Author Topic: pamac - simple graphical package manager for Manjaro Linux  (Read 90001 times)
0 Members and 2 Guests are viewing this topic.
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
Re: pamac - simple pacman gui for Manjaro Linux
« Reply #60 on: 31. December 2012, 14:53:31 »
fairly to say i dont use manjaro package manager... i use Pacmanxg4  , its a nice packagemanager , it spread using can handle┬┤s aur/normal repository kill the orphans and i dont know if that works. It kan do Rankmirrors... but on some part its not native enough but its not to say it  hurts me.
with this you can see all of thinks what you have gona install or what you remove it blocks cause off te depencies  you have to choose when it can further.
i does this with installing pnmixer, is ask me to remove xfce4-pnmixer. i could do Y or N  ..
with Pamac is a look a like of gnome-package kit..,  its doesn ask... i choose Y and then  some thing flases with ( ! ) and it off, and pamac is after then Unusable :) i have latest from testing..
mayby is better to clear it out ? like option not to check but like pacmanxg4 when you klick on it you see install or remove.. so  if i have xfce-pnmixer installed and you want install pnmixer ; it Blocks the installation standard  but whill you further then do you have manualy remove the xfce4-pnmixer, not in a other session but check them as remove then knows the browser that you wanna remove it.
its not for irritating something, but as that gona be the main packagemanager then it must be resisted like that , not it gona break and will be unusable :) and broken..
the options like gnome-packagekit seems to be unuseble... on this case??
« Last Edit: 31. December 2012, 14:55:25 by ringo32 »
Dutch go the dutch site :)
Offline guinux
  • Core Team
    • Manjaro
  • Branch: unstable
  • Desktop: Xfce
  • Skill: Guru
« Reply #61 on: 31. December 2012, 18:46:15 »
Of course you can't compare a stable program with one in alpha stage.
@Philm: can you try again with 0.2.7 ?
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #62 on: 31. December 2012, 19:04:45 »
Seems to work now. Tested it both ways. pnmixer-xfce4 <> pnmixer
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #63 on: 31. December 2012, 19:06:13 »
hmm....it  is better then the last version it did works again....
strange    :o
oh i have 0.26-1 :)
« Last Edit: 31. December 2012, 19:09:49 by ringo32 »
Offline YFDogan
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
« Reply #64 on: 31. December 2012, 20:40:52 »
After installing pamac-0.2.7-1 , it doesn't placed itself into KDE menu, and it's look isn't regular KDE look.
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #65 on: 01. January 2013, 00:41:11 »
now happy new year ive got the new 0.27 updated still  dificulty with depencies handling..
i do delete Evolution-data i know its a depencies of evolution... give a thing  so i select backon... it say no package selecto on
so i try delete openbox i know there is some depencies then i get this  :o
that pnmixer where fine, it does the job forward and revert..
but deleting a depencies its hurt.... but must also be suggesting it about..
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #66 on: 01. January 2013, 00:47:31 »
fairly to say it did a stepforward openbox selected or unselect it you cand select  some obmenu like that only for openbox, it unselected  you cant select it but you must select openbox. i dont know it was after the break...that happend... shel do a restart to morrow normal it must ask what he must install to what its needs... but now aint working :) so i have first a fresh start :)
its broken now but it still online but basic function is off :D
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #67 on: 01. January 2013, 17:14:36 »
but if the error in pamac package manager it float also to the update, my advice is just, Drop the update. you have also a nice updater.. Kalu.., it spread news and new updates, dont drop something when aint broken.. you prefer putting more energy in the base Pamac,  looking is ok, it looks almost to  Gnome-package kit, but i hope it can be more adult. like  some button like Chromium on right corner to have some more options like rankmirrors. but personal how it handle in pacmanxg4 is apreciate too.. giving good mix of terminal and gui use..
its in begin stadium... update manager is just too much :) you have a nice one it works..
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #68 on: 04. January 2013, 13:39:02 »
Still lot of work to do on this one ...
Offline vanlong441
  • Artwork Team
  • Skill: Novice
« Reply #69 on: 05. January 2013, 03:32:53 »
+1. Also working here in 0.2.7-1.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #70 on: 24. January 2013, 22:53:12 »
0.3.1 got released. tell us your findings ...
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #71 on: 24. January 2013, 23:03:54 »
cannot find in the packages... i dont use unstable :) dont need some intermediate brakings :) mayby future if have a second pc :)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #72 on: 25. January 2013, 00:06:44 »
I always link also direct downloads of pamac ;)
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #73 on: 25. January 2013, 03:00:28 »
hmm hide and seek :)
Offline guinux
  • Core Team
    • Manjaro
  • Branch: unstable
  • Desktop: Xfce
  • Skill: Guru
« Reply #74 on: 25. January 2013, 09:51:11 »
Here it is: http://repo.manjaro.org.uk/addon-unstable/x86_64/pamac-0.3.1-1-any.pkg.tar.xz
It can now be launched as user and use Polkit and Dbus to get authorization and run transactions (with also many fixes) .
Please give feedback.  ;D
