Author Topic: Compiz 0.9 series package available  (Read 42628 times)
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
Re: Compiz 0.9.11 series package available
« Reply #60 on: 11. October 2014, 18:05:05 »
was protobuf updated in unstable?
I updated last night and it looks like ccsm for compiz will not load after the protobuf update
Check /var/log/pacman.log to see what was updated when.
J.
Hitten by the door in the back when I left Manjaro.
Offline ManofJELLO
  • Jr. Mitglied
  • Branch: unstable
  • Desktop: Openbox
  • GPU Card: Nvidia 750 ti
  • GPU driver: non-free
  • Kernel: linux43-x64
  • Skill: Intermediate
« Reply #61 on: 11. October 2014, 18:08:51 »
I should have been more affirmative, I wasn't guessing that is was updated.
It was updated last night from
[2014-10-11 01:11] [PACMAN] upgraded protobuf (2.5.0-4 -> 2.6.0-2)
Code: [Select]
[manofjello@manjaro ~]$ ccsm
  File "/usr/bin/ccsm", line 92, in <module>
    import compizconfig
ImportError: libprotobuf.so.8: cannot open shared object file: No such file or directory
Just downgraded for now
« Last Edit: 11. October 2014, 18:19:41 by ManofJELLO »
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • Kernel: linux314 x64
  • Skill: Advanced
« Reply #62 on: 11. October 2014, 18:37:31 »
New rebuilt compiz-manjaro packages that fix the issue will be committed to Unstable branch in a few minutes.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #63 on: 11. October 2014, 18:39:50 »
Can a 0.8 user let me know if 0.8 ccsm is affected also?
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
« Reply #64 on: 11. October 2014, 19:09:52 »
Running MATE 1.8  on Manjaro unstable with Compiz 0.8 here, no problems after the last update.
J.
Offline ManofJELLO
  • Jr. Mitglied
  • Branch: unstable
  • Desktop: Openbox
« Reply #65 on: 11. October 2014, 19:48:56 »
Thank you sir, you are awesome.  Everything works great now, love Manjaro
« Last Edit: 11. October 2014, 19:51:23 by ManofJELLO »
Offline trzalica
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: nVidia Geforce 8800 GT
  • GPU driver: Non-free
  • Kernel: Linux 4.1 x64
« Reply #66 on: 11. October 2014, 19:52:52 »
In Compiz 0.8 with 340.xx drivers, after some time (sometimes ~5 minutes, sometimes ~30 minutes) I can only move mouse cursor and can't do a thing until I reboot PC... With 304.xx everything works great but would really like to have newer drivers and Compiz in the same time.
Offline ManofJELLO
  • Jr. Mitglied
  • Branch: unstable
  • Desktop: Openbox
« Reply #67 on: 11. October 2014, 20:09:13 »
considering that 0.8 is no longer supported to my knowledge, and that only the rewrite 0.9 is being updated, a fix for your issue might not be possible.
I'm on 0.9 and the newest nvidia driver with no issues, if that helps.  YMMV
Offline trzalica
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Xfce
« Reply #68 on: 11. October 2014, 20:41:00 »
I've already promised Rob that I will try Compiz 0.9 but couldn't find some time for experimenting. Would really like to try it... Guys, I would like to know how you configure effects in 0.9 - CCSM like in 0.8 or directly in a file? And would like to know which effects are available in 0.9?!?
Offline masolit
  • Vollwertiges Mitglied
  • Branch: stable
  • Desktop: KDE
  • GPU Card: intel-nVidia
  • Kernel: 3.14.20-1-MANJARO
  • Skill: Novice
« Reply #69 on: 11. October 2014, 21:40:58 »
yees, solution reinstall libcompizconfig from aur
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #70 on: 12. October 2014, 02:48:42 »
J.
Are you sure you're running the new protobuf package from unstable? (2.6.0-2)
It really is very easy to swap between the 2 versions.
For Xfce user:
To swap to 0.9:
Code: [Select]
sudo pacman -S compiz-manjaro(then log out and in)
To swap back to 0.8:
Code: [Select]
sudo pacman -S compiz-xfce(then log out and in)
Answer yes about any conflicts.
You can quickly test Compiz 0.9 in a matter of minutes, and swap back to 0.8 if you don't like it in seconds.
They keep their configuration separate so you can mess with 0.9 as much as you like and if you decide to swap back to 0.8 your configuration will be untouched.
Rather than asking for a list of what's in CCSM, etc., why don't you just quickly try it out :P
Thanks.
I'm testing it myself now directly. It seems also compizconfig-python needs rebuilding too.
Package updates will be in Unstable in a few minutes.
« Last Edit: 12. October 2014, 02:54:06 by Rob »
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
« Reply #71 on: 12. October 2014, 11:07:15 »
Yes, I am sure that I am running protobuf 2.6.0-2
Code: [Select]
[jeannie@Manjaro ~]$ pacman -Ss protobuf
extra/protobuf 2.6.0-2 [Installiert]
    Protocol Buffers - Google's data interchange format
extra/protobuf-c 1.0.2-1
    Protocol Buffers implementation in C
extra/python2-protobuf 2.6.0-2
    Python 2 bindings for Google Protocol Buffers
J.
Offline trzalica
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Xfce
« Reply #72 on: 12. October 2014, 14:17:03 »
For Xfce user:
To swap to 0.9:
Code: [Select]
Code: [Select]
Thanks.
Ok Rob, I'll try it today :)
Offline darso
  • Held Mitglied
  • Keep 'er between the hedges!
  • Branch: OpenRC-Stable
  • Desktop: OpenBox+XFCE
  • GPU Card: nVidia GT610
  • Skill: Novice
« Reply #73 on: 12. October 2014, 15:08:30 »
Hi guys, figured I'd give compiz another go, didn't like it before on XFCE and still don't really.
I have a little problem though.  After installing compiz with the above command and then uninstalling it with "sudo pacman -R" I have lost my panels in XFCE, if I press the "super" key the menu comes up but no panel is visable, I also un-installed the deps that installed with compiz through pamac, all is working fine in Mate though not in XFCE.  I had also lost my right click but after removing the compiz-***.conf file I got my right click back, still no panels though, can anyone point me in the right direction to repair this without another re-install please?  I have tried to re-install XFCE and the goodies, this did not work either.
Cheers,
darso.
It must be difficult... for those who have taken authority as the truth, rather than truth as the authority.
-G. Massey, Egyptologist.
Linux Counter Reg Number #578558
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #74 on: 13. October 2014, 05:36:21 »
Cheers,
darso.
Double check you've removed all compiz packages.
Code: [Select]
pacman -Qs compiz
When you removed Compiz there was instructions about clearing saved sessions, follow them.
Here they are again:
Code: [Select]
$ sudo pacman -R compiz-manjaro
[sudo] password for korrode:
checking dependencies...
Packages (1): compiz-manjaro-0.9.11.2-7.1
Total Removed Size:   21.20 MiB
:: Do you want to remove these packages? [Y/n] y
(1/1) removing compiz-manjaro                                              [------------------------------------------] 100%
  -> Updating icon cache...
 -> Updating XDG menu database...
  -> Recompiling the GSettings database...
**                     XFCE USERS                           **
** It's recommended you clear your saved sessions before    **
** logging out and back in:                                 **
** Menu -> Settings -> Session and Startup -> Session tab   **
**              'Clear saved sessions' button               **
** Make sure 'Save session for future logins' is NOT ticked **
** in the log out window.                                   **
** Log out and back in, then Xfwm4 should be restored.      **
