15:09:01 »
Thank you very much, Esclapion.
Offline hype
  • Neuling
  • Branch: stable & testing
  • Desktop: LXQt & KDE
  • GPU Card: Nvidia & Intel
  • Kernel: 4.3 x86 & x64
  • Skill: Intermediate
« Reply #16 on: 20. May 2014, 10:38:27 »
Great work Esclapion.
Will this update as new versions of applications get released? (from git or final)
Should I use your repo or is it something similar in Arch repos? Why did you create your repo?
« Last Edit: 20. May 2014, 10:42:15 by hype »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #17 on: 20. May 2014, 11:40:16 »
Hi hype,  :)
Quote
yes, from time to time, and sure for the 0.8.
Quote
lol, you can do as you want.  ;) There are almost 30 modules to compile with yaourt and on my PC (old, but a quad hyperthreaded at 2,8 Ghz) almost 30'. With binary repo, no time of compilaton, only download and installation.
This repo is also a working snapshot of the development, I tested it. If something is wrong, I discuss with the devs before updating it.
And at the begin, some modules were not compiling. Now, only one is missing in AUR.
Else, I follow the mailing list and survey all the new things, for example QT5 coming.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline sdch
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: nvidia
  • GPU driver: nvidia
  • Kernel: 3.12 LTS x86_64
  • Skill: Novice
« Reply #18 on: 21. May 2014, 04:49:01 »
hi esclapion i didnt find the network manager in LXQT?
Offline Mr Green
  • Neuling
  • Skill: Novice
« Reply #19 on: 21. May 2014, 08:03:00 »
Thanks for sharing your repo, really wanted to test lxqt out and you have done all the work for me  ;)
If you do not mind can I add repo to ArchBang wiki on lxqt to allow our users to try it out? Of course I will refer to you in the guide.
MrG
best things in life are systemd free....
Offline Mr Green
  • Neuling
  • Skill: Novice
« Reply #20 on: 21. May 2014, 09:11:48 »
juffed would not start
Code: [Select]
a                                [######################] 100%
[mrgreen@arch ~]$ juffed
juffed: error while loading shared libraries: libenca.so.0: cannot open shared object file: No such file or directory
easy fix
Code: [Select]
sudo pacman -S enca
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #21 on: 21. May 2014, 10:49:30 »
MrG
Hi,
Sure, you can.  :D We are in the Linux community, and my job is mainly based on PKGBUILD of AUR.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #22 on: 21. May 2014, 10:56:20 »
Hi sdch,  :)
The icon, you mean ? Because network manager is sure installed.
Try a :
Code: [Select]
pacman -Qs networkmanager
you must obtain :
Code: [Select]
local/network-manager-applet 0.9.8.10-1
    GNOME frontends to NetWorkmanager
local/networkmanager 0.9.8.10-1
    Network Management daemon
local/networkmanager-dispatcher-ntpd 1.0-6
    Dispatcher Script for ntpd
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #23 on: 21. May 2014, 11:10:23 »
Code: [Select]
easy fix
Code: [Select]
sudo pacman -S enca
Normally, on a Manjaro, enca is preinstalled, I just checked.
Offline Mr Green
  • Neuling
  • Skill: Novice
« Reply #24 on: 21. May 2014, 11:33:42 »
Well I am running ArchBang so we do not ship with it... easy fix though. Got sddm running autologin just setting up lxqt now
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #25 on: 21. May 2014, 11:41:47 »
When autologin is enabled, policykit doesnt work for me. So, to configure wifi, I have a problem, especially for the live.
Offline Mr Green
  • Neuling
  • Skill: Novice
« Reply #26 on: 21. May 2014, 11:44:57 »
I am running lxqt under a VM, autologin works although autostarting does seem not to work all the time. Loading cmst (connman gui and tray icon) to see it that works. Want to get rid of network manager.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #27 on: 21. May 2014, 11:52:37 »
Hmmm, I forgot conman in my list, thanks. I tried slim/lxdm/sddm, and problems in case of autologin. Until now, sddm was the best.
I didn't try kdm because it brings a lot of KDE with it : 484 Mo of kdebase-workspace, lol.   ;D
Offline Mr Green
  • Neuling
  • Skill: Novice
« Reply #28 on: 21. May 2014, 11:55:17 »
cmst works only it does not like system tray, so not sure how compatible it will be. I going to run it 'cmst -m', wired seems ok. Wallpaper is not being set via sddm (even with login) but no big deal.
Offline axel668
  • Neuling
« Reply #29 on: 23. May 2014, 13:14:17 »
New stuff for the repo ? http://blog.lxde.org/?p=1127  8)
