Author Topic: NEW : Iso LXQT 0.7 alpha available !!!  (Read 17051 times)
Offline john29
  • Sr. Mitglied
  • Branch: Manjaro unstable
  • Desktop: Arch + Manjaro CINNAMON
  • GPU Card: ATi HD 7850 pcs +
  • GPU driver: open-source drivers
  • Kernel: manjaro + Arch Kernel 4.3-ck 4.2 x86-x64
  • Skill: Intermediate
Re: NEW : Iso LXQT 0.7 alpha available !!!
« Reply #60 on: 12. May 2014, 13:48:02 »
Kwin -stanalone -git work really well I use it for over a year,and Rob has done a lot of work compiz 8, & 9,but just saying you can use alter
windows manager to openbox
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #61 on: 12. May 2014, 13:54:34 »
You have kde_base installed or not ? If yes, for me, it's not standalone.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #62 on: 12. May 2014, 14:14:40 »
i have successfully installed lxqt on the manjaro net edition.
i have edited my post accordingly: https://forum.manjaro.org/index.php?topic=13257.msg120051#msg120051
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #63 on: 12. May 2014, 14:19:24 »
To answer the question of this post, no. I  note that you issue the command twice, so the order must be bad for dependencies.
I have my own list, that I use only once. And some modules are not in this list or in AUR.
Offline john29
  • Sr. Mitglied
« Reply #64 on: 12. May 2014, 14:37:04 »
Kdebase-workspace is not install,and you cannot install kwin-standalone-git if you have it install
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #65 on: 12. May 2014, 18:25:34 »
If it interests somebody, I did a little .desktop to reboot without confirmation :
Code: [Select]
[Desktop Entry]
Version=1.0
Type=Application
Name=Reboot
Comment=Restart the PC without confirmation
Icon=gnome-session-reboot
Exec=systemctl reboot
NoDisplay=false
Categories=Utility;
StartupNotify=false
Terminal=false
NoDisplay=true
and I added it to the taskbar.
I don't know the command for logout, by cons.*
(edit)
*killall lxqt-session works, but... ?
« Last Edit: 12. May 2014, 18:57:47 by Esclapion »
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #66 on: 12. May 2014, 18:53:09 »
If it interests somebody, I did a little .desktop to reboot without onfirmation :
thanks a lot.
can you do a "shutdown" icon as well?
if you do not know how to do it, try to use one of the following commands:
sudo shutdown 0
sudo poweroff
sudo halt
sudo init 0
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #67 on: 12. May 2014, 18:56:05 »
It was only an example.  ;) If the users will have buttons, it's easy to do. But I can't leave a button "reboot" or "halt" without confirmation in the ISO, too dangerous for beginners.
Offline LCJr
  • Held Mitglied
  • Skill: Novice
« Reply #68 on: 12. May 2014, 19:30:39 »
sudo shutdown 0
sudo poweroff
sudo halt
sudo init 0
No need for sudo.
systemctl reboot / systemctl poweroff
reboot / poweroff
Not a suggestion Esclapion  :)  For anyone looking for a KDE-free file manager we have qtfm and doublecmd-qt in the repos.  doublecmd-qt requires udisks if you want to be able to see your other volumes and optical drives.  That should really be listed as an optional depend at the very least.  Of course there's more qt fm's in the AUR.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #69 on: 12. May 2014, 19:35:31 »
udisk2 is installed by default. Udisk not, I dont know why, maybe a an oversight on my part ? But from pcman, I see all the others partitions and I can mount them.
(edit)
for the moment, pcmanfm-qt is the official file manager, I dont think to replace it. It's an important part.
« Last Edit: 12. May 2014, 19:39:32 by Esclapion »
Offline LCJr
  • Held Mitglied
  • Skill: Novice
« Reply #70 on: 12. May 2014, 19:53:40 »
Like I said not a suggestion for you.  Udisks has been pretty much replaced by udisks2 so you don't need it.  I understand you want to stay with a 'pure' LXQT setup.
The suggestion was for those who might not be thrilled with PCManFM-QT in it's current state of development.
Offline sdch
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: nvidia
  • GPU driver: nvidia
  • Kernel: 3.12 LTS x86_64
  • Skill: Novice
« Reply #71 on: 12. May 2014, 20:37:21 »
is there any chance that a version of lxqt 0.7 with out need to compile (per-compiled versions) will arrive in repo?
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #72 on: 12. May 2014, 20:49:07 »
0.7 is an alpha, and the whole project is in develoment. So, too early.
Offline sdch
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: nvidia
  • Skill: Novice
« Reply #73 on: 12. May 2014, 20:59:00 »
just as i thought  :)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #74 on: 12. May 2014, 22:40:31 »
As E-mail notifier, I use checkgmail. Works perfect, with an icon in the notification area.
But only for gmail.  ;)
For weather, typhoon is very light, but no icon.
