Author Topic: pamac - simple graphical package manager for Manjaro Linux  (Read 89994 times)
0 Members and 2 Guests are viewing this topic.
Offline Yoyo
  • Vollwertiges Mitglied
    • Deb Linux
  • Branch: Stable
  • Desktop: Xfce
  • GPU Card: Intel HD Graphics 2500, Nvidia Geforce GO 7300
  • GPU driver: free, non-free
  • Kernel: linux319 (x86_64)
  • Skill: Intermediate
Re: pamac - simple pacman gui for Manjaro Linux
« Reply #30 on: 17. December 2012, 00:03:59 »
installed and working
Very nice :)
Offline YFDogan
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
« Reply #31 on: 17. December 2012, 01:11:15 »
When installing only one package it is working fine. But if I choose more packages to install it is closing automatically. And an error message:
Code: [Select]
  File "/usr/share/pamac/transaction.py", line 35, in init_transaction
    t = handle.init_transaction(cascade = True)
alpm.error: transaction could not be initialized, pm_errno 10
« Last Edit: 17. December 2012, 02:21:52 by YFDogan »
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #32 on: 17. December 2012, 08:57:22 »
It is still early alpha software. Thx for the report.
Offline guinux
  • Core Team
    • Manjaro
  • Branch: unstable
  • Desktop: Xfce
  • Skill: Guru
« Reply #33 on: 17. December 2012, 13:19:02 »
@YFDogan: I need more details, run pamac in a terminal with:
Code: [Select]
sudo /usr/share/pamac/pamac.py
and tell me what packages you want to install or remove and what are the terminal outputs.
Offline vanlong441
  • Artwork Team
  • Skill: Novice
« Reply #34 on: 17. December 2012, 13:23:35 »
sudo /usr/share/pamac/pamac.py gave me the below and nothing showed up while it opened fine when navigating to Pamac using the menus.
Code: [Select]
[manjaro@manjaro ~]$ sudo /usr/share/pamac/pamac.py
[sudo] password for manjaro:
  File "/usr/share/pamac/pamac.py", line 12, in <module>
    import transaction
  File "/usr/share/pamac/transaction.py", line 12, in <module>
    interface.add_from_file('gui/dialogs.glade')
  File "/usr/lib/python3.3/site-packages/gi/types.py", line 47, in function
    return info.invoke(*args, **kwargs)
gi._glib.GError: Failed to open file 'gui/dialogs.glade': No such file or directory
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #35 on: 17. December 2012, 15:19:19 »
Code: [Select]
[yfdogan@manjaro ~]$ sudo /usr/share/pamac/pamac.py
[sudo] password for yfdogan:
  File "/usr/share/pamac/pamac.py", line 11, in <module>
    import config
  File "/usr/share/pamac/config.py", line 13, in <module>
    from transaction import ErrorDialog
  File "/usr/share/pamac/transaction.py", line 11, in <module>
gi._glib.GError: 'gui/dialogs.glade' dosyasını açma başarısız: Böyle bir dosya ya da dizin yok
Böyle bir dosya ya da dizin yok = No file or dir exists.
I tried to install some Libreoffice extensions and some KDE packages at once and it has stopped. ( I installed them manually after that ;) )
Offline guinux
  • Core Team
    • Manjaro
  • Branch: unstable
  • Desktop: Xfce
  • Skill: Guru
« Reply #36 on: 17. December 2012, 15:30:43 »
sorry please try:
Code: [Select]
cd /usr/share/pamac
sudo ./pamac.py
and report.
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #37 on: 17. December 2012, 15:50:02 »
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #38 on: 17. December 2012, 15:53:35 »
Selected some packages to install from KDE and:
It is waiting as you see.
Offline guinux
  • Core Team
    • Manjaro
  • Branch: unstable
  • Desktop: Xfce
  • Skill: Guru
« Reply #39 on: 17. December 2012, 17:50:03 »
Yes, it's a bad bug, thx for the report. ;)
Offline Kolibry
  • Sr. Mitglied
  • Branch: Unstable
  • Desktop: Openbox
  • GPU Card: Ati Radeon HD6290 Wrestler
  • GPU driver: free
  • Kernel: Linux manjaro 3.12.30-1
« Reply #40 on: 18. December 2012, 23:05:47 »
Good work. Simplicity is the word  ;D
Ir's very intuitive, though it's missing some features, but it's under developpement stuff. Keep continuing to make a great job. Thanks.
Asus 1225B - 11,6" -  AMD E-60 Dual Core 1,3Ghz - 4 Go RAM - HDD 1To-  Radeon HD6290
 Manjaro Openbox - Github
Offline vanlong441
  • Artwork Team
  • Skill: Novice
« Reply #41 on: 24. December 2012, 17:52:43 »
Pamac crashes when resolving package conflicts
sorry please try:
Code: [Select]
cd /usr/share/pamac
sudo ./pamac.py
and report.
Code: [Select]
Resolving dependencies
Checking inter conflicts
ERROR: unresolvable package conflicts detected
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #42 on: 24. December 2012, 19:41:35 »
there is an pamac updater, what would happend with kalu?
Dutch go the dutch site :)
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #43 on: 24. December 2012, 23:41:11 »
http://mirrors.mycraft.eu/manjaro/pool/
I couldn't find pamac. Where is it?
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
« Reply #44 on: 24. December 2012, 23:45:16 »
unstable repositories, I think.
