Author Topic: NEW : Iso LXQT 0.7 alpha available !!!  (Read 14494 times)
Offline LCJr
  • Held Mitglied
  • Skill: Novice
Re: NEW : Iso LXQT 0.7 alpha available !!!
« Reply #15 on: 10. May 2014, 02:53:26 »
Esclapion are you in contact with the LXQT folks?  Or do you know where bugs should be reported?  Just found out pcmanfm-qt doesn't care for Buuf.  Icon set uses mainly 128x128 pixel icons and pcmanfm isn't scaling them in the main window.
That drag and drop menu in pcmanfm is pretty annoying too.  And the "Do you really want to log out" popup.
Also any idea what's needed to get conky to display?  Got it:
Code: [Select]
own_window_class Conky
own_window_argb_visual no
Getting some artifacts on the network icon.
« Last Edit: 10. May 2014, 03:15:08 by LCJr »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #16 on: 10. May 2014, 11:42:10 »
Hi LCJr,  :)
Look at the link, in the OP. There is something about bug report.
I'm on the mailing list, but I use only it for blocking problems, It's not done for that.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline aranwe
  • Vollwertiges Mitglied
  • Skill: Intermediate
« Reply #17 on: 10. May 2014, 11:57:51 »
How much RAM is eating?
Troll kalla mik.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #18 on: 10. May 2014, 12:04:24 »
It's not especially optimized for that now. In VBox, with the 32 bits, I use :
thus, 124 Mo.
« Last Edit: 10. May 2014, 12:06:27 by Esclapion »
Offline aranwe
« Reply #19 on: 10. May 2014, 12:16:21 »
Wow this is nice.
Tnx.
Troll kalla mik.
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #20 on: 10. May 2014, 15:29:53 »
i agree.
in my opinion, there are still some setting options missing, e.g. to turn off the log out popup and other stuff. but this desktop is not finished yet.
at this point, i am not going to install it on my main system, but i am going to follow the development closely in the future - it is a really interesting project and i definitely share their mindset.
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #21 on: 10. May 2014, 15:38:56 »
For the bad init of qupzilla, a simple solution :
Code: [Select]
rm -rf .config/qupzilla
It must solve definitively the problem. May be, I will change it with an opening on manjaro.org.
For the necessary pacman -Syy, who must be currentlly necessary for all distros now, two solutions :
- suppress the PhilM optimization about suppressing pacman databases, and I lose few Mo ;
- discuss with Arnt about that.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #22 on: 10. May 2014, 15:41:10 »
Code: [Select]
all DE have that, no ? It asks for confirmation, it's all.
What exactly do you want ?
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #23 on: 10. May 2014, 15:45:53 »
Code: [Select]
yes. all DEs have that.
i would like a settings option to turn the confirmation dialogue off.
this cannot be achieved by you, though. it must be implemented into lxqt.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #24 on: 10. May 2014, 15:56:43 »
OK. In xfce, I have two dangerous button to do that. Left for reboot, and right for shutdown, without confirmation.
May be I can create a shortcut in the taskar for reboot ?
For Qupzilla, not solved. I will have a look on the Net.
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • Kernel: linux46 - x64
« Reply #25 on: 10. May 2014, 16:02:14 »
Installed latest 64 bit iso.  And since I had previous version, it meets expectation.
And I again think it's very suitable for most linux beginners and for slightly advanced users needing some less bloated DE.
(I think Enlightenment is creeping to be more bloated, Elementary is not minimal;  and...openbox, fluxbox, awesome, etc is only suitable for more advanced users)
So, thanks again.
Oh, PcManFM.
Still no single-click?
It's available in PcManFM of other Manjaro's DE.
Why not in LXQT?
ps: have to manually put numlock in .xprofile
autologin is fine.
And why not linux313 instead of 312? Not an issue, just asking.
Personal opinion - confirmation for shutdown/reboot is fine and should be default. But there must be a way to disable that.
Life is a sexually transmitted disease with a 100% mortality rate.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #26 on: 10. May 2014, 16:32:55 »
Thanks for the test.
Answer for the single-click (PCMan) :
Quote
Oops!
I forgot to hide that option.
It does not work at the moment.
While it's very easy to enable single click, it's not as easy to
handle hover-selection.
If items are activated on click, then we need other ways to select them.
Qt has no built-in support for selecting items on hover.
So I need to implement this myself for all kinds of item view, which
is more than trivial.
I'll do it later.
Thus, demand done.
For numlock, I can easily add it, but with wich value : on or off ?
Qupzilla is a good browser, and qt based, but it has this problem on unstable initialization, and its git version refers to kde-wallet, that I do not want for the moment.
Arora doesn't work, and is orphaned since several years.
So, for the moment, I think to replace qupzilla by midori.
« Last Edit: 10. May 2014, 16:41:07 by Esclapion »
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #27 on: 10. May 2014, 16:41:46 »
there is also cupzilla-qt5
Dutch go the dutch site :)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #28 on: 10. May 2014, 16:50:37 »
qupzilla-qt5 ?
I skipped it, because of 0 votes.
I tried now : 105 Mo* to install, and same initialization problem.
(edit)
*14,7 Mo installed, but I dont know what it adds.
Why not icecat ?
(re-edit)
I do a try with icecat
« Last Edit: 10. May 2014, 16:57:55 by Esclapion »
Offline LCJr
  • Held Mitglied
  • Skill: Novice
« Reply #29 on: 10. May 2014, 17:28:13 »
64-bit with Nvidia drivers.  Shows ~350-360 Mb in conky.  ~330 Mb with ps_mem.  edit> That's on actual hardware not a vm.
I think you want off.  They were discussing that for Openbox and what I got out of it was having it on by default screws with laptops.
« Last Edit: 10. May 2014, 17:47:04 by LCJr »
