Author Topic: Compiz 0.9 series package available  (Read 42627 times)
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
Re: Compiz 0.9.11 series package available
« Reply #30 on: 30. July 2014, 15:31:30 »
I changed the pkgbuild as you said, still emerald-git tries to remove compiz-manjaro.
Using emerald0.9 from aur worked though.
The reason why I wanted to give  compiz 0.9 a try was that I hoped to get rid of the problems with compiz 0.8 and  window refreshing under Nvidia >= 334 with my gpu's power not set to maximum in nvidia-settings.
The flickering I mentioned for ccsm with Compiz 0.9 only goes away when setting my gpu's power to max performance in nvidia-settings, so the problems with Compiz and Nvidia  non-free seem to be present in compiz 0.9 too.
Is there a website to report compiz 0.9 bugs?
J.
Hitten by the door in the back when I left Manjaro.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • GPU driver: non-free
  • Kernel: linux314 x64
  • Skill: Advanced
« Reply #31 on: 30. July 2014, 15:35:28 »
https://bugs.launchpad.net/compiz
Well something went wrong or you typo'd or whatever, because the adjustments to the PKGBUILD i listed enable you to build and install Emerald so long as you have the current compiz-manjaro package installed, which is compiz-manjaro 0.9.11.2-4
« Last Edit: 30. July 2014, 15:38:10 by Rob »
Offline Kat
  • Sr. Mitglied
  • Don't Believe What You Cannot See
  • Branch: unstable
  • Desktop: KDE 0.8.11-pre1 Gnome 0.8.10 RC1
  • GPU Card: Ati 6870
  • Kernel: linux312-x64
  • Skill: Intermediate
« Reply #32 on: 30. July 2014, 15:37:22 »
Log out/in after entering 'emerald' there is there's any issue.
Hmm, thumbnail plugin crashed X when i enabled it (which certainly isn't great), though when i killed X and re-logged in, it has since been working fine.
You did as i advised here?
Because i am running emerald-git with Compiz 0.9 right now and it's working fine for me.
I don't understand the confusion with Emerald.There are 0 conflicts.  I installed this last night,install went perfect, compiz was running.Had emerald and emerald themes installed as well. ONLY thing I could not install was fusion-icon. I needed that to run it at startup.. I could have made a launcher for it to start at boot,  BUT, I would have rather used Icon.  BUT, could not install so reverted back. Done!!
It is better to keep your mouth shut and be thought a fool than to open it and remove all doubt. (Mark Twain)
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
« Reply #33 on: 30. July 2014, 15:39:18 »
Seems there is a known fix/patch for compiz0.9 whch has not been included due to nVidia/canonical licensing problems, see here:
https://bbs.archlinux.org/viewtopic.php?pid=1428789#p1428789
J,
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #34 on: 30. July 2014, 15:41:52 »
The modifications i mentioned are for the emerald-git package, maybe the emerald package works fine. I thought i heard emerald-git was needed for compiz0.9, maybe that is incorrect.
Certainly compiz-manjaro meets the package dependencies for "emerald":
Code: [Select]
depends=('compiz-core' 'libwnck' 'gtk2' 'libxres' 'shared-mime-info' 'xdg-utils' \
         'desktop-file-utils' 'hicolor-icon-theme')
compiz-manjaro provides 'compiz-core', so building emerald would not fail due to package deps.
Try the normal emerald package as Kat suggests, Jeannie.
J,
I'll investigate.
Offline Kat
  • Sr. Mitglied
  • Branch: unstable
« Reply #35 on: 30. July 2014, 15:44:16 »
Code: [Select]
I'll investigate.
No Rob, NO modifications needed what so ever. I just entered
Code: [Select]
yaourt -S emerald emerald-themes DONE!!
The wiki is our friend!!  ;)
https://wiki.manjaro.org/index.php/Compiz_and_Emerald
@jeannie. One question. Did you completely uninstall the older compiz  one first? I did.
« Last Edit: 30. July 2014, 15:53:43 by Kat »
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
« Reply #36 on: 30. July 2014, 15:54:22 »
Code: [Select]
yaourt -S emerald will install emerald compatible for compiz 0.8, yaourt -S emerald0.9 will install emerald compatible for compiz 0.9
J.
P.S. The arch wiki only deals with compiz 0.8, so it's kind of outdated in regards of compiz.
Offline Kat
  • Sr. Mitglied
  • Branch: unstable
« Reply #37 on: 30. July 2014, 15:59:02 »
J.
I had 0 problems with it
Edit: OH. Just got an update with 53 updates!! for kde . Good luck with this
« Last Edit: 30. July 2014, 16:01:28 by Kat »
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #38 on: 30. July 2014, 16:01:20 »
i checked out fusion-icon and it is simply incompatible with compiz 0.9
Offline Kat
  • Sr. Mitglied
  • Branch: unstable
« Reply #39 on: 30. July 2014, 16:02:21 »
cool Rob.. if there was only a way we could make it compatible would be perfect!! Thank you
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #40 on: 30. July 2014, 16:06:05 »
Well it could be done of course.
normal emerald package didn't work for me with Compiz0.9, but emerald-git was fine.
Offline Kat
  • Sr. Mitglied
  • Branch: unstable
« Reply #41 on: 30. July 2014, 16:07:23 »
YEP. Thats what I;m hoping  ;) Pretty PLEASE!!!  ;D Back to the drawing board!! Rob!!
« Last Edit: 30. July 2014, 16:10:45 by Kat »
Offline Kat
  • Sr. Mitglied
  • Branch: unstable
« Reply #42 on: 30. July 2014, 16:08:30 »
 wow weird, normal worked for me!!
« Last Edit: 30. July 2014, 16:23:53 by Kat »
Offline coolthingy450
  • Vollwertiges Mitglied
  • Using GNU/Linux since 2013. Started at 2010
  • Branch: Arch/CentOS/Kaos
  • Desktop: Xfce/KDE5
  • GPU Card: GeForce GTX 965M
  • GPU driver: Non-free driver
  • Kernel: Linux Natsuko 4.4.5-1-ARCH
« Reply #43 on: 31. July 2014, 04:44:39 »
Thank you for the notice. I was prepared to just use Xfwm4 for normal use, or kwin (I don't like to use KDE dependencies) If I wanted to have special effects. But I do use the workspaces a lot.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Skill: Advanced
« Reply #44 on: 31. July 2014, 20:42:11 »
Kat is would be helpful to me if you could really triple-check and confirm that you are definitely running "compiz-manjaro" (not still accidentally somehow running "compiz-gtk-standalone" or something else) and that you are definitely running the package called "emerald" (not "emerald-git" or anything else) and that Emerald is definitely working (i.e. install "emerald-themes", open that Emerald Theme Selector config app and make sure you can in fact swap to different themes) and that it all continues to work after a reboot.
It can have implications not just for this package and myself, but for all AUR compiz packages and their maintainers (who i am in contact and coordinate with) regarding how we set up our provides arrays.
