Author Topic: all mirrors show an error after pacman mirrors-g  (Read 1803 times)
Offline csmcpb
  • Neuling
« on: 30. March 2014, 10:40:25 »
As above which makes it impossible to install any packages. Any ideas how to sort this?
Offline Hertz
  • Held Mitglied
  • Skill: Novice
Re: all mirrors show an error after pacman mirrors-g
« Reply #1 on: 30. March 2014, 11:10:15 »
Hi csmcpb,
try this series of command by terminal mode:
Code: [Select]
$ sudo pacman-mirrors -g
Code: [Select]
$ sudo pacman -Syy
Code: [Select]
$ sudo pacman-key -r 5C0102A6
Code: [Select]
$ sudo pacman-key --lsign-key 5C0102A6
Code: [Select]
$ sudo pacman -Syyu
Code: [Select]
$ sudo pacman -Suu
« Last Edit: 30. March 2014, 11:12:54 by Hertz »
Offline csmcpb
  • Neuling
« Reply #2 on: 30. March 2014, 11:27:04 »
hi hertz
that has helped a bit but has only fixed 1 mirror and that was in australia, the rest all show errors still
Offline Hertz
  • Held Mitglied
  • Skill: Novice
« Reply #3 on: 30. March 2014, 11:34:38 »
hi hertz
hi csmcpb,
please could you post here the output for see what can be happened?
Offline csmcpb
  • Neuling
« Reply #4 on: 30. March 2014, 11:51:19 »
i cant add an attachment of my output i keep getting an error. when i input what you asked me above i get not errors and the key is updated but again when i do a pacman-mirrors -g i still get errors from all mirrors apart from australia, im in the uk so couldnt get any further away!!
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #5 on: 30. March 2014, 11:53:53 »
Hi,
Are you on stable or unstable ?
You probably have an Internet problem : I do the try now, and it works perfectly. A firewall, proxy, something of that sort ?
How are you connected to the Net ?
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline csmcpb
  • Neuling
« Reply #6 on: 30. March 2014, 12:03:36 »
I'm on stable, no proxy And firewall is not turned on. My internet speed is around 70 mbs so should get a half decent connection even from a laptop and I can browse the web from Firefox fine is just the mirrors that appear to be an issue . iv usually connect using wireless but have tried with an Ethernet cable but still get the same result!
« Last Edit: 30. March 2014, 12:06:46 by csmcpb »
Offline Shadow Warrior
  • Mirror Support Team
  • Branch: Testing
  • Desktop: openbox from first ever version
  • GPU Card: Advanced Micro Devices [AMD/ATI] Wrestler [Radeon HD 6250]
  • GPU driver: non free
  • Kernel: Linux manjaro 4.4.8-1-MANJARO i686
  • Skill: Novice
« Reply #7 on: 30. March 2014, 14:42:48 »
Post what the errors says in the terminal.. that would give us a better idea of the issue you have.
are you putting this in as a command
Code: [Select]
pacman mirrors-g as that won't work
it should be
Code: [Select]
Iv'e just tried on a particularly weak signal in the back end of nowhere and its all OK
Offline csmcpb
  • Neuling
« Reply #8 on: 31. March 2014, 12:29:52 »
Thanks for all your help guys but got my problem solved, it was all to do with my nameservers in resolve.conf. changed them to the Google nameservers and now my mirrors sync as they should and my downloads fly!
Offline Hertz
  • Held Mitglied
  • Skill: Novice
« Reply #9 on: 31. March 2014, 21:03:59 »
Hi csmcpb,
i'm glad that you have solved your problem with DNS server configuration.  :)
